Hot Rods Picked up a neat 327 stroker..Does anyone have a Howard's Cams catalog?
Discussion in 'The Hokey Ass Message Board' started by Black Panther, Apr 5, 2025.
  1. Black Panther
    Black Panther
    from SoCal
    So picked up a neat 327 engine.. was told it was a 383. It has TRW 2278 pistons which appear to be a 9/16ths stroker as they called it. 3.562 stroke. Weird thing is that it has a 2680 steel crank..can those be offset ground that far? Has plenty of balance weights added to it. Oil pan rail area has been clearanced...and a main girdle added.
    Anyway...has a Howard roller cam...might be pretty old build..60s? Does anyone have specs on it?
    20250404_182851.jpg 20250404_182847.jpg 20250404_182841.jpg 20250404_182843.jpg 20250404_163711.jpg
  2. Tim
    Tim
    from KCMO
    The 365/360 is most likely a hp/tq estimate I don’t see that on any Howard’s cams that come up so I’m going to say it is a similar grind to a performance Chevy cam aka the same as a 365 hp 327 factory motor and that’s how it got marked
    Deuces, Just Gary and porkshop like this.
  3. JD Miller
    JD Miller
    show the oil pan pic
    porkshop likes this.
  4. Black Panther
    Black Panther
    from SoCal
    Tim...I doubt it...its a solid roller cam.
    Deuces and porkshop like this.
  5. Black Panther
    Black Panther
    from SoCal
    Don't have one. It'll have to have a big cutout in the side to fit the girdle no doubt..
  6. Tim
    Tim
    from KCMO
    Well it’s not a part number and it’s not lift numbers so it’s just a guess at what the number could mean
  7. snoc653
    snoc653
    from Iowa
    Is that crank cut and welded? If so that is scary. The 360/365 is probably lobe lift. A 327 normally had 300 or less lobe lift. You can put it in the block and measure the lift to verify. Put a degree wheel on it and identify the separation and overlap as well.
  8. Black Panther
    Black Panther
    from SoCal
    Tim...it could be lift numbers...multiply those numbers by 1.5 and you have something pretty rowdy. Just wondering if anyone has seen a similar cam..or markings
  9. Tim
    Tim
    from KCMO
    Hadn’t considered the 1.5 let me see if I can find the page of cams I found when I was first looking and I’ll link it.
  10. Black Panther
    Black Panther
    from SoCal
    It's possible. I just got it and it needs a lot of cleanup before I try to pull it apart..or something will break. It for sure has the TRW 2278 pistons..which are for the 3.562 stroke. Also they are 12.5-1 ! The guy was a sprint/oval track kind of guy and I read online the 9/16ths stroker was a hot thing to do back then. I ***ume that this was done before you could just buy a 350 crank. So pre 1967? I just don't know yet how they got that much stroke out of a 327 crank. I agree about the numbers on the cam..they must be lift. Multiplied by 1.5 it's 547 540. Pretty wild..but it is a solid roller.
  11. Tim
    Tim
    from KCMO
  12. Tim
    Tim
    from KCMO
    Using your numbers there are some options that are close on page 3 of the link. From what I gather they handle all the Howard stuff now maybe give them a call? Might be something out of production.
  13. saltracer219
    saltracer219
    Crankshaft Company, later Hank the Crank manufactured and sold thousands of welded strokers in the 50's through the 70's with no breakage problems. Properly done they are just fine.
  14. Black Panther
    Black Panther
    from SoCal
    Heads are cool too...462 casting camel humps..2.02s ported and screw in studs..
    Deuces, Just Gary, Toms Dogs and 5 others like this.
  15. big john d
    big john d
    from ma
    nice score l;eet us know more when you take it apart
    Deuces and Black Panther like this.
  16. Speed Gems
    Speed Gems
    I Didn't look up the piston part # but what's the bore? According to my old Jake's speed equipment chart if it's a "4 bore it's a 358 ci, if it's a "4/16 bore (.060 over) it's 369, if it's only .030 it's a 363 inch.
  17. Black Panther
    Black Panther
    from SoCal
    It looks like standard bore if you can believe it. I'm guessing this engine was built in the 60s..the block is 1966 dated..so it was a near new engine at that point. I think the 9/16ths stroker is commonly .030 over at least...ive seen references to 364 cubic inches. At standard bore its a 358 like you mentioned.. which makes me think this engine must have been built by 1967 or 1968 at the latest...because the 350 came out then. Why go through the trouble and expense to stroke a 327 crank when you can just use a 350 crank?
    Deuces and Speed Gems like this.
  18. Russco
    Russco
    from Central IL
    Those were very popular combination used in Dirt Sprint cars in the early 70’s did it have a rev kit in it too, that was about as stout as you could make a stock block back then. What block casting is it?
  19. Black Panther
    Black Panther
    from SoCal
    Its a 3853174 block...1966 dated. That type of racing is exactly what the guy was doing who built it. Just had the roller lifters in their bores...heads weren't bolted on..
    Russco likes this.
  20. M C Empson
    M C Empson
    Having worked on small block checks for fifty years thirty three of it full time in my own machine shop I have never seen that main girdle / cap arrangement. I think your first concern should be making an oil pan fit and seal! All the rest is straight forward engine work. Unless your planning on racing it you'll want to lose some compression and likely the cam.
  21. Fordors
    Fordors
    That girdle was only for the three center mains, Ron Hammell operated 10,000 RPM Speed Equipment and IIRC an early Champion Speed Shop fuel dragster had one of those on their SBC.
  22. jimmy six
    jimmy six
    My current Howard cam was ground in 1976 and its numbers were the lift at the cam. It was one that had been used from the late 60’s. My guess is those are intake and exhaust lifts at the cam. EZ to check.
  23. Black Panther
    Black Panther
    from SoCal
    Thanks for the great info. The 10,000 RPM lettering on the girdle looks hand stamped and primitive..so probably early. I guess they thought they had to restore some rigidity to the bottom end after scooping out the oil pan rail for crank and rod clearance.
    Deuces and Fordors like this.
  24. Deuces
    Deuces
    ....or check with a pair of calipers....
  25. The girdle was patterned after the units for 392 Chryslers. As has been stated, the 9/16's was very common, not just circle but drag racing also. The quickest way to get an idea of what the cam is: get a pair of v blocks to allow spinning the cam freely. Put a degree wheel on the front of it. Set up a dial indicator in a vertical plain on an intake and an exhaust lobe. rotate the cam and measure the cam lift and multiply by the rocker arm ratio. You can measure duration also but remember that a clearance ramp can affect readings.
    Russco and 19Eddy30 like this.
  26. Jmountainjr
    Jmountainjr
    Nice score! Too bad it sat around without much protection. Just a guess, but engine was probably set up to just slide under a 360 cubic inch cl*** and most likely on alcohol. Hope you are able to save it.
