Technical Brake bleeder hose
Discussion in 'The Hokey Ass Message Board' started by johnfin, Mar 30, 2025.
  1. johnfin
    johnfin
    from Florida
    I need to replace the coiled brake bleeder hose on my chinese unit. Only lasted a few weeks. Any ideas on a chemical resistant hose.
  2. pprather
    pprather
    I use clear hose that I buy by the foot at my local Ace Hardware, when I bleed brakes.
    It doesn't seem to be affected by type 3 fluid.
    Dino 64, Just Gary and firstinsteele like this.
  3. johnfin
    johnfin
    from Florida
    I use to too until i bought this machine. Not sure if the curly q has a function.
  4. Mr48chev
    How much pressure are you using. That type of unit is only supposed to operate on 15 lbs max pressure.
  5. indyjps
    indyjps
    Curly Q is very annoying seems to hold bubbles. Maybe my imagination as the bleeding process stretches out :D
    I also use clear ace hardware hose, get extra. Lay it out flat and get some heat into it to relieve the curve from the roll.
  6. Kiwi 4d
    Kiwi 4d
    I have used this el cheapo bleeder for years , it has never let me down .
