Technical 1940 Ford Guys
Discussion in 'Traditional Customs' started by jumbogem29, Mar 23, 2025.
  1. jumbogem29
    jumbogem29
    from Alabama
    Hello can you tell me what most is running tire size on your coupes . i was looking at the 700R-16 or the 750R-16 and the 600R for the front . Any pictures would be great trying to get the best stance on the old coupe thanks
  2. chevyfordman
    chevyfordman
    The stance looks good but the rear end has to be dropped to get the tire out of the wheel well with 750's on my ex car. IMG_2542.jpeg
  3. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    I can’t remember what tire size I’m running, I think 16’s in the rear and 15’s in the front but will check next weekend.
    Here is some pics.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    8.20-15 rear and 5.90-15 front
  5. Bandit Billy
    Bandit Billy
  6. V8 Bob
    V8 Bob
    205/70x15 fronts, 235/75x15 rears.
  7. hotrodharry2
    hotrodharry2
    from Michigan
    This thread is a help to me also! My 40 had skirts & lowering blocks in the rear. I’ve been looking at tire size! Mine currently are 205 65 x15. Also loosing the wide whites. Personal taste, isn’t that what Hot Rodding is all about?
  8. @hotrodharry2 , if I was anywhere near that car, I'd probably put 195.70 on front and 225or 235/70 on the rear.
    hotrodharry2 likes this.
  9. HOTRODPRIMER
    HOTRODPRIMER
    I can imagine it's a PITA to change a rear tire but it looks & sits great. HRP
  10. 19Fordy
    19Fordy
    Remember, when you "rake" a stock 40 Ford the rear end fluid gravitates into the torque tube, depleting the gear oil in the differential. Over time, the gear oil dissolves the rubber encasing the torque tube center bearing causing a vibration of the solid driveshaft.
  11. lothiandon1940
    lothiandon1940
    ....WOW!!:eek:
  12. This is very true. I know thee is a seal that can be installed between the Banjo housing and the T T flange. I'm currently trying to find more info on what it takes and where to buy one. I know I've also read about it here but so far the search hasn't turned up anything.
  13. 19Fordy
    19Fordy
    Skip Haney on Fordbarn sells a replacement center bearing. Read this
    https://www.fordbarn.com/forum/printthread.php?t=186780 .
    The OEM bearing is shown in first photo below. They are very rare and expensive.
    Go over to www.fordbarn.com and do a search for Torque Tube Center Bearing. There was a fellow in Big Spring, TX who was making a seal (last4 photos) to prevent draining of gear oil into torque tube. ALSO, BE SURE AND READ THIS:
    https://www.fordbarn.com/forum/showthread.php?t=301624&highlight=torque+tube+center+bearing
  14. 50 Merc Man
    50 Merc Man
    Looks like the car my dad bought off a little old school teacher when he was in high school. His first car btw!! RIP Dad!!
    Moriarity likes this.
  15. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Checking today....
  16. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    7.50-16 Rear and 5.90-15 Front
    southpaw-customs likes this.
  17. tubman
    tubman
    I gotta ask : If those are the sizes on the tires, how the heck old are they? I had used 8.20-25 tires on the back of my '51 Ford in 1959; when I wanted to put them on my new Corvette, they has already been superseded by 9.15-15's. I haven't even seen a 5.90-15 in the last 60 years.:D
    Re-pop's maybe?
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    warbird1 and lothiandon1940 like this.
  19. Mr.Norton
    Mr.Norton
    from Sweden
  20. jumbogem29
    jumbogem29
    from Alabama
    Thanks to all.
    lothiandon1940 likes this.
  21. jumbogem29
    jumbogem29
    from Alabama
