Projects Timm builds a model A
Discussion in 'The Hokey Ass Message Board' started by Tim, Mar 8, 2016.
  1. Six Ball
    Six Ball
    from Nevada
    Will the full diameter of the rubber be supported by the frame mount?
  2. Tim
    Tim
    from KCMO
    Yup. The side gussets fold down about half way threw the biscuit if that helps picture it.
  3. Tim
    Tim
    from KCMO
  4. Six Ball
    Six Ball
    from Nevada
    OK! I just wasn't seeing it. Should have known you would have it covered. Good work!
    Tim likes this.
  5. Tim
    Tim
    from KCMO
    IMG_9135.jpeg Measured 5 zillion times, tossed a few apparently strong enough tacks and sat the engine down! The biscuits squished just enough that the exhaust manifold hits the steering column. But just by a hair. I’m going to grab some thick fender washers to shim it back up and see where we sit.
    engine is currently sitting on the mounts with the hoist attached with a slightly slack chain just in case. It’s been a couple hours and it hasn’t moved at all but I figure better safe than sorry and I’m gonna have to lift it to shim it anyways. IMG_9137.jpeg plenty of steering box and exhaust room
    drdave, brEad, osage orange and 4 others like this.
  6. nrgwizard
    nrgwizard
    from Minn. uSA
    Aren't those ford biscuits supposed to have cups around the bottom of the upper biscuit, to keep them from squeezing out??? Which also act like a washer/shim under them?
    Marcus...
  7. Tim
    Tim
    from KCMO
    Some are like that. Some just have a metal band around them. These have like a pyramid shape on the top, maybe cone is a better word? Anyhow looks like that’s where any squish has taken place as I’m sure is intended.
    I had thought about sitting a small block on one of these just to guess how much it might compress under weight and then factor that in but at some point I just have to stop measuring **** and just put it together.
  8. Tim
    Tim
    from KCMO
    Guess I gotta eat my hat on those rubbers. Got home from work and they’ve squished are smushed down to somewhere between 3/4 and 7/8 of an inch. Looks like roadster shop has the best deal on the metal banded units but now I’m leery about what to order.
    Okie Pete and G_Don like this.
  9. 05snopro440
    05snopro440
    Are those rubber biscuits you have hard or soft?
    Mine from Roadster Supply with the band are really hard.
    Tim likes this.
  10. Tim
    Tim
    from KCMO
    Apparently soft lol these are compressed I would guess 50% gonna try to order some tonight before I go to bed. Was feeling productive this bums me out but can’t let it slow me down
    edit- the squished to 3/4 or 7/5 in the previous post is over all height with weight on them
  11. Tim
    Tim
    from KCMO
    Ordered the roadster supply cushions, I’ll take these squishy ones and use them for a trans mount or something
  12. Tim
    Tim
    from KCMO
    Full fender sedan with the nose down in 1953? I’m filing this under inspiration while I wait on parts. IMG_9142.jpeg
  13. Tim
    Tim
    from KCMO
    “Power of the hamb “ is pretty cool some times.
    waiting on motor mount supplies to make it to my door step I searched “building transmission mount.hamb” and the very first result is @Paul building a trans mount for the exact same transmission I’m using and the same holes I'm going to use AND that the rubber mount I want to use can work!
    https://www.jalopyjournal.com/forum/threads/transmission-mount.16897/
    jackpot! This helps a ton!
  14. Paul
    Paul
    Editor
    dang, 21 years ago.. man where did the time go?
  15. Tim
    Tim
    from KCMO
    I turned to my wife and told her what I found and when I did the math on how old the thread is I said “wait, no that can’t be right?” Lol
  16. RodStRace
    RodStRace
    Power! Good on you to link it AND thank the OP.
    Being gracious and giving credit is being a quality hoodlum!:)
    The HAMB is dedicated to spreading the gospel of traditional hot rods and kustoms to hoodlums world wide.
    drdave, osage orange and Tim like this.
  17. Tim
    Tim
    from KCMO
    I always like sharing all that info for a few reasons. 1: when I forget where I found it or the details I can come back here 2: if anyone else needs the info or wants to see further detail. 3: I tag the OP to say thanks and feed back, I feel like that encourages people to continue posting tech and threads in general. Also with old threads they might volunteer added new information that’s developed or learned since originally posted.
    drdave, Just Gary, Six Ball and 4 others like this.
  18. Six Ball
    Six Ball
    from Nevada
    And there are the ones here who ***** about bringing up an old thread like anything we do here is new. :rolleyes:
    RodStRace, Just Gary, Tim and 2 others like this.
  19. Tim
    Tim
    from KCMO
    Ordered just after midnite on Friday and before dinner Monday my parts are here from roadster supply. One day ahead of the tracking number estimate! Popped them Open quickly they are much much harder. Maybe tonight I’ll try to swap them out. Right now they are twice as tall as the installed ones that are smashed. I’ll measure and compare when I swap them
    drdave, Six Ball, Thor1 and 2 others like this.
  20. nochop
    nochop
    from norcal
    Six Ball, Thor1 and Tim like this.
  21. 05snopro440
    05snopro440
    Glad to hear they're harder. I was surprised how hard they were. Interested to hear how they work out.
    Six Ball, osage orange and Tim like this.
  22. The same ones that gripe about zombie threads are the same ones that gripe about new threads about previously discussed topics lol
  23. 05snopro440
    05snopro440
    Miserable people want everyone to be miserable. :p
    Six Ball, osage orange, RAK and 2 others like this.
  24. Tim
    Tim
    from KCMO
    Mid day update :)
    I swapped out the rubbers and hardware and measured the squished and un installed heights of each. Initial measuring shows the roadster supply rubbers are initially taller and only compressed 1/32 of an inch! So installed they are still taller than the one ones before install.
    I got as far as threading the bolts until they got to the nylock section and stopped so I don’t ruin them/ use them up. Both little lips registered in the mounts etc.
    I did not get time to measure level or placement etc but I did try on the drivers side manifold. It fits! But just barely touches. Before I shim it or hit the manifold with a flap disc I need to let the cushions sit for a couple more hours and the measure everything. No point shimming if it’s not even centered or something.
    drdave, Just Gary, rjgideon and 7 others like this.
  25. RAK
    RAK
    Mine with a SBC on them haven't moved in almost 7 years, the motor doesn't even rock when you rev it. I wouldn't worry about them.
    Six Ball, brEad, osage orange and 2 others like this.
  26. 05snopro440
    05snopro440
    I'm glad they seem to be much better!
    Six Ball, RodStRace and osage orange like this.
  27. Tim
    Tim
    from KCMO
    Alright so I spent the evening measuring and leveling and on and on. I think it might be just a hair different than it was but everything clears so I currently don’t see a reason to mess with it. My only interference at the moment is that drivers side exhaust manifold. I’m continuing to level and check etc. if it’s dead level I’m going to hit the manifold with a flat disc if it’s not I’ll shim that side up to gain clearance and level. Worse case I build headers. Thinking some Belond style center dumps.
    anyhow I’m moving onto the trans mount. Last night I cloned the tube mount I have in cardboard after realizing that would be easier to manipulate into the space than gaining room to get the metal one in without moving the trans.
    all the photos I took look the same as the rest so here’s a photo of the hood and grill on again and the front drivers tire tucking into the fender.
    I was soooo close to just sitting the front end back on the ground but I do t want the drivetrain to move at all and dropping the front end 5 ish inches could certain shift stuff that’s not bolted down. IMG_9321.jpeg
    brEad, drdave, Thor1 and 3 others like this.
  28. RodStRace
    RodStRace
    Stupid question; judging from the pics, it looks like a couple shims at the trans will make more of a change than at the engine side mounts as far as getting clearance at the exhaust/steering. Is the driveline angle locked in and where you want it?
    drdave and Six Ball like this.
  29. Tim
    Tim
    from KCMO
    Yup the fan has to be nearly perfectly parallel with the radiator to give enough room top and bottom.
    I can bolt the manifold on its just the meat around the very last/bottom bolt hole s****es because it’s so thick. Good thought though. Everything’s just tacked so I nothings 100% set.
    drdave, Six Ball and Thor1 like this.
  30. RodStRace
    RodStRace
