Technical Full floating axle on a hotrod ?
Discussion in 'Traditional Hot Rods' started by mercjoe, Mar 30, 2025.
  1. mercjoe
    mercjoe
    Hello eveyone.
    So, I have a full floating freshly built axle I scored a while ago.
    It is not even close to being a traditional axle from the start since its a Dana.
    But how off would it be to install it on my car besides the brand ?
    I mean, has anyone ever seen any hotrods coupes or roadsters with full floating axles ?
    Thanks for any help
  2. 1biggun
    1biggun
    Some were in the model A thread there is car with wide 5 wheels and what a appears to be a floater rear.
    I have a 57 Olds type rearend here that's got floating axles .
    I suspect was in a circle track car.
    I have seen some old drag cars that had a floater .
    dana barlow, mercjoe and seb fontana like this.
  3. Dana rears been around a long time. My 51 still has its Dana 44.
    Round track guys been running full float since about a week after full floats hit the junk yard
  4. gimpyshotrods
    gimpyshotrods
    My Model A has a full-float rear axle.
    427 sleeper, mercjoe and alanp561 like this.
  5. gimpyshotrods
    gimpyshotrods
    If you think about how the rear hubs mount on a Ford banjo axle....
    427 sleeper likes this.
  6. mercjoe
    mercjoe
    Great to know. Mine is a 44 as well
    anthony myrick likes this.
  7. gimpyshotrods
    gimpyshotrods
    A full-float Dana 44?
    What's that out of?
  8. mercjoe
    mercjoe
    Dana44 has been used on many cars here in the 70s, but none were factory full-float. It was converted at some point
  9. gimpyshotrods
    gimpyshotrods
    It's a great axle. Well supported to this day in the aftermarket.
    I ran an off-highway vehicle Dana 44HD (2.75" OD, 1/2" wall tubes) in the front of an offroad truck for over a decade. Zero issues.
  10. mercjoe
    mercjoe
    Yeah, they are good. Ive just never seen one on a hotrod. Just wondering if mine is going to be the only one, even rarer being full-float :)
  11. 1952henry
    1952henry
    I would like to see pictures of that, please. I think there was, or is, a kit for lock out hubs on the rear axle for Willys Jeeps, which basically made the axle a full-floater. The later CJ3As had Dana 44s.
  12. 1biggun
    1biggun
    .00000000000000000000000000000000FB_IMG_1742571657629.jpg The A I saw in the thread today .
    I copied it to my computer because it had a Hemi in a channeled A like I want to do ( 31 PU ) and it had a really cool industrial / g***er look to it with the floating rear end .
    I have seen 8 lug magnesium rims before that made me think it was on a floater in a dragster or other drag car
  13. 1biggun
    1biggun
    I know there was a kit that let you looked like lock out hubs that were for the rear so guys could flat tow there old Willys jeeps . A neighbor had them on his years ago
    mercjoe likes this.
  14. ididntdoit1960
    ididntdoit1960
    from Western MA
    I had a Prefect drag car with a full float d60 out of an old dump truck - guys used them because they were easy to narrow - they cut the flange off the axle shaft, bored it out and welded it back together at the length they needed - couldn't do this with a semi float
    mercjoe likes this.
  15. jimmy six
    jimmy six
    After having one in a dirt race car I would put one in any car I was building.
    mercjoe likes this.
  16. mercjoe
    mercjoe
    Awesome. Thanks for that one.
    And here is mine
    dwollam, Phillips and 1952henry like this.
  17. mohr hp
    mohr hp
    from Georgia
    IMG_4288.png Gr***o and Mills Willys drag car from Nebraska. It had a full floater truck axle until it got pro streeted in the late 80's.
    mercjoe likes this.
  18. Well, I'd say "kind of" . . . when you break an axle in our early Ford rear ends, the hub/wheel does "float" . . . right off of the rear end! LOL.
    On what I'd call a true full-floater, you can break an axle and the hub stays where it is supposed to. ;)
  19. dirt car
    dirt car
    from nebraska
    I've a 42 Ford 3/4 ton rear in my avatar, also added 37 tube front axle with skeleton back plates, 2-1/2 " wide 5 safety hubs & finned drums.
    mercjoe and dwollam like this.
  20. DDDenny
    Fairly common in the 60's.
    Toms Dogs and mercjoe like this.
  21. gimpyshotrods
    gimpyshotrods
    Nope.
    My Model A has a Winters quick change, with Grand Nation snouts, and hubs.
