Technical ***April 2025 Banger Meet Thread - April Showers Bring May Bangers***
Discussion in 'Traditional Hot Rods' started by Jiminy, Apr 1, 2025.
  1. Jiminy
    Jiminy
    Link to previous month: March 2025 Banger Meet
    Coming Events: (PM Jiminy with additions/corrections)
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there may be more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    https://eraspeed.com/
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
  2. denis4x4
    denis4x4
    from Colorado
    I'm in
    winduptoy likes this.
  3. 62pan
    62pan
    Still here
  4. wuga
    wuga
    Checking in!
    Warren
  5. Dan from Oakland
    Dan from Oakland
  6. Kevin Pharis
    Kevin Pharis
    from Califunny
    Somebody say fool…? I’m here!;)
    Outback likes this.
  7. Stovebolt
    Stovebolt
    Hiya all.
    Outback likes this.
    winduptoy, Outback, Jeff34 and 4 others like this.
  9. Still lurking, slowly going forward
  10. youngsspeed
    youngsspeed
    It was mentioned that I should post my request for some knowledge here.
    I purchased a side mount set up a long while back.
    I am now back on my coupe project and want to sort out the side drive on my B motor.
    I purchased it because of the Mallory distributor.
    I did not want to use a mag.
    I am having a hard time finding any information on the Mallory distributor used on my set up.
    mvee33, Outback and Dan from Oakland like this.
  11. Told you they were gathering… all in one place for the first time. IMG_6648.jpeg
    winduptoy, jet996, Outback and 5 others like this.
  12. Bearing Burner
    Bearing Burner
    from W. MA
    Still looking for information on '32 Plymouth PB rngine
  13. Dedsoto
    Dedsoto
    from Australia
    Missed out on this at the swap this morning, pretty wild and corroded
    jet996, Outback and Stovebolt like this.
  14. 29Sleeper
    29Sleeper
    from SoCal
    Time to plan for May - The Antique Nationals will be held at Barona Dragstrip in Lakeside CA on Sunday May 4th. It will be a fun packed weekend with the RPM Nationals being held at Barona on May 3rd.
    winduptoy, GuyW and Stovebolt like this.
  15. 4BangerDean
    4BangerDean
    It’s been a while but I find myself tearing down another engine. It’s the first time I’ve come across these adjustable lifters. What tool will I need to remove the valve springs? IMG_8460.jpeg
  16. Dan from Oakland
    Dan from Oakland
    Probably a regular valve spring compressor. Collapse the spring and remove the split keys that hold the lower spring retainer onto the valve stem. Release the sprig retainer, remove the valve and then the spring and retainer can be taken out. Pretty much the same as removing valves from a stock engine except there are a pair of keys and a retainer rather than a one piece retainer on the mushroomed valve stem. Hope I'm not missing something.........
    4BangerDean likes this.
  17. 4BangerDean
    4BangerDean
    Thanks for the reply, The valve spring tool I have worked for the stock springs and retainers but is inadequate for these springs and retainers. I should have asked what style I need. I’ll locate a different style than what I have.
  18. Dan from Oakland
    Dan from Oakland
  19. 4BangerDean
    4BangerDean
  20. youngsspeed
    youngsspeed
    I carefully cleaned the tag.
    It is a model MY
    The serial number is also 90
    Still haven’t been able to find out any information. 4EB63C79-1232-46FF-9CB4-4CC4464CE76D.jpeg 8CD11050-5994-45EE-AB5F-F6BAC65EBE5A.jpeg
  21. Savage Coupe
    Savage Coupe
    from Washington
    IMG_8254.jpeg IMG_8257.jpeg IMG_8259.jpeg A little Banger garage shuffle and the first start of the Savage Coupe for the year.
    winduptoy, jet996, Deutscher and 6 others like this.
  22. PINEAPPLE
    PINEAPPLE
    Savage Coupe likes this.
  23. 4BangerDean
    4BangerDean
    Made the 1500 mile roundtrip to Schwalm’s to drop off all the pieces for my B engine build. Left my house 11:30 PM on Thursday night and made it home at 3:30 AM this morning. I guess you can say I’m all in on performance oriented Model As and Bs,
    I had bought a Burtz for my Model B pickup and reversed course on my decision. I just couldn’t put an A engine in my Model B. The engine will consist of a D4B high compression B head and water pump. Going to with a 1R grind cam and a set of Ross forged pistons. Hopefully I’ll get the short block back in 3 months.
    On a side note Ora at Schwalm’s has been great to deal with an I have full confidence in his ability to deliver an excellent product. IMG_8518.jpeg IMG_8455.jpeg IMG_8461.jpeg
    winduptoy, jet996, Outback and 6 others like this.
  24. Checking in! I've had some free time, so I decided to design a new cover for myself. Really interested in experimenting with investment casting, so we'll see what happens!
    On a side note, who is familiar with Frontenac information? Looking to learn all I can about them!
  25. Savage Coupe
    Savage Coupe
    from Washington
    Spotted this sweet roadster up in La Conner WA today.
    mvee33, Deutscher, winduptoy and 4 others like this.
  26. Calling out all Fronty Fanatics!
    I'm chasing the history of Frontenac.
    Im familiar with the Model R, S, T, Gerber, and the Stagger Valve.
    I read somewhere that there were single stick conversions, with varying abbreviations like OR and OSR or something of the likes. Does anyone know the history of those conversions? Barney Oldfield Collection 060.jpg
    studebakerjoe and jet996 like this.
  27. Stovebolt
    Stovebolt
    I was out and about today, and ran into a mate who took and posted this photo on Stalkbook.
    This ol’ girl doesn’t scrub up too bad, if I say so myself. Even better when you know that the paint is over 40 years old.
  28. Dan from Oakland
    Dan from Oakland
    "I read somewhere that there were single stick conversions, with varying abbreviations like OR and OSR or something of the likes. Does anyone know the history of those conversions?"
    The single overhead cam Fronty conversions normally used an 8 valve model SR head, although some were made up using the 8 valve model R heads. The SR heads were also offered in a rocker arm version. The OHC setup used a roller chain drive with a tensioner sprocket contained in the front cover. All the SR heads were twin spark and used 18mm plugs. SR heads have twin intake ports and three exhaust ports.
    Here is a picture of one at Speedy Bills:
    winduptoy, jet996, Outback and 2 others like this.
  29. Thanks Dan! If I remember correctly, there was someone on here with a supercharged fronty. Do you know who that is by any chance?
    Outback likes this.
  30. was mine. Single stick SR Fronty with a chain drive Gregg supercharger
    mvee33, Crusty Chevy, Super88 and 6 others like this.
