home made tools and equipment...
Discussion in 'The Hokey Ass Message Board' started by kustombuilder, Jan 16, 2008.
  1. j hansen
    j hansen
    Hey,,,,,,I made the local newspaper as a welder/smith,,me on the left pic with the mag welder.
    chevy57dude, whtbaron, brEad and 6 others like this.
  2. brading
    brading
    j hansen Curious to know what you made this tool up for.
    seb fontana, saltflats and Sharpone like this.
  3. j hansen
    j hansen
  4. brading
    brading
    j hansen Thank you for the reply.
    jeepsterhemi likes this.
  5. 29A-V8
    29A-V8
    from wyoming
    good one, thats funny ****!!!!!!
    j hansen and Sharpone like this.
  6. 29A-V8
    29A-V8
    from wyoming
    maybe turn the heat down a notch or two on the glue gun.
  7. 29A-V8
    29A-V8
    from wyoming
    Im by lingle in Wyoming ( lingle wy is a small town fairly close to where I live, didnt know if anyone would catch that so thought Id explain) but that dosent mean I speak anything other than *******ized english. would really enjoy reading about you in the paper but I dont sprekenze sweed. :(;):cool:
    vtx1800, Sharpone and j hansen like this.
  8. 29A-V8
    29A-V8
    from wyoming
    Hey hope that made cents to someone besides me and Im not sure about that either. ;):cool:
    j hansen, Sharpone and Glenn S like this.
  9. Sharpone
    Sharpone
    I know where Lingle is but I can’t read the paper either other than Jan Hansen I don’t know any of the words.
    Cool Newspaper pictures however. So some of it made sense . Maybe
    Dan
    29A-V8 and j hansen like this.
  10. j hansen
    j hansen
    It`s only say,,
    brEad, leon bee, vtx1800 and 2 others like this.
  11. 29A-V8
    29A-V8
    from wyoming
    Short and sweet thank you Jan.
  12. j hansen
    j hansen
    From the Interweb,,,,,,,
  13. j hansen
    j hansen
    More from Iweb
    jet996, Sharpone, whtbaron and 8 others like this.
  14. seabeecmc
    seabeecmc
    It's not rocket surgery. I needed to drill some 1/4" holes in a floor pan. I was concerned in that there was an area just below where I needed the holes that I didn't want to damage.
    I grabbed a piece of 5/16" fuel line with an inverted flare end. Having a 1/4" ID I cut the tube to length, placed drill bit in, squeezed slightly drill.jpg in vice so it wouldn't slip out and drilled my holes without fear of damaging the surface below. Ron
    Bugguts, chevy57dude, jet996 and 42 others like this.
  15. atch
    atch
    Here are a couple I came across recently and snapped pix.
    This is a tool that I made almost 20 years ago to screw in the parking brake adjustment on a car with rear disk brakes. It's pretty rusty now 'cause it's been sitting in a drawer attracting humidity all these years. It got used once. I know I ought to throw it in the steel recycling barrel and get rid of it; "but what if I need it again???"
    This is a wrench that I made so long ago that I can't remember what I made it for. That handle shaft is 1/2" x 1/2" square tube so it's obviously for something about 1" across the flats. And for something that I couldn't get a normal wrench on due to it being a long ways "down." Please don't dis on the welding. I like to think that I'm a somewhat better welder now. b-t-w; it looks like my trailer fender is ready for a repaint, but it ain't broke so why fix it? This ain't no Pebble Beach trailer. 20250604_174747.jpg
    Boneyard51, Sharpone, vtx1800 and 8 others like this.
  16. j hansen
    j hansen
    From the web,,,a little scetchy
  17. 69fury
    69fury
    from Topeka
    I feel quite uneducated. For a great part of my life, I've seen ring rollers for sale in all the tool stores, in all the shop articles- they're everywhere.
    Evidently there is an entire world of people that need to make metal hulahoops of varying sizes for dozens and dozens of reasons, but aside from circling up rebar when pouring concrete columns, I can't for the life of me understand why so many people of multiple industries require them.
    What am I missing? Is it just super handy for making arcs for fabricating? Clue me in, please?
    -rick
    Sharpone likes this.
  18. j hansen
    j hansen
    Think I only made 1 hoop,,,,,,mostly bends.I have nothing to do with this car! Just an example.
    Sharpone, saltflats and jeepsterhemi like this.
  19. 20250618_200254.jpg My toys. I love them. Last thing I made was some off topic car's gauge surrounds.
  20. patsurf
    patsurf
    def not home made equipt.- that old beauty!!
  21. mohr hp
    mohr hp
    from Georgia
    You made that lathe at home? Are you God?
    Sharpone, SS327, seabeecmc and 4 others like this.
  22. b-body-bob
    b-body-bob
    I had to replace the adjusters in a set of Mopar 273 mechanical rockers with a set that uses lock nuts. So I had to spot face the rockers.
    I setup a bolt on the drill press, then mounted the rockers on that through the adjuster hole/threads.
    I put the drill press in a cut up box to cut down on the mess.
    I stuck an arbor for a Rol-Loc disc in the drill press, then adjusted things so it hit the right place on the rocker.
    It's as flat as it needs to be.
  23. Dave G in Gansevoort
    from Upstate NY
    Now THAT is the KISS Principle defined
  24.
  25. 16" swing, also a bridgeport.
  26. Cleaning lathe now for paint
  27. seabeecmc
    seabeecmc
    More not rocket surgery. Early Ford master cylinder under floorboards with limited room to tighten or loosen cap. From short rack I found a 1 1/4" X 1/8" wall square tube. 1" square ID fits cap perfectly. Ron brk2.jpg brk1.jpg brk3.jpg brk4.jpg brk5.jpg
    X-cpe, Sharpone, fauj and 21 others like this.
  28. seabeecmc
    seabeecmc
    My 1946 Ford had an EIS brand master cylinder. After I rebuilt it I needed a way to hook up a pressure bleeder. The aluminum cap was not easy to fabricate.
    I recently purchased a replacement master cylinder for another project and the pressure bleeder adaptation couldn't have been easier. A trip to NAPA provided me with a 3/8 inverted flare plug. I drilled and tapped the plug for 1/4 NPT. Voila, I had a pressure bleeder hook up. Ron mc1.jpg mc2.jpg mc3.jpg mc4.jpg mc6.jpg mc8.jpg mc9.jpg
    LAROKE, loudbang, X-cpe and 5 others like this.
  29. Ron Brown
    Ron Brown
    GuyW, fauj, jeepsterhemi and 4 others like this.
  30. lostone
    lostone
    from kansas
    Me too !! I love it ! 1945 or 46' Logan 200. If it's dark blue I've totally rebuilt that part of it. The apron was totally torn apart, new bushings installed and hand reamed to fit, I even drilled holes where the bushings are and installed those small flush fit grease ******s. A few little mods here and there.
    It's all change gears with the slowest feed rate of .0046 but after finding some other gears that fit I can get it down to .0018 (gun barrels).
    One really cool thing is on the apron is a super rare auto feed kick off. This was an option that you bought and had to install yourself. Downside is I don't have the piece that looks like a starfish that mounts to the bed, upside is I have the all of the apron side and the most complex part. How rare ? Only seen another one in the old catalog and all the guys on the logan forum had no idea what it was but just one gent and he only knew because he owned just the starfish piece. And of course he wanted to buy mine, I wanted to buy his and neither one of us would part with our halves. So between him and myself it's the only pieces I know of and the only way to make a complete set. Never found any pieces for either side and nether has he...
    Bandit Billy, jet996, WhyW8 and 5 others like this.
