Hot Rods BENNETTS ‘Pacific-Indian Special’ ‘29 Roadster on ‘32 rails
Discussion in 'The Hokey Ass Message Board' started by jordabennett, Jun 5, 2022.
  1. Tim_with_a_T
    Tim_with_a_T
    I believe for the clips, you're either stuck making them or robbing them off a donor wheel. I could be wrong, but that was my understanding. Beautiful job on the crossmember.
  2. Roger that!
  3. dirt car
    dirt car
    from nebraska
    Check Bob Drake web site he was reproducing the clips.
    chryslerfan55 and jordabennett like this.
  4. dirt car
    dirt car
    from nebraska
    The Drake clips are listed as SKU 68-1034 $26.95 a set with correct rivets
    jordabennett and Tim_with_a_T like this.
  5. Tim_with_a_T
    Tim_with_a_T
    Learn something new every day! Nice @dirt car
  6. dirt car
    dirt car
    from nebraska
    I had my 15" wide 5's powder coated & should have removed the clips prior as they serve no purpose on my open wheel.
    jordabennett likes this.
  7. Thank you sir! Yeah I’m not planning on running caps but thought heck might be nice to have the option!
  8. Everydays a school day!
    Tim_with_a_T likes this.
  9. Total long shot but was thinking of running a old chrome or nickle plated 32 grill- I know that’s rare as hens teeth but let’s play the game, anyone holding?
  10. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I may have some clips. (No rivets though) Will send them along with your other stuff:D
    Beautiful job on the crossmember!
    Now, if I can just find a pair of 18" Kelsey Hayes Wide 5s.
  11. I got one extra Bruce! It’s a bit rough but still. Half ways there
    chryslerfan55 and brEad like this.
  12. Put a few hours into the rear cross member- definitely a lot of work! Would have been easier to remove the whole thing and fix in a complete model a crossmember. Happy with the result though- some t******* underneath and some hot rivets and I’ll call it done. I plan on painting the inside the the frame rails and crossmembers again.
    Will prep and primer wheels and get those done in gloss black in order to get the tires fitted! Another step closer to getting this rolling!
    IMG_5648.jpeg IMG_5647.jpeg IMG_5646.jpeg IMG_5643.jpeg IMG_5642.jpeg IMG_5641.jpeg IMG_5635.jpeg
    chryslerfan55, rod1, porkshop and 6 others like this.
  13. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Looks like the Lord sent it down!
  14. I know it's something that will rarely (ever?) get seen after the body goes on, but I LOVE how you molded the Model A to the 32 crossmember. Flows nicely and just gives a different feel.
  15. Hahah
    Stogy likes this.
  16. Agreed! Happy with the result forsure
    chryslerfan55, porkshop and Stogy like this.
  17. Frames flipped over, sections of the old 32 crossmember are removed and will finalize the welding and blending. Got excited to see what the Model T spring sat like.. might be a bit too low!
    IMG_5668.jpeg IMG_5667.jpeg IMG_5666.jpeg IMG_5671.jpeg IMG_5672.jpeg IMG_5674.jpeg
  18. alchemy
    alchemy
    If it’s too low, switch in an A spring.
    porkshop and jordabennett like this.
  19. Definitely I got one on standby
    chryslerfan55, porkshop and brEad like this.
  20. Rear crossmember is officially finished.
    Welded inside and out, blended, hot riveted, primed and painted.
    I then loosely mocked up the rear axle using the QC and ‘36 radious rods. Little worried about the model T spring but can run a Model A spring if needed. Excited to get the rear axle built in order to get it all bolted up for the last time.
    Also might need to run different shackles as when the u bolt plates are right side up they does catch the threads IMG_5672.jpeg IMG_5689.jpeg IMG_5693.jpeg IMG_5688.jpeg IMG_5685.jpeg IMG_5686.jpeg IMG_5698.jpeg IMG_5699.jpeg IMG_5716.jpeg IMG_5715.jpeg IMG_5714.jpeg IMG_5712.jpeg IMG_5720.jpeg IMG_5722.jpeg IMG_5723.jpeg IMG_5725.jpeg IMG_5728.jpeg IMG_5727.jpeg IMG_5727.jpeg
  21. Over the next week I plan to get this back rolling! I want to finish the 36 radious rods and fir those to get everything painted. Then it’s on to the hubs and spindles.
    A photo from what seemed to be another life time. Excited to get this one rolling.
    IMG_3766.jpeg IMG_3775.jpeg IMG_6568.jpeg 40F1D848-6836-4ECB-B56A-82A17E43F403.jpeg
    chryslerfan55, Stogy, rod1 and 8 others like this.
  22. Due to the drive shaft relocation nearly 3” lower than the factory ‘36 center I needed to head and bend the radious rods to fit properly.
    Also the distance of the pinion flange was a 1/4” shorter on the Quick Change so I needed to make a spacer plate.
    Where the leaf spring mounts was really worn so I popped some br*** inside and tig welded it back up and hit it with the scaler.
    Now to get this Rear end built and installed.
    IMG_5827.jpeg IMG_5828.jpeg IMG_5832.jpeg IMG_5833.jpeg IMG_5830.jpeg IMG_5831.jpeg IMG_5835.jpeg IMG_5836.jpeg IMG_5837.jpeg IMG_5838.jpeg
  23. Lots more to come!
    Stogy likes this.
  24. While still awaiting the carrier bearings for the rear end to build I decided to clean up and paint the wheels. fronts are 16” narrow V860 rims and rear are 18” Kelsey Hayes. I didn’t high build or try and make them perfect. I bit of 2k gloss and some character is what I was after.
    Tires tomorrow!
    IMG_5917.jpeg IMG_5916.jpeg IMG_5915.jpeg IMG_5923.jpeg IMG_5924.jpeg IMG_5927.jpeg IMG_5929.jpeg
    chryslerfan55, brEad, Stogy and 3 others like this.
  25. 41 GMC K-18
    41 GMC K-18
    Even though those wheels are wide five bolt pattern, to me, the artillery style spokes are still one of the most interesting, artistic style of wheels ever created from that time period!
    Simply magnificent!
    chryslerfan55, Stogy and jordabennett like this.
  26. Definitely don’t disagree. Beautiful curves for sure
    chryslerfan55, Stogy and 41 GMC K-18 like this.
  27. dirt car
    dirt car
    from nebraska
    That solid black looks great & can't say I've ever seen the Ford wide 5's with factory pin stripping, but an interesting option, G.M./Mopar & others offered artillery wheels some with multi color accent stripping, then too Ford offered the accessory S.S.one piece scalloped spoke hub cap combo to liven things up, but only in the 16" I believe.
  28. 41 GMC K-18
    41 GMC K-18
    These are custom made by" EVOD" and are really well done, super spendy though at $2000.00 each. They were a set of one off design, for a Dave Kindig project. They are elegant indeed.
    chryslerfan55 and porkshop like this.
  29. dirt car
    dirt car
    from nebraska
    Impressive for sure!
