Projects The Flathead Flathead
Discussion in 'Traditional Hot Rods' started by Jeff34, Aug 30, 2021.
  1. Jeff34
    Jeff34
    Thanks @ZerroHalfcup I’m not on FB so thanks for the number. I’ll give them a call
  2. I'd highly suggest going to Red's versus the repop Fentons. Also, don't try to "slip fit" your exhaust extensions to the ends of the headers - weld in 2-bolt flanges on the ends of the headers (that way you can unbolt the system and you'll have a gasket with no leaks).
    richard noble and Algoma56 like this.
  3. Jeff34
    Jeff34
  4. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Can't wait to see the ch***is back from sandblasting!
  5. Jeff34
    Jeff34
    yeah, plans change, right? I’m doing it all myself. Got it ready for paint. Rust encapsulator and then satin black paint
    J.Ukrop likes this.
  6. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Awh yeah! I was super happy with how the Rust Encapsulator turned out on mine.
    Jeff34 likes this.
  7. Jeff34
    Jeff34
    Tim, Okie Pete, brEad and 2 others like this.
  8. Jeff34
    Jeff34
    Got most of the ch***is put back together today. I need to take a week hiatus for some house projects, so I'll be out of this for a bit. Wanted to get this much done. Pics aren't in order...sorry. frame 0.jpg frame 1.jpg frame 2.jpg frame 3.jpg frame 4.jpg frame 5.jpg frame 6.jpg frame 7.jpg frame 8.jpg frame 9.jpg
    Okie Pete, brEad, Tim and 2 others like this.
  9. AmishMike
    AmishMike
    Looks like large heim joint for Henry designed front suspension. What size is heim?
  10. Jeff34
    Jeff34
    Front is stock Henry. Rear has a Rock Johnny joint for the radius rods. Does that help?
  11. AmishMike
    AmishMike
    Johnny joint to some, heim to others, what size? Tks
  12. Jeff34
    Jeff34
    I'll have to double check, but I believe the ID of the sleeve is 1/2", and the threaded part is 3/4"
    AmishMike likes this.
  13. A Johnny Joint is a good choice for your front mount for the rear radius rods . . . much better than a typical heim joint. Also, most of them can be rebuilt with new urethane inner bushings.
    Outback, boxerdog and Tim like this.
  14. AmishMike
    AmishMike
    Johnny joint vs typical heim joint. I thought different name for same thing. Maybe need explain “typical”. Maybe I missing something. Help
  15. Jeff34
    Jeff34
    My understanding is that a Johnny Joint is a metal spherical ball inside a rubber mount, while a Heim Joint is metal on metal. Please smack me if I’m wrong. Here are some pictures of mine with a ruler for size reference. It is a 1/2” they hole. 3/4” thread.
  16. AmishMike
    AmishMike
    Some heim ball has plastic or other between other metal. Do not know about rubber. Tks for size
  17. Jeff34
    Jeff34
    IMG_4626.jpeg IMG_4627.jpeg IMG_4629.jpeg IMG_4630.jpeg IMG_4631.jpeg Flipped the backing plates ad mounted upside down for brake line clearance. Kept the crescent pieces Not sure if I’ll weld them into the gap or not. Built a nice little jig with a drill bushing I had to cut the crescent. Re***embled the backing plates and put them back on the rear end.
    Okie Pete and ZerroHalfcup like this.
  18. Jeff34
    Jeff34
    IMG_4634.jpeg Backing plates installed
    Outback, Okie Pete, brEad and 4 others like this.
  19. Jeff34
    Jeff34
    Got the plumbing finished on the rear. Need to do my kingpins in the front before I install the backing plates. More to come. IMG_4690.jpeg IMG_4691.jpeg IMG_4692.jpeg IMG_4693.jpeg IMG_4694.jpeg
  20. atch
    atch
    Nice work man.
  21. Jeff34
    Jeff34
  22. Jeff34
    Jeff34
    Because I flipped the backing plates, there’s only one screw hole at the outer edge of the wheel cylinder. I have the drum retention brackets, but with one hole I can’t mount them there.
    Should I just forget about them?
    I could mount them 45 degrees back from vertical on a flat spot on the backing plate if we think I really need them
  23. Jeff34
    Jeff34
    IMG_4714.jpeg IMG_4715.jpeg Quick update on the roadster. I replaced the king pins. Thanks to Norm Jr. at Norm’s for replacing the bushings and honing them to size. Also got the backing plates and grease shields back on. I’ll have to upload the pictures later
  24. Jeff34
    Jeff34
  25. Jeff34
    Jeff34
    More pictures of the front spindles and backing plates...
    59sedandelivery, brEad, Tim and 3 others like this.
  26. LCGarage
    LCGarage
    They also have a pretty fast little dirt track in Madras;
    Jeff34 likes this.
  27. Jeff34
    Jeff34
    First run on the rebuilt engine. He wants to run it for a couple more hours to be sure he’s happy with it. IMG_4729.jpeg
  28. Jeff34
    Jeff34
  29. Jeff34
    Jeff34
  30. Jeff34
    Jeff34
    Picked up a rear window for the top at the swap meet today. Beveled gl***. IMG_4781.jpeg
    brEad and ZerroHalfcup like this.
