Technical Aluminum radiators.... what's the consensus?
Discussion in 'The Hokey Ass Message Board' started by Crazy Steve, Mar 28, 2025.
  1. tubman
    tubman
    See my post #73 on this thread to see one way to do it.
    Dan Hay likes this.
  2. Dan Hay
    Dan Hay
  3. tubman
    tubman
    I looked at that link. I like my homemade one better. It's a lot cheaper, has more surface exposure, and the anode is easily replaced.
    Dan Hay likes this.
  4. Dan Hay
    Dan Hay
    I'll give it a whirl, if it needs replacing within 6 mos then I'll think about a bigger anode and whip something up.
  5. Fitty Toomuch
    Fitty Toomuch
    from WVa
    Grounding your radiator and even the heater core should help most electrolysis problems.
  6. Roothawg
    Roothawg
    So, I need to give you someone to flog.
    My old 2002 Ford F150, just received it's first antifreeze change in 2022. It has never overheated and I still have the original water pump on it. No visible corrosion. 160K miles on it. If you have ever seen the Fly at a track, that's what pulled it there.
    The only reason I changed the coolant was I had to change the heater core. Could I have gotten another 2 years out of it if I would have maintained the coolant? Maybe. I just didn't care. I wanted to focus on my hot rods.
    I am just playing devil's advocate here. I know I am a bad owner....
    The antifreeze smelled like a dead animal, but I guess that was to be expected.
    Flog away.
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    Cheap , any 1/4"npt access , block drain , radiator , intake , etc Screenshot_20250402-155556.png
    Ziggster, partssaloon and 1biggun like this.
  8. 1biggun
    1biggun
    John Deere dealers and other places sell test strips to check you coolant PH level and all that jazz. There are additives you can buy to correct you coolant if its off. On a car buying a few new gallons is no big deal but on heavy equipment were diesel liners get messed up by tiny air bubbles and aluminum gets eaten and such and the system holds 20 gallons its a big deal to adjust and correct existing coolant.
    I have aluminum after market radiators in a couple 60's - 70's chevy's and they have been fine. I may save my new Walker Model T radiator I have for something else nicer and buy a cheap aluminum radiator for the Speed Way fiberglass 27 project I'm building on the cheap. I can add brackets to the aluminum radiator with my TIG as well were I want.
    jimmy six, mad mikey and GuyW like this.
  9. Ned Ludd
    Ned Ludd
    Paint colour makes virtually no difference to thermal infrared radiation at the ±400K a radiator sees. A matt surface finish might help a tiny bit, regardless of colour.
    Black paint was traditionally used because it's cheap and tough and goes with everything.
  10. tubman
    tubman
    While zinc will work, magnesium is superior in protecting aluminum. Again, look at the Galvanic Table. The electrical potential between the worst grade of aluminum and the purest zinc is almost zero. while that between aluminum and magnesium is at least .6 volts. I know what I want protecting my heads, especially when it's easy to find and not that expensive.
    gimpyshotrods likes this.
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
    There's a bunch of aluminum in marine power systems , the go to anode has been for many years , Zinc , whatever ...
  12. tubman
    tubman
    Denial of proven science seems to be common these days.
    twenty8 and miker98038 like this.
  13. gimpyshotrods
    gimpyshotrods
    It's a national sport.
  14. If my options for a specific application in brass/copper were limited or nonexistent, then I would use an aluminum one painted black. You can't see it with the hood closed anyway and only weirdos would be on their hands and knees peeping through the grill to check that the car you built for yourself meets their expectations.
    gimpyshotrods and 2OLD2FAST like this.
  15. Fitty Toomuch
    Fitty Toomuch
    from WVa
    I`ve got you beat, my 2000 gmc 3500 454 with about the same milage has never been changed. It`s loaded with stop leak, I really need to get that flushed out of there as the stat is stuck open and never gets above 140, should be 210. I thought the heater core was leaking but iirc it was a quick connect and I just cut beyond that and direct connected it. It`s a rig truck that never gets used any more, may as well sell it. I bought new coolant and stat years ago, I really need to get around to that job:)
    2OLD2FAST and Roothawg like this.
  16. bobkatrods
    bobkatrods
    from aledo tx
    I don't know about that radiator. but two of my friends have cold case radiators from Summit .Both guys are on the 3rd radiator due to leaks.
  17. Original 1938 GM rad from an inline 6 cyl vehicle. I took the rad to a recommended rad shop and had it****essed. Rad was in good shape so I had them make some changes to it so I could run a SBC 350. Cost me $280. I installed it on a Thursday and was leaving for a weekend show the next day. Rad leaked on Friday test run. I was not happy, no time to return it and still make the show. I decided to smear a bunch of epoxy over the leak (basically voiding any warranty there may be). It still leaked some but I made it to the show.
    My next step was to remove the GM rad and get one custom built by BeCool. Cost was something like $1200. I used distilled and an anode. I did not ground the rad as this thread is the first I've ever heard of that being done. I did mount the BeCool rad on rubber mounts as recommended by the guys at BeCool. Rad lasted about two years before it started leaking. Again ... I am not happy. At this point I tossed in a can or two of sealer and, when it started leaking again, I'd toss in another can. I probably threw in a can a year. I no longer own the car.
    All that being said, if I was to do it again, I'd buy a cheap aluminum universal rad (no more custom garbage) and consider it a disposable item. With all the money I had spent on the factory rad, then the custom BeCool nonsense, I could have bought quite a few cheapie universal rads.
  18. twenty8
    twenty8
    I think you will find it is an international sport. Probably won't be too long before it is introduced at the olympics.
    Roothawg and Ned Ludd like this.
  19. I run one in my 39 Ford tub and it works well, using distilled water and water wetter, stays 170 - 180 deg.
  20. Russco
    Russco
    from Central IL
    That is who I’ve used for about the last 12 years and I’ve had good luck with them. I did have to replace one it it was damaged from something that was my fault.
    Bandit Billy likes this.
  21. swade41
    swade41
    from Buffalo,NY
    I've got aluminum radiators in all 4 of my cars, some custom made and others from Champion, run regular green anti-freeze without issues.
    I did paint the front of the one in the Henry J with Rustoleum's black high temp grill paint, ironically because I'm not running a grill in that car.
    miker98038 likes this.
  22. Ziggster
    Ziggster
    Back in the day, when we added A/C to the Light Armoured Vehicle (LAV), now referred to as the Stryker, a German “engineer” in our systems engineering group insisted on using silver paint on the rad cooling fan shroud as it would solve all of our heat transfer issues of that heat transferring to our cooled air ducts coming off of the evaporators which were only 1/2” away. Of course that didn’t work. That clown cost the company (General Motors Diesel Division) millions upon millions of dollars in damages as a total redesign was required in the midst of production.
  23. theHIGHLANDER
    theHIGHLANDER
    Ned yer a sharp guy, and have smarts gleaned from sources some never heard of. However, the SAE did a study in the late 60s, or early 70s that concluded satin/flat black absorbs heat from either direction. In other words direct sunlight or internal component heat. In that era we began to see a lot more air cooled engines and components in satin black. Do I believe it? Well, I wouldn't rest my forearms on a shiney black hood on a 90 degree sunny day. White, not so bad. All heat is a form of radiation and it's absorbed by dark colors.
  24. squirrel
    this is what I do, if I can find one that I can make fit...
    Paul B and firstinsteele like this.
