Technical Model B transmission identification help needed
Discussion in 'The Hokey Ass Message Board' started by Beau, Apr 29, 2017.
  1. Beau
    Beau
    I'm trying to figure out what I have here. It was sold as a '32 truck transmission. I'm ***uming that's incorrect. I can't find any numbers besides the 3.
    kidcampbell71 likes this.
  2. Will Kimble
    Will Kimble
    Looks like a '32 Model B trans to me. Serial # would be on the upper flywheel housing, not the case.
    Beau likes this.
  3. I agree with Will. It looks like a Model B transmission used in p***enger cars and light commercials (pickup trucks). It is definitely not the "big" (Model BB) truck transmission (which is probably good). The '33-'34 4 cylinder transmission is the same except for the rear mount is different and the shifting tower will not have the place to attach the emergency brake.
    Charlie Stephens
  4. Beau
    Beau
    Thanks. The brake handle forged into the cover is what threw me off.
  5. Southfork
    Southfork
    That is the first one of those I have seen (in pictures, or otherwise). Probably they are not very common. If you don't use it in a build, I would be interested.
    Beau likes this.
  6. Beau
    Beau
    I plan to use it. I'll have to clean the shifter housing and see if I can get a number.
  7. If you will find any number it will probably be a casting number that won't tell you much. The two threaded bosses on the side of the shifter housing were '32 only. If you change to later gears you may need to change the housing. Gears will fit all the way to '39 with the '39 and up being the best. The expert on transmissions is Mac VanPelt and he posts on HAMB. His company address is
    http://www.vanpeltsales.com/FH_web/flathead_home.htm
    Charlie Stephens
    Beau and The37Kid like this.
  8. jeepsterhemi
    jeepsterhemi
    From Rod Action Magazine....fall 1975....
    Stovebolt, jebbesen and UNSHINED 2 like this.
  9. Where on the flywheel housing?
  10. studebakerjoe
    studebakerjoe
    There should be a cast in pad on top near the opening for the starter with the numbers stamped into it.
  11. brjnelson
    brjnelson
    Beau
    I agree with all the info, I had empty case like that years ago from my Dads 34 pickup.
    Now you need a wide shift fork and some late heliacal gears
    jeepsterhemi likes this.
  12. brjnelson
    brjnelson
    and you will need the B top half of the flywheel house.
    Have you climbed around in the school bus at french lake? there could be something still under all the A stuff.
  13. brjnelson
    brjnelson
    Photos taken last November
