Hot Rods frame is 38..title is 38 chevy....BUT????
Discussion in 'The Hokey Ass Message Board' started by ALLDONE, Apr 2, 2025.
  1. proartguy
    proartguy
    from Sparks, NV
    There are two tags located on the passenger side firewall. The upper one has the model; Deluxe or Special Deluxe and thecvehicle serial number which starts with the series letters - GB or GA in ‘37. The lower tag is the style plate that indicated info as far as body style, trim and paint number codes.
    Many states would use engine numbers as identification before the standardized VIN system was introduced. Using engine numbers can cause lots of problems for registration now. Just my experience.
    ALLDONE likes this.
  2. deathrowdave
    deathrowdave
    from NKy
    I had one and plenty of parts years ago . I did not know 38 -39 was wider than 37 . I had a coupe and also an extra sedan frame seems as remember the 38 frame was dimpled slightly on the sedan to clear the gas filler neck
    ALLDONE likes this.
  3. 57Fury440
    57Fury440
    As someone with very little knowledge about the 37 and 38 Chevy cars, what parts were fiberglass? Nice car.
  4. twenty8
    twenty8
    Only the aftermarket reproduction parts......
  5. 57Fury440
    57Fury440
