Technical Cinch clamps
Discussion in 'The Hokey Ass Message Board' started by johnfin, Mar 31, 2025.
  1. johnfin
    johnfin
    from Florida
    Can these type clamps be loosened up with
    The tool?
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
  3. johnfin
    johnfin
    from Florida
    Can the hose be saved, ie cut the top cinch.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Do you mean cutting the “hose” below where it was crimped?
  5. TCTND
    TCTND
    That's a one use clamp. You can carefully cut it off and if the hose is still good replace it with the same or a different style clamp.
  6. ronzmtrwrx
    ronzmtrwrx
    I have cut them with a good sharp set of side cutters where Johnny gee has marked it without disturbing the hose.
    05snopro440, SS327 and LWEL9226 like this.
  7. Bandit Billy
    Bandit Billy
    you can save the hose but those clamps get cut off. My daughter VW bus' fuel line had a bout 20 of them. Not anymore.
  8. 57Fury440
    57Fury440
    I have cut a few of those off over the years. What is the benefit of using them?
  9. tubman
    tubman
    Lower manufacturing costs.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The clamp in the photo looks residential and RV plumbing as in PEX vs an automotive unit.
  11. Bandit Billy
    Bandit Billy
    German engineering needs no benefit or motive. I had to replace the starter on that VW bus, one of the bolts went through the bell housing and had a nut on the other side that my daughter had to climb into the engine bay and hold while I laid on the ground with the ratchet. Reason? What's German for laughter?
    Toms Dogs, Just Gary and SS327 like this.
  12. VI Lonewolf
    VI Lonewolf
    You can also remove them by inserting a flat blade screwdriver into the open area just to the right of the red line and twisting. They come off in seconds. I like them because to my old eyes they look cleaner than a gear clamp and don't cut into the hose. Right name is oetiker.
  13. johnfin
    johnfin
    from Florida
    lonewolf hit it on the head. They look cleaner. If they came in black it would be even better. Concealed to a point.
  14. Germans make things complicated because they can. :eek::D
    Bandit Billy likes this.
  15. johnfin
    johnfin
    from Florida
    Summit racing sells them. Not just for german junk or RVs.
  16. 05snopro440
    05snopro440
    Not only do they look cleaner, but from an installation perspective in m*** production they're a lot simpler. Crimp the clamp, sides contact, and it's secure. For those of us installing them all by hand and worried about removal and maintenance, there are other options.
    Algoma56 likes this.
