Best way to cut sheet metal for building?
Discussion in 'The Antiquated' started by Roothawg, Mar 23, 2025.
  1. Roothawg
    Roothawg
    I am working on the Dust Bowl World Headquarters (TM) and I am really dreading cutting the sheet metal for the end wall that separates the house from the shop. I have tried everything over the years, but they are usually loud and messy. It’s 26 Gauge Ag panel, Galvalume.
    Im sure yall know something better……you always do.
    Thanks,
    Root
    tractorguy likes this.
  2. noboD
    noboD
    6 inch cut off wheel in a four inch grinder. Wear leather gloves and ears.
    tractorguy, Roothawg and Okie Pete like this.
  3. Roothawg
    Roothawg
    I usually do that or use the circular saw with a metal blade.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    There was a custom production job at work that involved cutting a bunch of sheets of corrugated steel. they used a skill saw with a steel cutting (toothed) blade. It worked real good and made nice cuts but was LOUD and wear a full face shield cuz the chips are kinda sharp and hot
  5. Roothawg
    Roothawg
    I have the Diablo blade coming in a day or two. I need to order a good set of muffs. Mine are shot.
    Okie Pete likes this.
  6. Harv
    Harv
    from Sydney
    I put a new roof on the shed, and needed to trim some of the sheets. I used a nibbler - a lot quieter than a circular saw, less likely to amputate my vitals, cuts circles/curves easily. I was only doing a single car shed, so bought the el-cheapo version that runs on a drill. There are upmarket versions of the tool though,
    Craftright Sheet Metal Nibbler Cutter - Bunnings Australia
    Cheers,
    Harv
  7. mammyjammer
    mammyjammer
    from Area 51
    Upside down Plywood blade (so teeth point the wrong way). Seriously,works pretty good. Cheap,but loud as hell.
  8. nrgwizard
    nrgwizard
    from Minn. uSA
    & a fine-tooth at that. I was surprised it worked well. & yes - excessively loud...
    Marcus...
    deathrowdave, Roothawg and Okie Pete like this.
  9. Roothawg
    Roothawg
    I have a. Set of nibblers, but I’ll be danged if I can find them. Everything from the shop is boxed up. I looked for about an hour, finally gave up and bought the blade.
  10. Stack up all the same sizes and cut em with a circular saw.
    lay out the holes and drill several sheets at one time
    Okie Pete and hotrodjack33 like this.
  11. Roothawg
    Roothawg
    Like my***** is that accurate.....
    1952henry, Okie Pete and Tim_with_a_T like this.
  12. Yep.
    How my roofer does it.
    Cuts all the same size at one time.
    Lays out holes and drills em.
    All the screws in my roof line up. Looks great
  13. Roothawg
    Roothawg
    Yeah, but I didn't build your house.....
    Okie Pete and anthony myrick like this.
  14. hotrodjack33
    hotrodjack33
    Yes that's how I did the new roof on my house. Cut 4 sheets at a time with a carbide fine tooth in a skill-saw...and then pre-drilled them, all 4 at the same time.
    Looks like just a boring little house...
    But the "money shot" is out back;).
    The Chenango River:)
    Chief 64, williebill, Lepus and 6 others like this.
  15. deathrowdave
    deathrowdave
    from NKy
    Beautiful home , peaceful surrounds are priceless .
    I have a huge home , not bragging , just sharing its lots of wasted space to heat and cool .Lots of fun when grand children stay over and holidays , other than that its a full time job to maintain . Everything I do I have to have another piece of equipment to maintain it . I’m not a hunter but allow hunting to friends and neighbors . 3 years ago the near state record Buck was taken on my property . I would be pleased with smaller home , flat ground , larger garage to tinker in .
    Roothawg, hotrodjack33 and Okie Pete like this.
  16. alanp561
    alanp561
    I'm late to the party but here's an idea. I have bought metal siding and roofing directly from the businesses that make it, cut to my dimensions. There are 3 such places in the small city where I live. It sure saves money and aggravation with the extra advantage of having more colors than the big box stores. You're close enough to BBM Steel Buildings in OKC and they cut to your dimensions and they aren't the only ones. Their prices per foot are slightly more than buying from Home Depot or Lowes, but if you give them the correct lengths you need, there's no waste or noise.
  17. Roothawg
    Roothawg
    That’s who I bought from. They cut my pieces to get them close, but they won’t cut an angle for you. Only straight cuts, which I understand using a shear.
  18. alanp561
    alanp561
    Sorry, I didn't realize what you were doing, buy big earmuffs.
    Okie Pete and Roothawg like this.
  19. Roothawg
    Roothawg
    No worries. I did ask them, they said straight cuts only.
  20. TraditionalToolworks
    from NorCal
    Sounds like a good opportunity to get a new tool! ;)
    https://www.homedepot.com/p/Milwauk...-3-in-Cut-Off-Saw-Tool-Only-2522-20/305663849
    That would work if you have Milwaukee batteries. The M18 charger has an M12 on it also, but you need the M12 battery. This is the best for cutting sheet as it lays flat on the material. I have used a cutoff wheel in the past, but these work better for me.
  21. Roothawg
    Roothawg
    I started trimming them last night with my electric shears. Works ok, until the ribs, then we struggle a bit. I'll post pics when I have some verifiable proof that I am actually back to working on it.
