Fatman Mustang II lower control arm bushings
Discussion in 'Off Topic Hot Rods & Customs' started by kimden5, Feb 6, 2025.
  1. kimden5
    kimden5
    from Florida
    Does anyone have a part number for Fatman Fabrication Mustang II SS tubular lower control arm bushings. They are out of business. I've tried Jegs, Speedway Motors, Summit, Moog and Ebay with no luck. Thanx in advance.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    moved to the off topic forum
  3. Randy Sides
    Randy Sides
    I am in need also. Purchased for a 49 Chevy Pickup in 2003. Has not been on the road yet but lower bushings decenigrated
  4. deathrowdave
    deathrowdave
    from NKy
    By some stock and have someone turn new ones if need be
  5. rockable
    rockable
    Try Energy Suspension. Those bushings are off the shelf bushings, no special. You just have to do some measuring and online research. ES makes lots of bushings.
    https://teamenergysuspension.com/
    nunattax likes this.
  6. TA DAD
    TA DAD
    from NC
  7. Randy Sides
    Randy Sides
    I ordered some from Speedway Motor but they were too big. I think I will show up at the NAPA store in the morning to see what they have. I’ll also check Energy and see if they have dimensions.
  8. rockable
    rockable
    I will bet if you measure the i.d., the o.d. and the length of tfhe bushing, you can call ES and speak to an application spe******t who will pick out the correct bushings for you.
  9. gene-koning
    gene-koning
    And probably for less money then at NAPA.
    rockable likes this.
  10. Gary Sleeman
    Gary Sleeman
    from Central NC
    Make that three members looking for control arm bushings to replace the original crumbling 20 year old, never on the road bushings. Energy Suspension chat and phone support were no help! Said they only can look up by application. Now their website has a Universal Page that has inputs for dimensions and I think the part number for the lower control arm bushing is 9.9106. Couldn't find a match for the upper. I might just run with the suggestion from post 4 to purchase some stock and machine my own, I do have a lathe. Thanks deathrowdave
  11. nunattax
    nunattax
    im watching have 10 year old bushings in fat man front,no play at present.would excessive wear be a result of overtightening the pivot nuts
  12. rockable
    rockable
    I'm pretty sure the control arms and ball joints changed over the years. Not sure about the control arms bushings. Just because his fits a 20 yr old stub doesn't mean it will fit a 10 yr old. Get measurements.
