Technical Body Filler Basics
Discussion in 'The Hokey Ass Message Board' started by K13, Jan 11, 2020.
  1. jakesbackyard
    jakesbackyard
    from ND
    Excellent thread.
    K13, klleetrucking and fauj like this.
  2. grey49ghost
    grey49ghost
    Thanks for sharing your knowledge @K13. This thread has a lot of useful information.
    Sent from my SM-N986U using The H.A.M.B. mobile app
    K13 likes this.
  3. K13
    K13
    Sorry I missed this question. If you use decent filler there should be no need to do this. This is back to the old mentality of using fillers when they were hard to sand and didn't self level well. The biggest concern would be breaking the bond between the filler and the metal as it won't be fully adhered to the metal until the filler is completely cured. If you are needing to remove enough material that a cheese grader is needed you are using lousy filler or applying way too much in the first place.
    gimpyshotrods and fauj like this.
  4. I’ve see guys slather filler and it looks like they frosted a cake and post pics of it.
    Then there’s a squad of guys following and saying ohhh great job.
    You damn sure gonna need a cheese grater to get anywhere doing things like that
    Roothawg, alchemy, fauj and 2 others like this.
  5. 59rambler
    59rambler
    Great information, my question is what is life expectancy of cream hardeners, I have some tubes that the cream looks gritty, time to throw in garbage? Thanks for info
  6. K13
    K13
    18 months from the date of manufacture is about the limit for the life span of hardeners. They degrade over time and lose their strength so even though they may still be hardening the product they will require more and more to properly and fully cure the product over time. If they have become gritty then they are definitely garbage.
  7. 59rambler
    59rambler
    Thanks for the info, another question, I have epoxy coated some pedal cars after they were acid dipped, is it ok to use bondo over epoxy paint for repairs or should I strip area down to bare metal?
  8. KenC
    KenC
    Just scuff the epoxy with 80 or 120 grit and you'll be fine.
  9. 59rambler
    59rambler
    Thank you for the help
  10. Country Joe
    Country Joe
  11. phoneman
    phoneman
    from Missouri
    Those that do their filler work over epoxy. How do you handle areas you sand through the epoxy. do you recoat with epoxy further work?
  12. X38
    X38
    Some people must use POR15 filler because apparently it adheres best to rust.:eek:
  13. buick bill
    buick bill
    from yreka;ca
    i have started using more ice and less filler due to ease of app/ prep . is this good or should filler be used as a base for strength/stability .and is app .best on bare metal or on primer or sealer ?
  14. That all depends on if it’s sanded off a high spot or not. High spots is what ruins the day.
    If you just got distracted trying to sand out an imperfection in the filler that really needed filled any way not sanded,,,
    Or if it’s where the metal, epoxy primer and filler feathers out. In this case you’re finished and scuff up the surrounding epoxy and blow a little epoxy on, follow the data sheet and move on to filler primer.
    For the other situations, since filler has been done on bare metal for eons it doesn’t really matter much till you knock down the high spots or add more filler.
  15. Allan slater
    Allan slater
    I hope I am not just ****ing in, can I ask you what the best filler would be to fill floor pan **** welds? Just to smooth things out a bit?
    brEad likes this.
  16. K13
    K13
    On a floor pan I would use something reinforced. Maybe even one of the flexible reinforced products. You can message me if you want specific recommendations.
    brEad and fauj like this.
  17. vtx1800
    vtx1800
    @K13 I primed the fibergl*** T body with Shop Line JP202 primer surfacer a couple of days ago and now have found some pin holes that I missed (Evercoat gold filler) and some other "occlusions" that I had missed also. Do I need to sand it down totally down before using filler to "fix" my misses....or do I need to use a dremel to get the primer out? Wish my eyes/fingers worked better:)
  18. K13
    K13
    You can just sand the surface of the primer and reapply. No need to clean out the holes just make sure you blow the area off well so there is no sanding dust left in the holes. You would probably be better off using a putty rather than a filler if it is just pinholes and small areas needing touch up. It will allow you to sand with a finer grit (180) and will be far less likely to pinhole again.
    fauj, klleetrucking and vtx1800 like this.
  19. Just bumping this thread 'cause it contains great information!
    Thanks again @K13.
