Hot Rods Split front bones to inner chassis
Discussion in 'The Hokey Ass Message Board' started by panhead_pete, Mar 30, 2025.
  1. panhead_pete
    panhead_pete
    For 1934 Ford Coupe
    Can someone please school me in the correct way to mount the tie rod end of a split front bones inward from the outer surface of the ch***is rail? Closer to the center.
    Besides caster and oil pan clearance etc what if anything else do I need to consider?
    If someone has done that can you send through some pics?
    Thanks
  2. 1946caddy
    1946caddy
    from washington
    panhead_pete and chryslerfan55 like this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    When I built my '32 pickup I split the rails and moved them out to the side of the frame rails, I used a set of aftermarket spring perches, I installed bungs and tie rod ends then mounted them on the mounts I made to attach to the frame. HRP
    Blues4U, GordonC and panhead_pete like this.
  4. HOTRODPRIMER
    HOTRODPRIMER
    35 to 40 Ch***is you can use the Ch***is engineering kit and attach the bones and make the frame stronger at the same time. HRP
    Blues4U likes this.
  5. evintho
    evintho
    I ***ume it's for the '34 in your avatar. Here's how I did my '27 roadster. 3/16" steel plate mounted to the outside frame rail. First I determined the proper amount of caster needed, then placed and marked the plate.
    The tie rod ends have a 7* taper so I ordered two of these from Speedway. They'll accomodate the 7* taper.
    https://www.speedwaymotors.com/Roun...NdlyNCCgrp81wOyl2jOHy-T23DyF1JA362QPV_HtUjjdl
    Next I drilled big holes and set the shock mount ****ons inside and welded them in.
    Tacked the mounts and double checked all my alignments and clearances.
    Finally, finish welded and I also welded gussets on the opposite side for strength. Couple of thousand miles so far with no issues.
    Speccie likes this.
  6. 1935ply
    1935ply
    from peyton,co
    IMG_1791.JPG On my 34 pick up I mounted them in, because of fender and running board clearance. But not to far in so the exhaust could go through. There is no specific science for them. On my fender less Model A I mounted them on the outside of the frame, then just make sure you have tire clearance for a sharp turn.
    panhead_pete likes this.
  7. Mr48chev
    That Ch***is engineering INC (not .com) unit keeps the bones at close to the original triangle form. I couldn't find any instructions sheets though.
    Way back in the dark ages when that setup from Ch***is engineering inc showed up in a magazine article the stated theory was and still is that it comes as close to duplicating the motion of the stock wish bones as far as allowing the axle to move up and down as you go down uneven roads = my driveway. Working a bit more like the original setup when you transvers uneven ground like a rather angled driveway entrance. I'd say most guys who run split bones don't much worry about as they seldom drive anywhere where the surface they are driving on is going to cause the split bones to cause a bind. Screenshot (688).png IMG_9681.JPG
  8. panhead_pete
    panhead_pete
    Cheers Fellas have updated my initial post re it being for my 34 coupe. Have seen plenty ways to mount them on the exterior of the ch***is, was thinking more along the lines of what @Mr48chev and @HOTRODPRIMER posted - thanks!
    catdad49 likes this.
  9. Weedburner 40
    Weedburner 40
    wb3.jpg wb3.jpg We make these bolt on wishbone frame mounts that can be bolted to the X-member. These are also available with the bungs and tie rod ends.
  10. @Weedburner 40 , is there a taper in that hole for the tie rod pin? Looks like a easy way to get the bones mounted.
  11. Weedburner 40
    Weedburner 40
    Algoma56, yes, the tab is tapered for the Early Ford tierod end. The taper is from both sides so that the tierod ing can come in from either side.
    Algoma56, catdad49 and panhead_pete like this.
  12. A Boner
    A Boner
    Well, it works on a Model A, with a SBC and a F-1 trans crossmember, and later bones (42-48)…as long as you use a narrowish transmission.
  13. alchemy
    alchemy
    Weedburner’s mounts look nice.
  14. Happydaze
    Happydaze
    Mine, inverted, courtesy of Ionia Hot Rod Shop. Works great. Only downside is that the mounting plate between the crossmember and the ch***is rail makes access to the brake and clutch master cylinders somewhat difficult.
    teach'm, Algoma56, catdad49 and 2 others like this.
