Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Sharpone
    Sharpone
    Two thumbs up, I’d give ya more but I only have two :)
  2. DDDenny
  3. That is great! I’ll use that in the future!
  4. Thanks for the tip. I, too, am referencing the Painless instructions as well as deciphering the Rebel instructions. I already have to re-do one of the basic wires coming from the fuse box. I'll get there eventually.
    Sharpone and swade41 like this.
  5. Oneball
    Oneball
    Made up a one piece line from the pump to the carb on the Merc the rubber pipe came loose earlier in the year and peed fuel everywhere and I really don’t like the idea of that.
  6. We are picking up a 1951 Ford Custom for Little Truckdoctor today. Pictures to follow.
  7. IMG_9168.jpeg Here are the promised pictures of Little(?) Truckdoctor’s 1951 Ford Custom. Ok, just one, we will get more tomorrow.
    Tim, Turnipseed, Tickety Boo and 18 others like this.
  8. 51504bat
    51504bat
    After 5 months of no progress I finally sprung my Ranch Wagon from body shop hell. The guy did a good job of replacing the floors and repairing lots of rust and started on prepping the body. Then all work stopped and periods of radio silence. Pretty bummed at this point. Not sure if another body guy will want to pick up the project. I'll be 74 in April. Maybe time to either sell it as a stalled project or part it out. IMG_20250329_125452708.jpg IMG_20250329_125506883.jpg
  9. BJR
    BJR
    Put my newly rebuilt tach and speedometer back in my 56
    T-Bird. No pictures as it's not that exciting.
  10. alanp561
    alanp561
    With a lot of help from my gofer, Alyn, I replaced the 3-piece (leaking at two of the joints and installed by someone else) gas line with a one-piece length of NiCopp. Measured that ****er quite a few times before I made the two bends from the frame to the fuel filter. This was probably the easiest thing we've done on this car. May not seem exciting to anyone else, but to us it means that we can go down the road with it without the car catching on fire.
  11. chevy57dude
    chevy57dude
    @Truckdoctor Andy - The shoebox Ford looks pretty solid. Tell us about it!
    It's a 1951, the last year of the 3, flathead?
    porkshop, High test 63, enloe and 5 others like this.
  12. rod1
    rod1
    Don't give up now! You're on the home stretch. Find the video of Gene Winfield saying :Don't Give Up !
    Tim, charleyw, porkshop and 7 others like this.
  13. We picked it up in Memphis yesterday, I traded a Harley for it. It is pretty solid, it does have some filler in it, but the trunk floor is good, and the rear floor looks good. It’s a Flathead V8 with a 3 on the tree. The video on Marketplace shows it running, although I don’t believe on all 8 cylinders. Chandler can’t wait to hear it run, but before we spend any money on the motor, a compression test will be in order. Our plan is to make it go, make it stop and drive it, thank you Anthony! @anthony myrick Chandler’s cousin is pushing for a 302 Ford and 303 3 speed because he’s a Ford guy and he has those pieces to sell. I’m sure it will be a Small Block Chevrolet because we love them and Chandler has a 350 he just dis***embled. Shoebox Central also has the mount kit too. When we picked it up, it was being stored at a shop in Memphis called Steel Rose Metal Company. Mike, the owner took us on a tour of his shop, neat place, they do cool work.
  14. 51504bat
    51504bat
    Thanks for the encouragement. Not going to make a hasty decision. Need time to reflect on the situation before deciding what to do.
  15. Lloyd's paint & glass
    Flat black, flames, lake pipes, wide whites, spider caps, diamond pleats... I can see it now :cool:
  16. blue 49
    blue 49
    from Iowa
    My older brother and I on the tailgate of our Grandparents red and white Ranch Wagon.
    Gary
    51504bat, Oneball, 61Cruiser and 3 others like this.
  17. guthriesmith
    guthriesmith
    Sure hope you can get someone to finish it.
    51504bat, Sharpone and saltflats like this.
  18. 51504bat
    51504bat
    So do I. Was complete and running before the journey to body shop hell. All the chrome is redone, stainless polished and straightened, rebuilt 302/AOD combo, Maverick 8 inch with new 350's, front discs, 12 volt rewire, knee knocker a/c, etc. Hoping I can get it down the final stretch but if not it'll make a good project for someone.
  19. jeepster
    jeepster
    from wisconsin
    Replacing power window motor.
  20. Sharpone
    Sharpone
    Mmmm tasty, do you oyster cracker or just plain saltines?
    Dan
    alanp561, anthony myrick and enloe like this.
  21. deathrowdave
    deathrowdave
    from NKy
    Old crock pot is my go to for carb work .
    Sharpone, anthony myrick and enloe like this.
  22. deathrowdave
    deathrowdave
    from NKy
    Playing with the TIG welder . After 33 years in my care , finally the original seat , seat belts , and finished rumble seat area . IMG_2572.jpeg IMG_2573.jpeg IMG_2563.png
    rod1, jazz1, charleyw and 12 others like this.
  23. F-head
    F-head
  24. brading
    brading
    porkshop, Sharpone and enloe like this.
  25. F-head
    F-head
  26. vtwhead
    vtwhead
    got lucky today! found a '66 283 bored 30 over with power pac heads. Been in a dry garage for over ten years. story goes that the PO had it rebuilt and then was in an accident, so he pulled the engine to use another day which never happened.
  27. Robdski
    Robdski
    I was able to get some epoxy primer on some front end parts today.
  28. pila38
    pila38
    Finally made this happen:
    Tim, 4 pedals, Sharpone and 14 others like this.
