Technical Holley-edelbrock help
Discussion in 'The Hokey Ass Message Board' started by Nicholas minor, Mar 31, 2025.
  1. Nicholas minor
    Nicholas minor
    So I'm just digging into the car I purchased last yr wich is a 32 roadster don't know much about the engine at all person I bought it from has no idea anything about it wheel and deal type thing trades but anyways my ? Is I have a Holley carb on it now wich I've been told need to be rebuilt and was told to maybe switch to edelbrock for how much I drive the car and less up keep what's everyone thoughts I believe it's a 750 Holley now can anyone confirm I'm gonna attach a pick of the numbers I have found wish I knew more on the engine but I don't and I'm a newbie at this so learning as I go IMG_6796.jpeg
    GlassThamesDoug, Deuces and Sharpone like this.
  2. alumslot
    alumslot
    3310 is a 780 cfm should be a good carb for the street and cruising around. Why would you think it need to be rebuilt if the car runs ok.
  3. Mike VV
    Mike VV
    from SoCal
    deadbeat, Sharpone and mad mikey like this.
  4. 05snopro440
    05snopro440
    What's the engine? SBC? Mild idle?
    GlassThamesDoug and Sharpone like this.
  5. poco
    poco
    from oklahoma
    Keep the holley it is a much better than a edelbrock.
  6. Give us some more details on the engine (model, size, performance parts, etc), transmission, etc.. There is nothing inherently wrong with this carburetor - unless it is completely sized wrong and or worn out. If you were going to have it rebuilt, I recommend that it is sent to somebody who really knows these carbs . . . not your local guy "who says he has done a lot of them". But, who says the carb needs anything?
  7. Montana1
    Montana1
    Edelbrock. Set it and forget it...
  8. Nicholas minor
    Nicholas minor
    So for the engine I'm not sure of what has been done same with the engine all I know is I was told that carb had to be rebuilt or to get a edelbrock do to set and forget less messing with it honestly I thought it had a 600 cfm on it but now but what you guys have said it is a 780 to me seems like I should be getting better throttle response and better power than what I have been in the look for somone that is good in upstate ny meaning Saratoga area I have only pics to go by right now withought taking apart to find out exactly what I have and even then would need some help I know it has a turbo 350 trans with Brodix heads not sure if valve covers where just thrown on or if it more than that IMG_6802.jpeg IMG_6801.jpeg IMG_6800.jpeg
    GlassThamesDoug and Deuces like this.
  9. Nicholas minor
    Nicholas minor
    That's what I have been told
    gimpyshotrods and Montana1 like this.
  10. Nicholas minor
    Nicholas minor
    I know it's a 350 but other than that not sure it idles ok little rough but not bad was just told was leaking the carb that's all I really know just getting into this to be honest gotta start somewhere
  11. Nicholas minor
    Nicholas minor
    Runs rough in my opinion a little and just seems off also that is what I was told when I did bring it to someone to give it a Quick Look over when I first got it
  12. Given that it has Brodix heads, my guess is that the rest of the engine is probably setup for some higher horsepower and hence the pretty-big carb. I have an 830 Holley on my 383 SBC - makes 520 HP with a hydraulic roller cam.
    It probably idles rough because it has a performance cam in it. If somebody is putting those types of heads on a SBC, I'm sure they also put money into a high-performance cam.
    What you really need to do is take it to somebody who really knows performance SBC engines - and not just think a magical "new carb" is going to do something for you. There may be nothing wrong with your setup . . . no way to tell. If it was mine, I'd try to find a performance shop that knows carbs and has a ch***is dyno to do some real tuning with it. My guess is that you have a few $$$ in the car - might as well get it to run as it can.
    How well does it run when you take it on the road?
    Deuces, Packrat, Montana1 and 2 others like this.
  13. Also, it looks like the vacuum line is disconnected from the distributor - is it just lying there and ****ing air or plugged off or what? Normally you would want vacuum advance (***uming the timing is setup correctly).
  14. Does it run pretty well when it is cold and then have issues once it gets hot?
  15. Nicholas minor
    Nicholas minor
    Ya it is not connected I don't see anything laying anywhere that's my thoughts I gotta find somewhere local that does that kind of stuff near me
  16. Nicholas minor
    Nicholas minor
    Ya when it warms up it hesitates a little but not bad
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    what is this vac hose laying there? it should probably be going to the vac advance. it looks like it came from strait manifold vacuum. that will make it hesitate and run rough unhooked like that vacadv.jpeg
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    Toms Dogs, Deuces and Sharpone like this.
  19. joel
    joel
    The rebuild isn't that difficult, if you have patience. This book is a big help. IMG_2845.jpg
    Deuces, Sharpone and Budget36 like this.
  20. Mike_B
    Mike_B
    Some specs for list# 83310-1. This would probably be a good place to start.
    LIST # CFM STOCK JETTING POWER VALVE TYPE
    83310-1 750 (F)72, (R)plate 134-131 6.5 4160
    To confuse things a bit, there is also a list# 3310-1.
    The very first version (without the "8" or the "-1") was used by Chevrolet on the 375hp/396 and was rated at 780cfm.
    Current versions are 750cfm and have a manual choke.
    Deuces likes this.
  21. Nicholas minor
    Nicholas minor
    Ok thanks sorry about that I appreciate it so I know for the next time
    Deuces likes this.
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    what about the unhooked vac hose?
  23. Nicholas minor
    Nicholas minor
    the hose that is hooked up goes down to the transmission looks like the other ports are blocked off
    Deuces likes this.
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    ok, thanks for the better pic... sorry
  25. 427 sleeper
    427 sleeper
    With the car running, spray some carb cleaner around the base of the carb. Might be a vacuum leak caused by a spreadbore intake manifold and squarebore carb mismatch.
  26. indyjps
    indyjps
    Clean up ( bowls jets carb cleaner etc) on Holley is pretty simple. Lot of tune up issues could be leading to running rough.
    Timing and vacuum advance not hooked up would be good places to start.
    Deuces and Nicholas minor like this.
  27. alchemy
    alchemy
    So guys, tell him which port he should hook an advance vacuum hose up to. This might be a $3 fix.
    Deuces, Sharpone and Moriarity like this.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    It depends on if he needs ported vacuum or manifold vacuum. If he wants ported vacuum then hook it to the plugged fitting on the side of the carb just ahead of the choke ***y. Or if he wants manifold vacuum there should be a fitting coming out of the base plate at the front closer to the p***enger side that is coming out at an angle. he can try it both ways to see what works better. couldn't hurt to check the ign timing also
  29. Montana1
    Montana1
    This guy is asking for help. He doesn't know if he needs ported or manifold vacuum... o_O
    Deuces, Sharpone and Butler 32 like this.
  30. Moriarity
    Moriarity
    SUPER MODERATOR
    that is why I said he should try both to see what works better on his car. it is literally 1 minutes worth of work to try it
