Projects Uncle Jim’s 32
Discussion in 'Traditional Hot Rods' started by Brian Berger, Jan 23, 2025.
  1. 34 5W Paul
    34 5W Paul
    from Fresno CA
    Fantastic progress so far, keep it going! Love to see all the work. Thanks for posting this up.
    BTW from that to this with just a little scrubbing? Wild.
  2. Brian Berger
    Brian Berger
    Got the wishbones shortened. Now to finish the torque tube and driveshaft, then will be 34 radius rods kn the front and fix the steering issues. IMG_6560.jpeg IMG_6562.jpeg IMG_6564.jpeg IMG_6563.jpeg
  3. It’ll buff out. Hehe.
    Tow Truck Tom and clem like this.
  4. Hopefully you plan on using a lot stronger material to align the TT pieces that what I see in the mockup. I would be using some 1/4" thick angle iron to keep things as rigid and aligned as possible. I would tack around the whole circumference and probably weld 1" beads - alternating back and forth from one side to the other. Welding loves to warp things - everything you can do to reduce the warping is a good thing!
    Brian Berger and The37Kid like this.
  5. The37Kid
    The37Kid
    I have several stock torque tubes in different lengths. Would cutting a stock one at the rear flange, then removing the section to make it the correct length and rewelding the rear flange be stronger and less welding?
    tb33anda3rd and Grumpy ole A like this.
  6. Hell of a lot easier job that trying to graft a section in the middle and hope that you can somehow align the two ends. Given how a TT pivots in the front, my biggest concern is for the front roller bearing race area to be in correct alignment and centered with the driveshaft that runs inside of that roller bearing - the rest (generally - other than length, orientation of radius rod mounts, etc) isn't as much of a concern (it can be a bit off).
    Another situation is when using a solid style driveshaft (later era rears) - ones that use a bearing in the middle of the driveshaft - that makes all the alignment issues all the more difficult. You don't want the alignment between the front, bearing, middle bearing and pinion mount such that it is attempting to "bend" the driveshaft due to things not being well aligned.
    rod1 and The37Kid like this.
  7. Brian Berger
    Brian Berger
    Well all the work is done just needs cleaned up. I ended up using a different torque tube to keep the rear bearing,it was shortened at the rear. Got drive shaft cut and machined and all the other stuff done. I learned IMG_6646.jpeg IMG_6644.jpeg IMG_6649.jpeg IMG_6645.jpeg IMG_6647.jpeg IMG_6648.jpeg a lot about banjo rears on this project.
  8. Brian Berger
    Brian Berger
    All the measurements worked out perfect and it fit great. I used some 3/8 angle when I welded the actual tube I ended up using.
  9. Brian Berger
    Brian Berger
  10. Robdski
    Robdski
    Such a great story and thanks for sharing the work you are doing.
    Brian Berger likes this.
  11. Brian Berger
    Brian Berger
    Paint the leaf spring and make some new brake lines and she’s going in for the last time!! Yay!!! IMG_6663.jpeg
  12. Grumpy ole A
    Grumpy ole A
    Looking good but I have a question about the drain plug on top.
  13. Brian Berger
    Brian Berger
    When they built the quick change back in the day they flipped the housing ‍,I can drain out the rear of quick change. I know I should have drilled a new drain plug and I might still .
    Tow Truck Tom and Okie Pete like this.
  14. Brian Berger
    Brian Berger
    It’s been a lot of work but well worth it! Make one brake line and bleed the brakes and rear axle swap is done! I couldn’t be happier with how it turned out! IMG_6675.jpeg IMG_6677.jpeg IMG_6678.jpeg
  15. tubman
    tubman
  16. burl
    burl
    from Minnesota
  17. Rocket88NZ
    Rocket88NZ
    Thanks for sharing, great story and car, what a treasure. Here is a New Zealand quick change made I think in the 50's for a midget or sprint car. I am hoping to use this in my roadster eventually but am going with a standard banjo to start with. P1080072.JPG P1080073.JPG
  18. Robdski
    Robdski
    Nice work. That really worked out great!
  19. Brian Berger
    Brian Berger
    Thanks! I have learned a ton about these cars already and have gained a lot from reading stuff on here.
    Tow Truck Tom and Robdski like this.
  20. Brian Berger
    Brian Berger
    Got the rear all done so now on to the front. Just basic upgrade, 34 rods and lower frame brackets and new rod ends. The rods it had were super short. The front axle and related parts are in great shape with no wear ! I can’t believe it all came right apart! IMG_6723.jpeg IMG_6724.jpeg IMG_6722.jpeg IMG_6721.jpeg IMG_6719.jpeg IMG_6718.jpeg
    tb33anda3rd and Tow Truck Tom like this.
  21. ModelAMitch
    ModelAMitch
    Awesome looking car!
    Are you swapping out the front rods because they're longer? Better stability?
  22. Brian Berger
    Brian Berger
    Yeah replacing the radius rods with longer ones from a 34. Hopefully help it drive better ,the ones on it are really short and car is a little darty sometimes.
    Tow Truck Tom and ModelAMitch like this.
  23. Brian Berger
    Brian Berger
    Got front all mocked up . I got the caster where it needs to be now and wheelbase. Pitman arm will need some love,I made a template to check body clearance. It’s close might need some tweaking. IMG_6735.jpeg IMG_6744.jpeg IMG_6751.jpeg IMG_6750.jpeg IMG_6749.jpeg
    Tow Truck Tom likes this.
  24. Brian Berger
    Brian Berger
  25. alchemy
    alchemy
    The wishbone shouldn’t have a bow in the middle of it. Looks like the right side needs some straightening.
  26. Brian Berger
    Brian Berger
    They were beat up , straightened the best I could cold without cutting and welding. They’ll be fine for and old ratty roadster, it looks worse than it is. Bottom and sides are pretty straight with a straight edge .
    Tow Truck Tom and alchemy like this.
  27. mrquickwhip
    mrquickwhip
    Absolutely awesome score. First set of pics with the as found whitewash are my favourite. Enjoy the hell out of it. Thanks for sharing.
    Bob in Scotland
    Brian Berger and AmishMike like this.
  28. Bitchin' Scoops
    Bitchin' Scoops
    What a cool story & such a beautiful traditional hot rod!!
  29. Brian Berger
    Brian Berger
    The body and frame are ready to be one again! Got all my suspension work done front and rear fixed caster issue and steering knuckles were bent at some point in time to clear the old short radius rods. Man turning radius is much better. Can’t wait to drive it again! IMG_6788.jpeg IMG_6791.jpeg IMG_6789.jpeg IMG_6790.jpeg
  30. Jacksmith
    Jacksmith
    from Aridzona
    Now that there is a real Hot Rod... Lookin' good!
