Technical blown Olds
Discussion in 'The Hokey Ass Message Board' started by Paul, Apr 4, 2025.
  1. Paul
    Paul
    Editor
    good friend brought a pile of parts over to see if we could make something out of it.
    a roller cammed '56 block and heads with Cragar 2" belt driven 4-71 and misc bits and pieces.
    I tore the block down to inspect,
    unfortunately it didn't p*** inspection.
    for ease of handling and storage I re***embled the big pieces, for now it can be garage art while he creates a new game plan.
  2. hrm2k
    hrm2k
    Sure is pretty even if it don’t work……
    Toms Dogs, 2OLD2FAST, lostn51 and 4 others like this.
  3. Mitchell Rish
    Mitchell Rish
    from Houston MS
    What didn’t p***? An early roller cammed blown Olds surely it isn’t beyond Hope? Too much good stuff there. I am a ****er for such things.
  4. Fordors
    Fordors
    Wondering about the cam, is it an early Herbert with long bars bolted into the valley to keep the lifters aligned?
  5. swifty
    swifty
    Are those beautiful Weiand valve covers extra tall to suit the roller situation? I don't think you could find a better combination of exotic parts for that engine. Hey I've got a running 55 Olds engine sitting in the shed but the freight would be a problem LOL
  6. Paul
    Paul
    Editor
    yep, I wouldn't mind having it in my corner
    let's just say the juice ain't worth the squeeze..
    block already bored .125 over,
    crank turned .020 under and scored mains
    pistons and rods renumbered from multiple rebuilds or donors
    far better to start with another core.
    we already have lines on a couple others.
    no name stamped, it does have the number 1 stamped twice, it rides in needle bearings and there was a flat plate bolted to the valley cover bosses that kept the lifters from rotating.
    bchctybob, Tim, Sharpone and 4 others like this.
  7. Paul
    Paul
    Editor
    the valve covers are to clear the adjustable rockers.
  8. Fordors
    Fordors
    Sounds like a Herbert, AFAIK Chet was the only one to guide roller lifters that way before the idea of joining pairs was thought of.
    bchctybob, Paul and mad mikey like this.
  9. lostn51
    lostn51
    from Tennessee
    That’s some gorgeous garage art!!!
    hrm2k, Sharpone and Paul like this.
  10. oldsmobum
    oldsmobum
    from SoCal
    What will it eventually go in?
  11. Paul
    Paul
    Editor
    he has a few to choose from, all early Fords
    bchctybob, hrm2k and Sharpone like this.
  12. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Hunka Hunka Burn'n Love
    mad mikey, Paul, hrm2k and 2 others like this.
  13. saltracer219
    saltracer219
    That sounds like a Chet Herbert roller, that is the same setup that I found when I restored the Orange Crate engine.
  14. Mitchell Rish
    Mitchell Rish
    from Houston MS
    I’d love to hear that baby run.
    mad mikey, Paul and Sharpone like this.
  15. GlassThamesDoug
    GlassThamesDoug
    Very Cool....in any ride.
  16. Tim
    Tim
    from KCMO
    Dang that’s cool!
    Sharpone, mad mikey and Paul like this.
  17. warbird1
    warbird1
    Looks kinda familiar... did it come out of the Skagit County area?
    bchctybob, El Hueso, 550Coupe and 5 others like this.
  18. Paul
    Paul
    Editor
    good eye, it does look like the same one, only obvious changes are the valve covers and timing cover
  19. tubman
    tubman
    The blower idler pulley is set up different as well.
  20. warbird1
    warbird1
    The picture of the blown Olds in the rail was taken at the Arlington Dragstrip Reunion about 2008. That one belonged to my nephew at the time. It came out of a '52 Olds convertible from the Oak Harbor area; he added the blower set up and put it in a couple of cars over the years. Never got it running and never tore it down to check the condition of the innards, though I told him he'd better do that before trying to start it. He was always looking for more speed equipment for it and was always adding stuff as he acquired it. Could be the same engine, or not...
    The Hydro that came off the back of it is in my roadster now.
  21. Back in the '50's we were known to bore those things to 3 15/16 or .187 over. As far as the cam, I bought a used roller that used the plate in the valley. Guy told me it was an Engle.
  22. saltracer219
    saltracer219
    Chet Herbert was the first one to use roller lifters in Hot Rod engines in the 50's. From what I have seen, I believe that several of the cam grinders in those early years used Herbert roller set ups with their cams. However they could have copied Chet's design also.
  23. Paul
    Paul
    Editor
    made a simple idler bracket out of 1/4" steel plate and tubing.
    there is enough adjustment to run the belt inside or out.
    (this "belt" is just a 2" rubber strap I had laying around to check fit and look)
  24. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Nice / Simple/ Clean.
  25. 550Coupe
    550Coupe
    I have been running a blown Olds (57' 371")in my nostalgia gas 34' Ford for ten years . Love the motor. For one thing it has that "cool effect" attention getter and not just another sbc/bbc. Not the fastest in the bunch but 10.17 / 130 mph is fast enough for me.. IMG_20190314_121234.jpg
  26. mad mikey
    mad mikey
    NICE! :):cool:
  27. Paul
    Paul
    Editor
    that is fast
    and dig the Ross heads!
    panhead_pete, Sharpone and mad mikey like this.
  28. silent rick
    silent rick
    didn't look close enough to even notice,
    sneaky
  29. swifty
    swifty
    That's gorgeous and those Hildebrandt valve covers are the icing on the cake.
  30. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Indeed nice/ different.
    Paul likes this.
