Projects 1946 GMC Bonneville build
Discussion in 'The Hokey Ass Message Board' started by Marcia, Aug 26, 2020.
  1. Marcia
    Marcia
    PXL_20250331_190513387.MP.jpg I have two front bumpers. One is chrome for show, the second will be paint for go. Giving it a skim coat of bondo.
    Frank has to plan where the water pump and all the other plumbing will go. View attachment 6362206 PXL_20250331_200013137.jpg
  2. ronnieroadster
    ronnieroadster
    Looking great if Frank needs some guidance on fitting the water pump and related plumbing I'm sure I could help. ;) On our race car finding space has been one of the interesting challenge's which each time I have been able to accomplish. :D
    Ronnieroadster
  3. Marcia
    Marcia
    Thanks for the offer. We do have plenty of room under the hood.
    chryslerfan55, Stogy and 41 GMC K-18 like this.
  4. rusty valley
    rusty valley
    The truck looks like a winner to me Marcia!
  5. Marcia
    Marcia
    Thanks!
  6. jimmy six
    jimmy six
    I fount it was easier to mount as much as I could on the other side of my stock head GMC’s where there was a little more room. I’ve never used freeze plug holes for cooling lines either with the stock head. Using the stock rear head line to the thermostat housing and feeding the stock front block hole has cooled our 14-1 compression engine just fine. Everything you are doing/constructing looks great!
  7. gas pumper
    gas pumper
    Thanks for the kind words! I'm liking that side there for the water and oil filter. Looks like enough room for -8 lines to #2 and #4 core plugs. I ran a drag race electric motor drive to the stock pump for the Mile and a half Loring runs but thought for the 3 mile SCTA more balanced flow might be a good idea.
    41 GMC K-18 and Stogy like this.
  8. Marcia
    Marcia
    PXL_20250416_182450094.MP.jpg This is the mid plate to adapt 6 cylinder to Chevy V8 ****ter shield.
  9. Marcia
    Marcia
    PXL_20250427_164617093.jpg Preparing the head. 302 GMC.
    2devilles, Toms Dogs, jet996 and 15 others like this.
  10. Hotwyr
    Hotwyr
    Where did the midplate come from? Great looking work on the entire truck.
  11. Marcia
    Marcia
    Frank made it. He's clever like that.
    Thank you.
  12. Marcia
    Marcia
  13. Dave G in Gansevoort
    from Upstate NY
  14. rusty valley
    rusty valley
    Well aint that a ***y lookin thing!
    Stogy, Six Ball and Marcia like this.
  15. Six Ball
    Six Ball
    from Nevada
    Very nice! Like the valve cover hold downs. What distributer is that, a GM HEI ? Do you gave a source for the cap on the oil filler/breather? I lost mine and with all the GMCs sitting around here I don't have another. Looked on eBay till I gave up.
    Stogy, chryslerfan55 and 41 GMC K-18 like this.
  16. Marcia
    Marcia
    The distributor is a Summit copy of a late 6 cylinder Chevy HEMI. Frank modified it to fit.It has Davis Unified Ignition cap rotor coil module.
    The oil filler came on another engine. I don't have another.
  17. Six Ball
    Six Ball
    from Nevada
    Cool, Thanks. That is all the distributor you'll need until you p*** 10,000 rpm. :eek:
    Stogy, Marcia and 41 GMC K-18 like this.
  18. jimmy six
    jimmy six
    Oil filler is standard military even though that’s a civilian block. I see you have the deflector that mounts on the block on the inside. Every thing looks great!
  19. Six Ball
    Six Ball
    from Nevada
    Here's mine before I lost it. It was on the civilian 270 when I pulled it from a '57 pickup. They shouldn't be hard to find.
    Stogy, chryslerfan55, Marcia and 3 others like this.
  20. Marcia
    Marcia
    The final version, maybe. PXL_20250512_224007850.jpg PXL_20250512_223957331.jpg PXL_20250512_223949152.jpg
    Stogy, Toms Dogs, 2devilles and 4 others like this.
  21. AmishMike
    AmishMike
    What cl*** would u run with late model GMC Atlas 6 of 4.2 liter? Fantastic hi horse motor not HAMB friendly
    Stogy and chryslerfan55 like this.
  22. Six Ball likes this.
  23. jimmy six
    jimmy six
    Where they run your “HAMB unfriendly” is not allowed in a vintage engine cl*** (XO Gas Production) it would be against later model trucks (E Gas Production) if it was ever available in a GMC pickup. There is a 10 mph difference between the speed. That 4.2 Atlas can be used in their pickup and would be cl***ified as a Modified at still close 10+ mph difference.
    E is dominated by V8’s for-the most part and anything bigger than 4.276 L would move to D. If it were used as a D in the Modified category there is a 60 mph difference.
  24. Six Ball
    Six Ball
    from Nevada
    That looks good! Getting excited yet?
    Mike, There are several guys on the Inliners International site that run those. There are at least a half dozen of them in our local chapter.
    Stogy, AmishMike, Marcia and 2 others like this.
  25. Marcia
    Marcia
    I can't wait to start it up!
  26. Marcia
    Marcia
    PXL_20250520_164745407.MP.jpg The transmission and drive shaft are in and working.
  27. Marcia
    Marcia
    PXL_20250523_134556988.jpg PXL_20250523_192143020.jpg PXL_20250523_204550066.jpg We ran the motor in yesterday. The Video is on Facebook, the Flying Seven. We'll replace the fuel pressure sensor and the tach. It sounds good. We're very happy!
  28. Toms Dogs
    Toms Dogs
    from NJ
  29. 51504bat
    51504bat
    Might run better by switching to a can of Genessee Cream Ale? Just asking.:cool:
  30. Marcia
    Marcia
    Yep, Frank was drinking that!
