Technical Ford Flathead Transmission gear ratios
Discussion in 'Traditional Hot Rods' started by bustingear, Apr 4, 2025.
  1. bustingear
    bustingear
    I know it is a Ford open drive post 1939 with the desireable large double detent shift tower but I am trying to find out the 1st, 2nd ,and 3rd gear ratios. Anyone close to these?
    Number on the base rear case 78-7006
    Number on Shift Tower 81A-7222B
    Serial number on upper bell area 799C-I 906942
    Thanks
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    High gear will always be 1:1. the only way to tell the rest is to turn the input and count rotation on the output or remove the cover and count teeth
  3. bustingear
    bustingear
    i have the cover off but there are several gears on the top and several on the bottom. Which ones to count? Thanks
  4. wheeltramp brian
    wheeltramp brian
    The cluster gear. 17437948941073031886577756896999.jpg 17437949213353325029268958269318.jpg
    alchemy likes this.
  5. bustingear
    bustingear
    According to the chart i saw on Van Pelt website a 29 tooth cluster gear can either be a 3.520 or a 3.114 depending on a 14 or 15 tooth drive gear??? And if your going after a cluster dont you have to count all four to get it right?
  6. bustingear
    bustingear
    Any tricks to counting it without taking it apart? Can only see the edge and too greasy to mark?
  7. rusty valley
    rusty valley
    Dab a rag on a tooth to clean it, then a dot from a paint marker pen. easy peasy
    V8-m likes this.
  8. V8-m
    V8-m
    from Alaska
    Exactly like I did.
    rusty valley likes this.
