Projects Deuce Roadster with 4 IDFs
Discussion in 'The Hokey Ass Message Board' started by JReece, Apr 1, 2025.
  1. JReece
    JReece
    Here’s my ‘32 Ford Roadster I’ve been working on for about a year now. We’ve done a lot to make it more of a “Traditional Style.”
    Here’s the current features:
    • Blueprinted and Balanced Built 383 Full Roller Motor with 525 hp
    • Pierce Manifolds 4 x IDF Intake
    • 4 × 44 HPMX EMPI Carbs
    • Edelbrock Performer RPM Heads
    • Built TH350 Trans
    • RJay's Speed Shop Boxed '32 Ch***is
    • Front Big Bore GM Disc Brakes
    • Drilled I-Beam 4" Drop Axle
    • Flaming River Steering Column
    • 9" Ford Rear End
    • 4 Link Suspension with Coilovers
    • Rear Wilwood Disc Brakes
    • Halibrand 15” Sprint Wheels w/ Custom Knock-offs
    • M&H Racemasters Cheater Slicks 28x12.50-15LT
    • Michelin XZX Front Tires 165SR15
    Sharpone and LOU WELLS like this.
  2. JReece
    JReece
    IMG_4224.jpeg IMG_4228.jpeg IMG_4226.jpeg IMG_4229.jpeg IMG_4221.jpeg I hope you like it!
  3. JReece
    JReece
    I won my first trophy this past weekend.
  4. DDDenny
    Dig it.
    The only thing missing is a clutch pedal.
  5. JReece
    JReece
    I completely agree!
    Ned Ludd and Sharpone like this.
  6. Rand Man
    Rand Man
    I like it. My only comment would be those head rests make it look like more of a street rod. I’m sure it’s a fine machine.
    Just Gary and JReece like this.
  7. JReece
    JReece
    I agree, I wish they weren’t there, but there’s not much I can do about it now.
  8. Speccie
    Speccie
    Congratulations on the trophy.
    JReece likes this.
  9. flamedabone
    flamedabone
    Nicely done little car and my very favorite color, shiny black.
    -Abone.
    loudbang, JReece and ffr1222k like this.
  10. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Prtetty car. I even like the blued header pipes. It makes the car look like it was run hard, like a deuce roadster was meant to.
    Sharpone, duecesteve and JReece like this.
  11. Pasthisprime
    Pasthisprime
    love the Webers!
    Ned Ludd, duecesteve and JReece like this.
  12. JReece
    JReece
    Thanks man!
    duecesteve and Speccie like this.
  13. JReece
    JReece
    Me too, and it definitely has, LOL.
    duecesteve likes this.
  14. rod1
    rod1
    Nice. And, you like the Empi's?
    JReece likes this.
  15. Dan Hay
    Dan Hay
    My 2028cc VW ran really good with dual HPMX 44's. Nice car!
    JReece likes this.
  16. JReece
    JReece
    I love them. These 4.0’s are pretty spectacular compared to the old Webers. They have a lot of new features.
  17. jnaki
    jnaki
    Hello,
    This is one of the nicest roadsters in the last year shown on the HAMB… That is until the full side photo shown. The culprit just does not go along with the smooth style of the roadster. Everything seems well thought out, even the unusual carbs. But, then, when the exhausts are shown, the bottom piping seems like our high school first year students jammed it together as a last result.
    I have never been in the so called “lakes pipe” (like) header selection group. Impractical is based on location and when hot, is hot as far as access to the motor or opening the doors. So, the need to put a set on and divert the exhaust flow in a 90 degree turn and then more turns before the flow out of the back of the hot rod always puzzled me in design and function.
    When the headers were just open and not connected to the muffler systems as compe***ion items, then it had more value. Straight out of the motor and no backflow restrictions. But, now…
    Jnaki
    So, what is the solution? There is none if a smooth rearward flow of the exhaust is necessary. For looks, various 90 degree joints would continue the flow, but restricted. But at least some form of hidden continued piping is necessary to not ruin the nice roadster form or design. Or, make headers drop from the motor to bend back, smoothly under the frame, flowing together into collectors…YRMV
    Sorry, @JReece
    mkubacak and Just Gary like this.
  18. JReece
    JReece
    Yea, that wasn’t really what I thought I was getting when I took it to the muffler shop. I was hoping for a smoother look with minimal bends. However, in person they are not nearly as noticeable. This car is so small and low to the ground, you really don’t see much of them at all. I figured they’d do for now, but at some point I’ll do something different.
    jnaki likes this.
  19. On the pipes, you need to buy mandrel bent u-bends (different angles to work with) and then custom make the pipes to flow a bit better, hug the frame more, etc.. It is a lot of fabrication and TIG welding work - but it will be worth it in the end. Exhaust systems are one of the biggest pains in the ***es in building an early Hotrod . . . bar none!
    JReece and Just Gary like this.
  20. JReece
    JReece
    I get that, and I know it would look good, but I’m trying to go for a more “late ‘60s period” setup as I can and no one was running SS, mandrel bent, TIG’d exhaust piping.
  21. JReece
    JReece
    Here are some more pictures of the car.
    Sharpone, duecesteve and loudbang like this.
  22. JReece
    JReece
    Few more pics.
    Sharpone, duecesteve, rod1 and 2 others like this.
  23. JReece
    JReece
    I took the car out last night to the Varsity Cruise In in Dawsonville, GA. Here’s the video of the event:
  24. JReece
    JReece
    My car, as well as my dad’s ‘55.
  25. JReece
    JReece
    Hot Rod Revival #4 - ***ming, GA - May 16-17, 2025
  26. JReece
    JReece
    We had a great time at the Hot Rod Revival. Here’s a few shots of the car there. D65FE08D-F7AE-43BE-A3A2-2AB4B4452CB8.jpeg IMG_6120.jpeg IMG_6035.jpeg B2360DE4-5EBE-49D7-A31D-2320CB4C0C93.jpeg
  27. JReece
    JReece
    Here’s a few more shots of my car from other people at the show.
  28. HOTRODPRIMER
    HOTRODPRIMER
    Won't the headrest slid out, they are too low to do any good, other than that the car look great to me. HRP
    JReece likes this.
  29. JReece
    JReece
    Technically they can slide all the way out, but then it looks like something is missing with the plastic clips on top. They come up like a foot, which would technically work as a headrest for a normal sized person. I’m 6’4” and 300 lbs. Lol.
  30. Bandit Billy
    Bandit Billy
    So, make a cool SS trim piece that uses the same mounts as the headrests to cover it up. A lot of seats had nice trim on them back in the early 60's.
