Hot Rods Bringing the Scotty’s T roadster back from the dead
Discussion in 'The Hokey Ass Message Board' started by Russco, Apr 5, 2025.
  1. Russco
    Russco
    from Central IL
    Well, I’ve been pondering and researching this deal for several years, life got in the way as it often does. I’m finally ready to start the build to bring this iconic Hot Rod back from the past with a complete build from nearly scratch. It’s a great car that was originally built as a club project and with really fine craftsmanship and nearly everything was chromed. I’m going to build the injected only version for now because I just think it looks great, but I have the chain driven blower set up if I want to add it later..
    . I’m going to need A LOT of help Identifying the parts in the pictures if possible then, finding these vintage parts. I’m gonna need a lot of advice, building tips and support to pull this off. I’m hoping to maybe work out a partnership agreement maybe with someone that can help out with the build someway in return to put it on display in a museum or shows or something. I dont know if that is anything people normally do But I’d like to try that.
    My first issue is to lay out and build the chassis. I need to source some elliptical tubing for the main rails so far I haven’t been able to find a good source for that yet. Doing the research I’ve heard they frame rails came from PBY-5/6 wing struts. Other research just says it was tubing designed for wing struts on planes.. I need to determine the approximate wheel base which I can’t find any mention of so far in my research but I’m guessing it’s approximately 110” give or take. So right now I’m on the hunt for this tubing to just get the ball rolling. I have many many vintage parts to still locate but I’ll get into that as I go.
    I’ll post several of the pictures I have of it and hopefully I can get some input as to wheelbase estimates and any other details that need to be. sorted out.
    oddly another thing I’ve learned doing research is that even though this car was only on the scene out in California for what I believe to be 2-3 years, I’ve discovered it had 2 different paint schemes and was ran mostly with the 12” Magnesium midget wheels on front, but it also had some other taller spindle mount spoke wheels briefly.
    here are the pictures, first priority it to source elliptical tubing that’s approximately 2x4 inch and .085 or so although the thickness isn’t as critical.
    Wish me Luck I’m gonna need it……
  2. catdad49
    catdad49
    Those Pipes! Good Luck on your Treasure hunt.
    mad mikey, chryslerfan55 and hrm2k like this.
  3. hrm2k
    hrm2k
    I got to help with the Carrillo roadster restoration some years ago. It had elliptical frame rails which, according to Carrillo were wing struts from a WWII PBY. Only a reference, here is a shot of those frame rails during restoration.
  4. continentaljohn
    continentaljohn
    That would be an awesome build Mike and look forward seeing it built
    I have 3 of the 12 inch magnesium Halibrand wheels . They are 6 pins yet and not sure what your Dad ran 5 lug or 6 pin.
    mad mikey and chryslerfan55 like this.
  5. Stan Back
    Stan Back
    Here are some photos that you might already have some of . . .
    National Queen.jpg Scotty's Muffler Naked-04.jpg Scotty's Roadster.jpg 23 Alton.jpg 23 Bare.jpg 23 in Alton.jpeg 23 Roadster Colton.jpg 23 Roadster Riv..jpg 23 Roadster Colton.jpg 23 Roadster Riv..jpg National Queen.jpg 23 Roadster Riv..jpg 23 Roadster Riv..jpg 23 Roadster Riv..jpg Scotty's Muffler Naked-04.jpg National Queen.jpg 23 Alton.jpg 23 Bare.jpg 23 in Alton.jpeg 23 Roadster Colton.jpg 23 Roadster Riv..jpg
  6. Stan Back
    Stan Back
    . . . sorry, I can't eliminate the duplicates in my electric machine. Well, she's okay to look at a few times.
    The best of the features, in my opinion, are the 12" wheels and the out-the-back exhausts which I was told were modified Ford torque tubes -- which I doubt is true.
  7. Russco
    Russco
    from Central IL
    Thanks! That’s the same tubing alright, as well as the aircraft seat I will need to one up with as well
    catdad49, hrm2k and mad mikey like this.
  8. Russco
    Russco
    from Central IL
    Hi John good to hear from you! They were 6 pin on the fronts. I don’t have the hubs or any of that yet. I believe the spindles it used are 32-34 ford spindles. Mel and I were talking the other day. I was hoping maybe you’d have some stuff and maybe we could work out a deal I still have that 34 pickup cab, grille, doors and tailgate.
    catdad49, mad mikey and chryslerfan55 like this.
  9. Russco
    Russco
    from Central IL
    Thanks for posting those! Yeah , I have all those and just a few more and I believe that’s about all that are known to exist . The one on the trailer is taken here in Springfield Illinois when the car was sold to Bob Baugh who was a buddy of my Dad. The car worked its way around here for a few years, then was sold off in pieces and now most of its whereabouts are unknown.
  10. Tim
    Tim
    from KCMO
    What a wild car! Looking forward to seeing this coming to life. If you can swing an injected Ardun I’m sure you’ll be able to find some old plane parts :) this is gonna be good!
    mad mikey likes this.
  11. lurker mick
    lurker mick
    Its always been one of my favorite cars, so I have saved a bunch of pictures of it. Here's what I found so far.
    You may have already seen these but they are cool anyhoo.
    Mick scottymuffler@show1.jpg ScottysMuffler&TrophyGirls.jpg scottysmuffler1.jpg scottysmuffler2.jpg
  12. lurker mick
    lurker mick
    Some more
    Mick
    ScottysMufflerOnRun.jpg scottysmufflerrdstr.jpg scottysmufflerrdstrardun.jpg
  13. lurker mick
    lurker mick
    Even more.
    Mick
    ScottysMufflerT&Model.jpg ScottysMufflerT-1958.jpg ScottysT-RoadsterOnTrailer.jpg
    Deuces, Spooky, catdad49 and 2 others like this.
  14. Stan Back
    Stan Back
  15. Stan Back
    Stan Back
    51 mercules, 51504bat and catdad49 like this.
  16. Russco
    Russco
    from Central IL
    catdad49, mad mikey and Tim like this.
  17. deucemac
    deucemac
    The oval tubing may be a problem. I would contact aircraft supply companies that handle restoration structural supplies.
  18. 1biggun
    1biggun
  19. Russco
    Russco
    from Central IL
    I talked to a steel manufacturer in Louisiana yesterday that said they can make it but it’s 3000. Minimum to tool up for a run and then they are 8 weeks out.I have a guys number in Oregon that says he has a couple old damaged PBY struts that may be viable still. I’m still tracking down suppliers for the tubing.
    catdad49 and mad mikey like this.
  20. Russco
    Russco
    from Central IL
  21. mad mikey
    mad mikey
    A lofty undertaking to do this build, you have my deepest respect to take this on. This is now in my opinion about the greatest builds on the HAMB. Keep us posted.
  22. 1biggun
    1biggun
    Ouch on the cost .
  23. Awesome will be following along.
    Ken Crawford photos
    @hudsonjoe49 Got any PBY Struts?
  24. catdad49
    catdad49
    The more pics I see, the more I love this car! Is thread on it's known history anywhere? I don't think I have ever seen the blower pics before, Thanks all for sharing.
  25. RodStRace
    RodStRace
    For the tubing, there are airplane junkyards in SE AZ that might be a source.
    I don't know your skill level, but it might make more sense if you haven't scaled the pictures for measurements to build a wood frame and hang the components first, then once stuff is positioned in place, fab up the real frame.
    You might want to try to set up the pics in one folder showing it by time, too since it went through variations.
  26. Stan Back
    Stan Back
    Bob Baugh musta liked white Model T drag roadsters built in San Bernardino -- he also purchased two (I think) from the famous Heidelberg Speed Shop.
    51504bat likes this.
  27. Russco
    Russco
    from Central IL
    Yeah he must have, I was just a kid but remember that car well, Bob was buddies and ran in the same group of guys with my Dad. That’s how my Dad ended up with the Ardun from the Scotty’s car, which I’ve inherited, otherwise I’d never attempt this deal. I have this pic of Bob with another of their buddies Don Hughes “Hughsie” they called him, that drove the Heidelberg car. He ended up loosing a big chunk of his foot in a clutch explosion in that car. That car was wildly popular around here for many years and went through 2 or 3 transformations getting longer each time. Bob is on the left Don is on the right.
    Deuces, lurker mick and Stan Back like this.
  28. seb fontana
    seb fontana
    from ct
    Why do I think Green Hornet?[​IMG]
    Deuces and 51 mercules like this.
  29. Bluestreak-PA
    Bluestreak-PA
    from Erie, PA
    November 1957 Hot Rod Magazine:
  30. hudsonjoe49
    hudsonjoe49
    51 mercules likes this.
