Projects Faux-Magnesium
Discussion in 'Traditional Hot Rods' started by finalxstage, Mar 29, 2025.
  1. finalxstage
    finalxstage
    from Joliet, IL
    IMG_1460.jpeg IMG_1401.jpeg IMG_1454.jpeg IMG_1455.jpeg IMG_1457.jpeg IMG_1452.jpeg IMG_1450.jpeg IMG_1462.jpeg IMG_1448.jpeg IMG_1449.jpeg IMG_1446.jpeg IMG_1447.jpeg IMG_1451.jpeg IMG_1453.jpeg IMG_1456.jpeg
    Long-time listener, first-time poster, and unsure if I’m even doing this right.
    We all love mag wheels, but I could never afford them. So I tried my own version of some faux-mags and thought I’d share my method incase anyone else wanted to give it a try.
    -Start with nice aluminum wheels that you're supposed to leave alone.
    -Sand off the machined surface so it's all smooth.
    -Sandblast with a course media.
    -Spray wheel with Dry Graphite or Dry Moly. I used CRC Moly Lube.
    -Let dry overnight.
    -Lightly wiped wheels off with a towel to get any excess buildup. Not sure if it's needed but that's what I did.
    -Unload the Dishwasher and set all that stuff in the sink for a sec.
    -Toss a wheel in the dishwasher on high and a Cascade Platinum dish pod. The heat kind of baked it in and made the nice goldish-rainbow hue from the heat like magnesium has.
    -Apologize to your wife for the previous step.
    -Lightly mist the wheel with salt water outside since sodium chloride reacts with graphite and helps oxidize, while the wheel is facing up.
    -Let it dry. I let it sit overnight.
    -Keep them ****ers outside all night, and let it rain and hail on them the next day, and then heat in the sun later in the day. Shoutout mommy nature.
    -Profit.
    Yes I’m aware I should’ve cut the lip off, but I decided not to. I don’t know anyone with a lathe to make it quick.
    Enjoy, and please don’t send your wife to yell at me for tossing wheels in the dishwasher!
  2. finalxstage
    finalxstage
    from Joliet, IL
    Probably could fuzzy up some more if I leave them outside for a week out of rain but in the moisture. The second photo where it’s cleaner is the same method but stopping after the dishwasher. So minus the sal****er spray and leaving outside.
  3. finalxstage
    finalxstage
    from Joliet, IL
    And here is what they’re going on. Need to redo the rear slots with the same method, these were just sandblasted, dry graphite, and sealed with ATF.
  4. ironandsteele
    ironandsteele
    Those look great!
    ironandsteele.com​
    Deuces, mad mikey, duecesteve and 2 others like this.
  5. DDDenny
    Wow!!!
    That's about the best "mag look" I've ever seen pulled off with any realism.
  6. noboD
    noboD
  7. finalxstage
    finalxstage
    from Joliet, IL
    I appreciate it! Fun combining arts & crafts with science and Mother Nature just to make my hotrod look trashier in a good way.
  8. DDDenny
    The reason I notice these threads is I've had it in my mind to do the same thing to the wheels on my roadster for a long time, rarely do I see them turn out looking like real magnesium.
    These are P.S. Engineering welded two piece aluminum wheels, they normally come with polished hoops, I had them blast the hoops after they were welded to match the centers.
    I'm reasonably happy with the overall outcome but they don't look real like yours do.
    Deuces, mad mikey, bchctybob and 4 others like this.
  9. finalxstage
    finalxstage
    from Joliet, IL
    I’m new to all this so wasn’t sure if I even posted it in the right spot for people to notice it or find it for their own use. Those still look pretty good though! Going to try my method again on some slotmags soon and see if I can achieve the same results.
    vtx1800, Deuces, winduptoy and 5 others like this.
  10. Just Gary
    Just Gary
    Awesome 1st post.
    We need more homegrown tech guys like you!:cool:
    lo c dan, Deuces, winduptoy and 5 others like this.
  11. finalxstage
    finalxstage
    from Joliet, IL
    Thanks! Working with what I’ve got!!
  12. skooch
    skooch
    lol usually first time posters want to know why their brakes won’t work after replacing a bunch of parts. Killer post.
  13. X-cpe
    X-cpe
    Maybe someone with access to a brake lathe.
  14. finalxstage
    finalxstage
    from Joliet, IL
    Good idea!
  15. Motorwrxs
    Motorwrxs
    Wheels looked great…gonna look killer on your truck.
  16. DDDenny
    Oh man!
    I would have been all over that just to be part of that project (not that there is a thing wrong with the outcome), I bought a brand new 18x80 lathe in the 80's, 10 hp, had a removeable gap section under the chuck that would swing 22 inches, sold it after hurting my shoulder at work, had numerous shoulder, carpal tunnel /hand and neck surgeries over the years.
  17. duecesteve
    duecesteve
    Toms Dogs, Nostrebor, GuyW and 25 others like this.
  18. guthriesmith
    guthriesmith
  19. deathrowdave
    deathrowdave
    from NKy
    A+ . I ran mag wheels for years . I went the other way , trying to keep them polished , what a nut case I was
  20. lilCowboy
    lilCowboy
  21. panhead_pete
    panhead_pete
    Interesting, thanks. I have OG Halibrands on my coupe but want to run some Rocket wheels that are new, was hoping to get a similar finish. This looks like a viable option to do that.
    Deuces, winduptoy, mad mikey and 4 others like this.
  22. krylon32
    krylon32
    from Nebraska
    Go to hopup.com an scroll down to Dennis Saum out takes. He took some common aluminum wheels and sprayed them with I believe he said roof gutter paint. Look very vintage and last I knew he'd crossed the 50K mile mark and they still look great.
  23. panhead_pete
    panhead_pete
    Thanks Gary was able to find pics of his coupe.
    finalxstage likes this.
  24. finalxstage
    finalxstage
    from Joliet, IL
    I had posted this method on a Facebook Group called “MAGLUST Support Group,” and a user by the name of Fabian Dewar replied with one of his methods that seems decent as well. Thought I’d share it.
    “Sand blasting. then I've applied a kind of graphite paste or a paste for charcoal stove 24hrs then I removed with a brake cleaner and I've put the wheels under wet salt for 3 days I do the same for my other wheels”
    The sal****er on top of a graphite treatment seems to really help since it causes a chemical reaction, just as I’d done with my method too.
    Toms Dogs, LSGUN, Deuces and 5 others like this.
  25. BigJoeArt
    BigJoeArt
    Nice stuff! Does the baking help the coating hold up any better?
    Mine is starting to look pretty legit after 3000ish miles, but it can still be pretty fragile to the touch.
    Obviously the fronts are real, but the backs are the same wheels you started with.
  26. finalxstage
    finalxstage
    from Joliet, IL
    Hey Wag-Tag Rod Shop! From what I can tell it’s helped it hold together better, as well as the coating of “crustiness” that’s developed over the top, but still probably isn’t 100% cured in if scrubbed hard enough. But it just seems to blend differently if it is wiped/handled hard. Guess that’s just the name-of-the-game for me to have just the appearance and not the cost of mags haha.
    BigJoeArt and 427 sleeper like this.
  27. DDDenny
    Damnit!
    By the way, in the late 70's/early 80's, can't say for sure, I was at Portland International Raceway for either a vintage race or a kart race, was walking through the pits and in the distance I spot a (IIRC dark green) Cobra, as in (not a Mustang), it had big wheel opening flares so I knew it was a 427, it also had black wheels (I thought) and couldn't get there fast enough.
    Yep, it had Halibrands, raw, "real" magnesium Halibrands, like the car, they looked like they had never been touched cept by the hand of God, that, I was sure of.
    Funny how some things can have a life altering effect on a person!
    Just Gary likes this.
  28. A Boner
    A Boner
    An alternative method: (the Magnesium look rules!)
    My first attempt, using Vanish Oxi Action Powder on a repro aluminum Peerless tether car.
    I would suggest that the aluminum be thoroughly sandblasted, so the surface is more uniform…something I didn’t do. Mix the powder in hot water, then submerge the parts. Don’t let the parts touch other parts or even the side of the plastic bucket, or whatever you are using. My son did some “sandblasted” aluminum (off topic) valve covers, they turned out really good. He submerged them for 2 hours. My attempt was with the once used, (not so hot) treated water, and I left them submerged over night. We rinsed them with soapy water (Dawn) and applied Gibbs oil to stop the oxidation process. I didn’t treat the hood.
  29. HOTRODPRIMER
    HOTRODPRIMER
    I guess I could pull this off, my neighbors on vacation and I'm feeding his dog while he's gone and they do have a dishwasher! :D HRP
