Master Cylinder [Wilwood tandem 260-7563 Tandem 1" Bore Master Cylinder] started leaking from the piston. Brake fluid [Dot4] ran down the outside and inside of the firewall, into every nook and cranny down to the floor of the garage. Big mess to clean, a lot of bubbled paint. Any way to keep it from seeping back out from around brackets and stuff after I clean and repaint? I figure about the only course I got is to clean/flush every where with Brake Clean and hope for the best? Should I rebuild or replace the MC?
Hot soapy water scrub , rinse, repeat . I would use air to blow out and dry around brackets and creases. , welds etc . brake clean will cause more damage to the paint and area , brake fluid is water soluble . Water will dilute and get rid of it , use dawn dish soap . I would pull the master apart and see how bad it is , if it’s just a hone , polish and seals rebuild it , cheaper then buying new . that ****s .
Brake FLUID is water soluble. No need for brake clean if you have water and soap. Warm water even better.
I'd use this and a power washer... works great! https://www.lastotallyawesome.com/shop/all-purpose/awesome-allpurpose-cleaner-spray/
For those that are unaware: brake fluid is hygroscopic unless it's dot 5. Flushing with water will take care of the mess. I wish I had known that when I was young. Back then it was just sticky stuff that took paint off in the wrong places.
Thanks to all, wouldn't have thought a good soap would work as I was pretty upset. Funny [not] how the MC just dumped while sitting for 3 months. Since it is an aluminum MC I wonder if the bore is anodized for wear or not, probably not? Maybe I could get it sleeved [rebuilt] by a rebuilder, had one done years ago in br*** and worked well. I will wipe up what I can when I can stand to look at it till weather breaks for a good wash outside, wish my garage had a drain. Sigh. PS: Push rod alignment is [should be] good as I am **** about things like that but I will check.
I have the same Wilwood master cylinder kit in my 1962 Volvo. It started leaking at about 5 years. I just bought another one. Russ
I think if memory is right mine maintained a drip that never dripped [if that makes sense] so I watched it, level never went down till last fall couldn't see where it went [hindsight probably interior]. Topped off and watched and was ok till now. Just about 14 years. Wish I didn't have to buy the whole kit; anyone need any remotes?
Some useless memories: When I was a kid and working on model cars, we used to soak old bodies in a little tub of brake fluid to remove the paint. Then just washed them off with soap and water in the ba*****t sink. It never hurt the plastic one bit.
Old German mechanic taught me many moons ago about Simple Green on brake fluid contaminated gunky brake drums. Keep two spray bottles handy, 1:10 and 1:1 dilution. Great for neutralizing brake fluid and other spills.
I seem to recall some older shop manuals suggesting denatured alcohol for cleaning wheel and master cylinders. Don't know if this is still recommended with newer brake fluid formulations.
Last I knew, isopropyl alcohol was the recommended flush for the whole system when changing over to DOT 5 brake fluid. Roger
For thick oily gunky road grime, I am a huge fan of the Dawn Powerwash spray. Restored a Schwinn last year, didn't want to use the usual caustic stuff. Tried some DP on the smaller hardware. Worked like a charm.
