Hot Rods Anyone know what this tool is for?
Discussion in 'The Hokey Ass Message Board' started by Fortunateson, Apr 5, 2025.
  1. Fortunateson
    Fortunateson
    81A4492C-0CC2-44D3-B0E0-9BCEC01760C1.jpeg AD42A70D-5274-43B1-8E5E-F4CEEE30E3A3.jpeg As the title states.... I was given this by an older gentleman but he couldn’t remember what he used it for.
    Sharpone likes this.
  2. tubman
    tubman
    With the square holes in it, my SWAG is that it has something to do with positioning early Ford spring shackles.
  3. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Ok - totally WAG -wild guess....wire wheel spoke adjuster / straightener.
    Sharpone and Stogy like this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Looks like the “handle” pivots??? If so it’s a wire bender.
    Sharpone, clem, Stogy and 1 other person like this.
  5. twenty8
    twenty8
    Agree. It would put a neat 90 degree bend in wire (or something???).
    Now, to work out what would need that 90 degree bend...?
  6. 49ratfink
    49ratfink
    I'd keep it on the front seat. looks like it would put a dent in someone's noggin.
  7. Fortunateson
    Fortunateson
    Well that’s exactly what I was thinking as well. I guess it’s a little like brake line bender but the square holes are still a bit of a mystery to me!
  8. Fortunateson
    Fortunateson
    Well I can think of one fellow I’d like to use it on...
    mrspeedyt and Deuces like this.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
  10. 5window
    5window
    I wouldn't trust any site that doesn't know "bolts" is a plural word so "What ARE carriage bolts?"
  11. JD Miller
    JD Miller
    how big are those rocks its laying on?
    Thats for bending concrete reinforcing steel (rebar)
    .:cool:
    Stogy likes this.
  12. Ralphies54
    Ralphies54
    I think JD Miller is correct, but just in case some dimensions please or at least lay a yardstick next to it.
  13. 41 GMC K-18
    41 GMC K-18
    Just my guess, the square holes are potentially for anchoring the unit securely to a surface, which potentially means that there is a piece missing, that fits the holes.
    Definitely need a yard stick or tape measure along side it to figure its size !
    Sharpone, 2OLD2FAST and Stogy like this.
  14. Stogy
    Stogy
    Are there any numbers or lettering identifiers on it an as mentioned size would help in the search...
    Sharpone and 41 GMC K-18 like this.
  15. TerryT35
    TerryT35
    from Minnesota
    Just a wild guess here.
    The handle for throwing clay pigeons ???
    Stogy likes this.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    A bed of rocks or weathered asphalt?
    Stogy likes this.
  17. It's a kickstand for a wood framed bicycle. Square holes match square nails.
    vtx1800, Stogy, Okie Pete and 2 others like this.
  18. Boneyard51
    Boneyard51
    And those aren’t carriage bolts! Carriage bolts have rounded top, those are flat top bolts!
    Bones
    warhorseracing, Ben38, Stogy and 2 others like this.
  19. So you can tighten down a carriage bolt and then realize that you can't remove the tool? o_O
    The 'square' under a carriage bolt head is there to bite into the wood to prevent spinning. A carriage bolt is never spun. Only the nut on a washer at the other end ever gets tightened with a wrench.
    I don't have a clue what the 'tool' is, but my uninformed guess is that it's not car-related because the wealth of historical automotive tool knowledge (aka: smart fellers) here on this site should have come up with an answer by now.
    Edit: Maybe it's a tool for taking the slack out when running new fence wire/barbwire?
  20. tubman
    tubman
    I think those are called "elevator bolts". Why? I have no idea, but that's what they were called when I bought some that fit my needs for a specific project.
  21. Flathead Dave
    Flathead Dave
    from So. Cal.
    Very uplifting answer.
  22. oldsmobum
    oldsmobum
    from SoCal
    Right here officer, this is the one.
  23. Fortunateson
    Fortunateson
    I’ll try to take a pic for scale. Interesting responses so far. Those square holes are bugging me!
  24. warbird1
    warbird1
    Elevator bolts are used on bucket elevators with rubber belts.
  25. squirrel
    elevator bolts generally have larger diameter heads, that taper out to nothing at the outer edge.
  26. 41 GMC K-18
    41 GMC K-18
    Looking at the handle, which appears to have this weird spline that runs the length of the handle.
    That really isn't designed to be comfortable to the hand that is going to use it to bend something.
    That spline may indicate that a cheater sleeve that fits the spline as an extension for greater leverage, was part of the original apparatus ?
    But if that is the case, then the handle doesn't have a lot of strength built into it, in the first place now does it?
    Until there are some better pictures of it from a variety of different angles, its going to be hard to pin it down as to what it is and what it was used for.
    The square holes may be an indication that potentially square spikes were used to attach it to rail road switching gear to move some type of switch, but I know that isn't it.
    Also potentially that its part of a fence mending kit, and its a temporary tensioner ? But fence mending tools/kits, usually have a small block and tackle with ropes and pulley's to hold tension!
    The mystery continues!
    Sharpone and Boneyard51 like this.
  27. lostone
    lostone
    from kansas
    My guess...
    Can't tell it's size so this is a WAG, bolts to a table with carriage bolts and then used to make chain links. Slide the rod thru then rotate the handle and bends one end, flip the rod then bend the other end..... there you go a link for a chain !!
    TERPU, Ben38, 41 GMC K-18 and 3 others like this.
  28. CSPIDY
    CSPIDY
    Looks like a regular frumsteader to me
  29. eaglebeak
    eaglebeak
    They are "elevator" bolts. Used for levelling certain objects.
    Boneyard51 likes this.
  30. 41 GMC K-18
    41 GMC K-18
    I noticed that no one has mentioned the small circlet of metal, in one of the square holes. It appears to have no function at all, other than to confuse us all!
    Everyone's results may vary greatly!
    lostn51 likes this.
