Hot Rods Making the Unexpected '34 my own
Discussion in 'The Hokey Ass Message Board' started by drdave, Mar 3, 2025.
  1. Bentrodder
    Bentrodder
    from Cotati
    @anothercarguy That looks AWESOME! How did you attach the stainless rod to the aluminum panel?
    Thor1, anothercarguy, drdave and 2 others like this.
  2. downlojoe33
    downlojoe33
    What a transformation on that dash! The ideas just keep coming.
  3. guthriesmith
    guthriesmith
    Proves there is hope for billet after all! Very nice! :cool:
    winduptoy, anothercarguy and drdave like this.
  4. Thanks guys, I too was pleased with the outcome.
    I tack welded 4 small (about 3/4" wide) "L" shaped tabs around the perimeter on the backside of the stainless steel trim ring. The tabs hold the ring from coming forward, and between that tabs on the back and the offset/overlap of the ring to the aluminum billet in the front, it clips into place. Here's a quick sketch of the sideview to try and show my explanation. There is enough flexibility in the ring that I can unclip it one clip at a time with a gentle pry from the backside.
  5. Bentrodder
    Bentrodder
    from Cotati
    GENIUS!!
    drdave, Algoma56 and anothercarguy like this.
  6. drdave
    drdave
    What a great idea and an even better look! Thank you for sharing @anothercarguy!!!
    anothercarguy likes this.
  7. panhead_pete
    panhead_pete
    drdave likes this.
  8. drdave and panhead_pete like this.
  9. duecesteve
    duecesteve
    I have 2 orange cones stuck together and put them on a little turn table with plywood so you can spin it,then put the rim on top of the cones and whala you got a wheel painting rotisserie. And you can flip it over and do the back,I clean tire with lacquer thinner and duct tape around the lip and use black trash bag to cover rest of the wheel.
  10. drdave
    drdave
    Well, if you know me, parts collection started pretty quick...even if installing them isn't. LOL I have most everything to eliminate the billet....finned aluminum borrowed from the Merc for the motor, new steering column stalks to get right of the mix matched billet knobs, wiper arm, etc. The highlights are these.....
    '39 style banjo wheel for a GM column....but it will be a while before me and the current holder of it can hook up to bring it home. For now I'm still going to swap in the wheel out of the Mustang since I have the adapter on hand.
    This should take care of the billet gauge panel and not working 80's VDO speedometer...
    .....aaaaaaaand.....
    Picked up the mounted tires at lunch. 3 of the 4 are already on the car. I had the rears mounted with one on an 8 inch rim and the other on a 7 inch, not knowing if the 8 inch would fit....it do.....
  11. straykatkustoms
    straykatkustoms
    Very Kool! You are making all of the right changes. Looking forward seeing it soon. The kool part of the story, you piked up the wheels while driving the Impala. You the Man!
  12. guthriesmith
    guthriesmith
    What's that funny looking tank in the trunk of the Impala? :rolleyes:
    winduptoy, straykatkustoms and drdave like this.
  13. Jim Bouchard
    Jim Bouchard
    Looking good!!!!
    I can’t wait to see the new results
    drdave likes this.
  14. drdave
    drdave
    Two mounted wheels in the back of the Impala now....along with the last two boxes of train cars I picked up from dad's.
    That tank is where I keep the Coors on tap, Jeff....don't you know nuthin'? Hahahaha
    Pictures of the new look hopefully tomorrow....gotta find my center caps. LOL
    Grandadeo, winduptoy, Thor1 and 5 others like this.
  15. drdave
    drdave
    That’ll do pig….
    You can put a kustom guy in a hot rod, but you still can’t get the kustom out of him….bullet center caps and lug nuts. Lol
    Obligatory run to Home Depot after dinner… lol
    I wouldn’t mind the tail down a bit to tuck the tires up in the fender a bit, but not sure how to do that on a four bar, coil over rear end. I’ll have to look and see if I can adjust the shocks any I guess.
    For the curious…those are 195/55/15 up front and 235/70/15 in the back. The steelies were 185/65/14, which are pretty much the same size overall as the new 15’s and the rear were 225/70/15…the new ones are 1/2 taller and an inch or so wider…and now on 8 inch wheels.
    Barn Hunter, bymanr, Lepus and 34 others like this.
  16. wide34
    wide34
    from Texas
    You sure have a great eye for what looks good, great rim addition! You should have some adjustment on the coil overs but will be limited by the frame to axle spacing. I’ve got mine at 2 1/2 inches but that’s required a pretty stiff shock so rides on bumpy roads are a thrill a minute! Hope you drive the hell out of it!
    straykatkustoms, drdave and Thor1 like this.
  17. brett4christ
    brett4christ
    @drdave The wheels are PERFECT!!!!!!!
    drdave and HOTRODPRIMER like this.
  18. HOTRODPRIMER
    HOTRODPRIMER
    I totally agree with Brett, nothing would have looked better! HRP
    winduptoy and drdave like this.
  19. drdave
    drdave
    Thanks guys! I really like the look. Torque thrusts are probably my favorite mag wheel. And of course, who doesn’t love polished, but I think the grey centers really hit it with the paint in this case.
    Thanks for the info @wide34, I’ll have to get under it and look to see if there is any wiggle room back there. …and don’t worry…it’s getting driven plenty, between the Impala and the Tbird. I could be driving the A, too, before I take it apart to finish the interior install I guess, but since it’s leaving I almost don’t consider it mine to drive. Weird. Lol
  20. downlojoe33
    downlojoe33
    Who doesn’t love Torque Thrusts? Although I prefer the straight spokes. Great addition to your car! And the non polished look suits the car much better IMHO. Gorgeous car, what’s next?
  21. drdave
    drdave
    Next up will be swapping the steering wheel and the billet off the motor. Be a while before I have time to pull the gauges out and swap them over. The other big thing to decide is bring this or the Pratt ‘58 to the Stray Kat. Lol
  22. swade41
    swade41
    from Buffalo,NY
    That's a nice looking car, what is the chop amount ?
  23. Bentrodder
    Bentrodder
    from Cotati
    What’s the thing on the front bumper?
    drdave likes this.
  24. Tim
    Tim
    from KCMO
    Christmas wreath holder
    winduptoy, drdave and guthriesmith like this.
  25. drdave
    drdave
    Haven't a clue. Previous owner had the car about a year and the guy he got it from didn't have any real info on builder or history. Hope to run up on a stock one to be able to measure the window height to compare and see if I can figure out the amount.
    Accessory bumper guard.....
    ....or that. LOL
    Thor1, pprather, swade41 and 3 others like this.
  26. drdave
    drdave
    Got a little time to fiddle around last night...
    First thing I did was remove the wreath hanger as @Tim called it. LOL. I didn't hate it but probably doesn't fit the hot rod look so I'll try it with it off.
    Then, after an inordinate amount of time looking for the new wiper arm I bought (why couldn't you find it, Dave? Shop looks immaculate and so well organized...... :/ LOL) I got that swapped out. The new one won't seat down all the way on the splines, but it's still better than the squaredy billet one...
    Also robbed the finned aluminum engine goodies off the dead Merc motor and switched them for the cheap chromed diecast "billet" that was on there (see first post). They need cleaning of course, but the whole engine needs a degrease when I wash the car next week for the Stray Kat, so I just threw them on.
    I also switched out some of the billet steering column levers and knobs, but will finish that when I swap the steering wheel, so didn't take pics of that. Also have an original style rear rear view mirror on order that will mount to the header to replace the billet one glued to the windshield. I think we are coming around the corner and getting this thing in shape.
    Also sectioned a '49 Ford coupe quick last evening....I doin't know why everyone says sectioning a car is sooooooo hard. LOL
  27. guthriesmith
    guthriesmith
    Getting better all the time!
    porkshop, drdave and Robdski like this.
  28. J. A. Miller
    J. A. Miller
    from Central NY
    Much less welding when they're that size! :D
    porkshop and drdave like this.
  29. drdave
    drdave
    Haha! True enough!
    porkshop likes this.
  30. 54delray
    54delray
    from Fremont NE
    This gonna be for Mick's common kit build at Lead Ain't Dead??
    straykatkustoms likes this.
