Hot Rods How about some love for the T-Bucket?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, May 9, 2021.
  1. RodStRace
    RodStRace
  2. Dave G in Gansevoort
    from Upstate NY
    I like the Moon discs…
    High test 63 and Snicklefritz65 like this.
  3. 40ragtopdown
    40ragtopdown
  4. 40ragtopdown
    40ragtopdown
  5. 40ragtopdown
    40ragtopdown
  6. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    That's a cutie!
  7. Snicklefritz65
    Snicklefritz65
    from Mass.
    i'm going to binge-watch this series now that it's pretty much at an end. i was kinda teasing piero about starting a 'lucky and piero show' and i would like to see a series on the green t being restored and seen in the background. i forget the guy's name but he seems like a good guy. also, i know lucky is working on something of his but would like to see his high speed coupe get some love.
    RodStRace likes this.
  8. Snicklefritz65
    Snicklefritz65
    from Mass.
    dunno if it's been posted before but this was from a local, now shut down, event. orange m***. dragstrip reunion in 2012.
    CSPIDY, Deuces, bschwoeble and 11 others like this.
  9. swifty
    swifty
    Is that a Chev engine pretending to be a Studebaker or something that it's not.
    bchctybob likes this.
  10. Snicklefritz65
    Snicklefritz65
    from Mass.
    good catch. i took another look right after i posted and i think it's a sbc. water pump area is a little fuzzy for me.
  11. Dave G in Gansevoort
    from Upstate NY
    SBC with a long style water pump
    Snicklefritz65 and RodStRace like this.
  12. AndersF
    AndersF
    I have followed the Tweedy pie build from the start on youtube.
    Here is ep 1 thats all about the orginal Tweedy pie.
  13. Stock Racer
    Stock Racer
  14. 40ragtopdown
    40ragtopdown
  15. 40ragtopdown
    40ragtopdown
  16. Dave G in Gansevoort
    from Upstate NY
    Those rear wheels look like they were fabricated from plate and rims. Some sort of flame cut, laser cut or water jet cut center from flat sheet.
    Stock Racer and RodStRace like this.
  17. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    And the front ones have speed holes!
    Stock Racer likes this.
  18. Stock Racer
    Stock Racer
    I don't know what they are but they sure are cool!
  19. [​IMG]
    A-Frames on a T Roadster will never look okay to me. I can overlook the 4 bars on the rear, sorta.
  20. They remind me of some of the Walmart photos that make you feel like ralphing.
  21. Tim_with_a_T
    Tim_with_a_T
  22. Dave G in Gansevoort
    from Upstate NY
    Tim, don’t you think that centers like this could be cut out with an abrasive water jet system? The company that I used for some custom brackets for the whatever said they can hold tolerances in the thousandths. I know that the brackets for the rear axle were perfectly sized to be a fig snit on the 3 inch axle tubes.
    Tim_with_a_T likes this.
  23. Tim_with_a_T
    Tim_with_a_T
    Yes; I believe water jet could likely hold tight enough tolerances for wheel manufacturing. If I had a personal CAD system to play with, I'd be doing quite a bit of water jet and sendcutsend activities. For wheel mfg, I'd like to see some FEA simulations before welding them up, just to put the thinker at ease. In a straight line, seems like a flat spoke wheel would be fine, but going around a corner, then add some bumps in the road, I get nervous.
  24. Dave G in Gansevoort
    from Upstate NY
    Ah young paduwan! You are wise beyond your years. I remember when truck and jeep guys used steel wheels with a somewhat similar center design. One design had half the “spokes “ bent in, and half out, making the final product very strong. We should be able to use the same concept…
    Nah, just ruminating about it for ha has!
  25. 26 T Ford RPU
    26 T Ford RPU
    Wheels centers cut from plate were very common in NZ in the 60's-80's and we had a engineering firm close by that did similar, they also widened rims. They were everywhere. JW
  26. DDDenny
  27. RodStRace
    RodStRace
    I looked for more on the drag car. Nothing came up except a FB post of the pic and it's in a thread here on panel striped cars.
    Those wheels differ from most in that the lugs are in the spoke area, not the web in between.
    The off road truck wheels that were similar had more spokes and did have a convex shape to the center.
    I agree that a flat center is not as strong as a dish of some sort, especially if it's curved in two directions like common steel wheels. Astros also had (have?, a member sells new ones) a single stamped center with a dish.
    https://www.jalopyjournal.com/forum/threads/new-astro-howard-style-chrome-slot-wheels.970413/
  28. denis4x4
    denis4x4
    from Colorado
    Jackman Wheel Company was formed in 1968 and was the go to for those kind of wheels. They're still in business selling the same flat plate center wheel for trailers and off road racers. It's the same Jackman brothers that had the '32 coupe named top 50 at the GNRS
  29. 40ragtopdown
    40ragtopdown
  30. Jay McDonald
    Jay McDonald
    This T has a perfect stance, not the only thing in this picture that has that.
