Introducing my Fuel Coupe-styled Tudor
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Sep 18, 2006.
  1. lothiandon1940
    lothiandon1940
    ...Never mind.:rolleyes:..I should look before offering my thoughts.:( 20240603_184720.jpg
    catdad49, mad mikey and Just Gary like this.
  2. bowie
    bowie
    Great job Gary! Very happy for you! Your car is just plain *****N’ !!!
  3. swade41
    swade41
    from Buffalo,NY
    Watch that throttle cable sawing through that aluminum ferrel, might need to extend that upper gas pedal arm so it centers the cable out the hole more.
  4. neilswheels
    neilswheels
    from England
    Fantastic, must be a great feeling, even if there are some teething problems, what an achievement
  5. Just Gary
    Just Gary
    I took a break from driving to install the windshield & back gl***.
    Templates are 1/4" pegboard & plywood s****s.
    My local "Auto Gl*** Express" cut the clear laminated gl***....
    .... then glued their windshield into my powdercoated frame.
    I inadvertently cut the 1-piece side & bottom gasket into 3 pieces when beveling it's corners.
    They're glued in place with 3M black super weatherstrip adhesive and binder clips.
    I attached the frame to the header with the top gasket in place, but that caused the bottom of the frame to rub the cowl paint, so I removed the gasket and everything fits nicely.
    Bratton's hardware.
  6. Tim
    Tim
    from KCMO
    Was just thinking we were due an update! Looks
    Good :)
    Stogy, mad mikey and Just Gary like this.
  7. mad mikey
    mad mikey
    Excellently done Gary, However , I remember the old saying, If Henry Ford would have built boats we would have all drown.:eek:
    :D
    Stogy, catdad49, 05snopro440 and 6 others like this.
  8. mohr hp
    mohr hp
    from Georgia
  9. finalxstage
    finalxstage
    from Joliet, IL
    So rad Gary!!! It’s got “the look!”
  10. BigJoeArt
    BigJoeArt
    Dadgum gary. Thats *****in!
    hot rods in motion beat hot rods parked 1000000%
    cant wait to see it out on the highway racking up miles!
  11. Just Gary
    Just Gary
    Thanks for the kudos, fellas.
    I fixed those first-drive issues:
    1) Removed the pitman arm and centered the tires, steering box & steering wheel. Then reinstalled the pitman arm so it's perpendicular to the drag link (measured with a large metal framing square).
    After that, I rechecked 1/8" toe-in and re***embled everything with new cotter pins.
    Now the steering wheel and tires all turn the same amount in both directions.
    2) Narrowed the gas pedal and moved the brake pedal to the left 1/4"- so they're no longer accidently pressed simultaneously. :eek:
    3) Fine-tuned the brake proportioning valve at 0700 Saturday morning on a nearby empty street.
    Here's how:
    How Does a Proportioning Valve Work? And How Do You Adjust It?
    When setting up a street car for performance driving or converting a cl***ic to disc brakes, it is essential to ...
    Now there's max braking pressure with no rear lockup. :)
    4) Cut, lowered & rewelded the seat bases a bit more. Same steps as back in July '24.
    Oh yeah- I also added turn signal and high-beam indicator lights.
    They're incon****uous but visible to the driver.
    bchctybob, duecesteve, Stogy and 24 others like this.
  12. Tim
    Tim
    from KCMO
    Love seeing that beast outside!
  13. lothiandon1940
    lothiandon1940
  14. mad mikey
    mad mikey
    The hot rod is absolutely stunning Gary.
  15. Just Gary
    Just Gary
    Roy repaired my ***embly scratches...:oops:
    ...then color sanded and buffed everything.:cool:
    bchctybob, duecesteve, Stogy and 31 others like this.
  16. Tim
    Tim
    from KCMO
    **** if that’s not a @Jeff Norwell print I’m a crazy person lol
    Stogy, hrm2k, lothiandon1940 and 3 others like this.
  17. hotrodjack33
    hotrodjack33
    LOL. Looks like Gary just figured out where that damn "shop mouse" just ran to.
  18. flamedabone
    flamedabone
    That is a super good pic.
    -Abone.
  19. lothiandon1940
    lothiandon1940
    .....of a Super Cool car.:)
    Stogy, hrm2k, Horror Business and 6 others like this.
  20. catdad49
    catdad49
    Gary, Thanks for the videos. In the last one, as I watched, I thought about where I had seen the car before. This is what I Saw! IMG_4797.jpg
  21. 19Eddy30
    19Eddy30
    from VA
    Nice Pic Gary ,
    Looks to be @ painter's shop ,
    I was wondering if your driving it,
    Tires still Look New on Back:D
    Stogy, mad mikey, catdad49 and 2 others like this.
  22. Dino 64
    Dino 64
    from Virginia
    Roy did a fantastic job on the touch up. ;)
    Stogy, hrm2k, lothiandon1940 and 2 others like this.
  23. Just Gary
    Just Gary
    Thanks for the motivational feedback, fellas.
    Yes- he did.
    I've also monkeyed with the side gl*** for a few weeks.
    Stogy, hrm2k, Horror Business and 2 others like this.
  24. Just Gary
    Just Gary
    Old stuff.
    New Vintiques anti-rattle strips.
    Fuzzy channels with stock attachment hooks.
    Templates.
    I installed them and cycled the cranks to confirm no binding.
    New clear laminate from "Auto Gl*** Express".
    I'd considered- but rejected- orange Lexan as too "HEY LOOK AT ME" poseur-ish. :rolleyes:
    ***embly sequence of a Tudor's quarter gl***/ channel/ riser/ fuzzy/ inner metal panel combo is a regular rubik's cube.
    The channels and fuzzies got pried wider in a few spots for smoother operation.
    They work ok, but not great.
    I wonder if my angle chop (3.5" in front, 2.5" in back) might've slightly curved the posts & channels?o_O
    Anyway, back in elementary school, my friends and I plastered STP stickers on our banana bikes, lunch boxes, textbook covers (made from Mom's brown paper grocery bags), and everything else.
    https://youtube.com/shorts/OxmsBdlpPsc?si=txLv2-TkvxgBvRFg
    "The Racers Edge" :cool:
  25. Just Gary
    Just Gary
    The plan from the beginning was for a vinyl covered roof.
    I stretched stock Model A "long-grain cobra vinyl" on a s**** lumber frame.
    Then scuffed the roof with #220 :eek:
    The vinyl is attached with 3M-90 high-strength adhesive, one side of the roof at a time.
    My beloved bride lent a hand.
    "Hide-em" covers the edges.
    It's attached with weatherstripping adhesive, plus #6 x 3/4" flathead sheetmetal screws through the front header.....
    .... and #16 x 1" wire nails through the slotted drip rail channel holes on the sides & back.
    Stock drip rail corners didn't match the hide-em's shape, so I welded some tubing that did.
    Voila!
    BTW, here's my Oct. 2011 tech thread showing the '86 Toyota minivan roof installation:
    ’28 Tudor update #6; Steel Roof Covered by Stock Vinyl
  26. Dino 64
    Dino 64
    from Virginia
    Nice job on the roof !! I’m impressed :)
    Stogy, hotrodjack33, hrm2k and 3 others like this.
  27. 19Eddy30
    19Eddy30
    from VA
    Looks Nice Gary ,
    My top material I order from Germeny
    still in box
  28. lothiandon1940
    lothiandon1940
  29. Tim
    Tim
    from KCMO
    Looks fantastic, some good tricks in there as well! Thanks for sharing.
    Stogy, hrm2k, mad mikey and 1 other person like this.
