Technical ***March 2025 Banger Meet Thread - In Like A Lion, Out Like A Lamb***
Discussion in 'Traditional Hot Rods' started by Jiminy, Mar 3, 2025.
  1. jim1932
    jim1932
    Is anyonse running a hardline from a B fuel pump to dual downdraft carbs? I am looking for options. The header cooks my rubber line. Good thing I checked it before I did the Spring start up because it was hard as a rock and was cracked on both ends. I suppose header wrap is also an option?
    Outback likes this.
  2. alchemy
    alchemy
    A few inches away and it still got cooked? That sounds odd to me.
  3. 62pan
    62pan
    Jim, I do. It's a copper coated steel line so I dont have any of the loops for vibration. Been there a couple of years now with no issues. If you notice there is no line from the sediment bowl to the pump. I replaced that hose with a steel line that follows the body down to the frame where I have a flow thru electric pump that I use for priming. That pump uses rubber hoses on each end to absorb whatever movement I have between body an engine. Its tucked in along the frame rail so no issues with heat from the header.
    mvee33, 51 mercules and Bigcheese327 like this.
  4. jim1932
    jim1932
    I am saying over the course of the summer. All I know is it is cracked and hard as a rock. Probably get more heat when I park it and no air is moving then it does driving.
  5. jim1932
    jim1932
    That is what I was considering. Good to know it isi good with vibrations. I was considering putting in a few coils if I could get them to fit and look right (like you stole it off a still). Is that a compression fitting where it comes out of the fuel pump?
  6. 62pan
    62pan
    With out looking I believe they are compression fittings.
  7. 282doorUK
    282doorUK
    I'm looking for ideas to stop oil starvation in right hand bends on a Burtz engine.
    Modified stock pump, seems like it needs some sort of baffles in the pan, any pics of what has worked for you would be much appreciated.
    TIA.
  8. Mine suffers from it. I did put a hinged baffle across the centre of the stock dip tray to little effect. I’m going to drop the sump and have have another go. Probably take the dipper tray out entirely and baffle around the pump. I’ve fitted a 100E pump to my latest engine which has a central oil pickup which works well.
    Outback and 282doorUK like this.
  9. Stovebolt
    Stovebolt
    my B starves on hard right hand turns - so it seems to be a trait that afflicts bangers in general.
    282doorUK likes this.
  10. steve hackel
    steve hackel
    Looking for a side drive magneto and possible the entire side drive mechanism for
    the engine - anyone out there have one for sale? Thanks :D
  11. I've got quite a few rough castings that will need to be machined. If any of you guys want one, give me a shout! I think $50 a pop seems fair. Here's a more-so completed one I'm working on finishing. 467814372_18029650367596101_527167825746845210_n.jpg 468004889_18029650358596101_726352897412504516_n.jpg
    adam401 and jet996 like this.
  12. burl
    burl
    from Minnesota
    Random pics still gettin stuff done on this pile using torque tube on this one Torque tube 1.jpg Torque tube 2.jpg torque tube 3.jpg lathe 1.jpg lathe 2.jpg trans 1.jpg
    mvee33, skip65, 5280A2 and 8 others like this.
  13. nutrocker
    nutrocker
    I finally manage to build this one up.
    1934 AA block with Burtz 5 bearing crank fitted via a girdle. Burtz rods, RaceTec pistons, Jim Brierley dual grind cam, Roof 101 head, Rotoshim oil pump and cam gears, bespoke Firth Speedshop supercharger, Stromberg 81 carbs, Burtz flywheel and Yapp pan and front cover.
    DO01000425.jpeg DO01000424.jpeg DO01000430.jpeg DO01000434.jpeg DO01000429.jpeg
    Flatdash, 40 Olds, adam401 and 24 others like this.
  14. alchemy
    alchemy
    That one has everything, and then a little more!
    nutrocker and Outback like this.
  15. I'd sure like to see the girdle/crank ***embly
    and of course some hp numbers
    John
    Outback likes this.
  16. nutrocker
    nutrocker
    here you go John.
    Don’t have any hp numbers yet. Hopefully in the next couple of weeks I’ll get it on a mates engine dyno.
    jet996, mvee33, Crazydaddyo and 5 others like this.
  17. That is a nice setup, I wasn't sure how the Burtz crank rear main looked the bearing is shorter.
    I have had people asking about using with a girdle.
    Keep up the great work, J
    Here are a couple I have done in the past and currently run.
    jet996, Crazydaddyo, burl and 3 others like this.
  18. nutrocker
    nutrocker
    Very nice John.
    I made a bolt on seal housing for the rear.
    I also made all 5 bearings oiling from outside.
    40 Olds, jet996, mvee33 and 4 others like this.
  19. Very nicely built
    I had thought to maybe cut the crank down for a 2pc chevy seal and thrust off the center.
    John
    Outback likes this.
  20. Outback
    Outback
    from NE Vic
  21. nutrocker
    nutrocker
    I too thought about using the centre for thrust, but easier to machine on the ends.
    Pete
    Outback likes this.
  22. Crazydaddyo
    Crazydaddyo
    Here is what Milodon used to do to his oil pans
    jet996 and 282doorUK like this.
  23. Crazydaddyo
    Crazydaddyo
    This is what I did
    20130114_183347_zps16228693.JPG 20130114_183510_zps261b9ff9.JPG 20130210_144149_zps7ac1880e.JPG 20130119_170457_zpsd70151d3.JPG 20130119_155958_zps64569c73.JPG 20130119_160021_zpsaf1f5a83.JPG
    burl, jet996, 282doorUK and 1 other person like this.
  24. hotrodA
    hotrodA
    Beat me to the Milodon article. I remembered it but couldn’t find it.
    Lots of good info in it.
    Anyone have corrections that need to be made.?
    Crazydaddyo likes this.
  25. So here’s my centre baffle - not very successful as it really needs sealing to the bottom and fore/aft trapdoors.
    More successful was the 100E oil pump. Repurposed the original pickup pipe which ended up with a few kinks in it...
    Crazydaddyo, jet996 and 282doorUK like this.
  26. Dedsoto
    Dedsoto
    from Australia
    Haven't posted in some time, life etc. Starting to turn tools again though, have pulled the roadster down to start fitting the necessary things for registration down here. It's had a hard time after the last two Red Dust Revivals.
    I also took the day to go pick this old welder up today, as I'd been looking for an engine to build and this came up. Visually I know it's a B, and has a C head, I'm ***uming it's from a BB by the bell housing. Turns over by hand with good compression, does seem to be well looked after. What are my chances it's a counterweighted crank?
    A few closer shots...
    Doesn't appear to be a diamond, not even sure we had them down here though, shot of the Magneto setup below
    Any insight appreciated
    burl, Bigcheese327 and 282doorUK like this.
  27. Fabber McGee
    Fabber McGee
    Pull the cover off the fuel pump hole and see what you have for a crank if your curiosity is killing you.
    I think I'd pull the lifter cover (because it's easy) and if it's not completely buried in sludge put it back on and see about getting it running.
    Dedsoto likes this.
  28. 282doorUK
    282doorUK
    [/COLOR]
    [/COLOR]
    Thanks for input guys, some good ideas to think about there.
    Meanwhile today I was clearing a bit of bench space when I spotted an old pump and a forgotten small stainless steel bowl laying together beckoning to me, unbelievably they fit perfectly together!
    Hmmm.. thinks...if I weld the bowl to the pump shroud on my re-con pump, then cut the bottom of it off, it will extend the shroud down. The bowl being wider than the shroud it won't restrict the flow around the bottom of the pump where the gauze is showing, which would happen if I just welded two shrouds together.
    So I fired up the CAD equipment and prototyped an oil pan extension, my idea being that the pump will work as normal, but the oil being deeper around the pump it would take way more centrifugal force to move the oil away far enough to allow air to get ****ed in under the extended shroud.
    I might have made the pan extension a bit too deep, and I've got a feeling I'm missing summat, it can't be that simple, your thoughts would be appreciated.
    In England we are blessed with roundabouts everywhere and we have a large badly designed fast multi lane one that has to be negotiated almost every time we leave home. They've been messing about with the layout for years and it's still scary enough that many timorous types avoid using it altogether and make a big detour.
    It has three 4 lane roads and two 2 lane roads connected to it, very spirited driving is called for, and as our roundabouts go clockwise every one is a RH bend!
    Last thing I need is to be stressing about oil pressure!
    Crazydaddyo, hotrodfil and jet996 like this.
  29. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    So, I gotta ask the hive mind.... compression fittings are satisfactory for fuel lines? I see everything from "yes" to "you'll burn your car down to the ground the first time you take it out if you don't use double flares."
  30. alchemy
    alchemy
    Why risk it?
    Fabber McGee likes this.
