Technical Help ID'ing this Spindle mounted disc brake stuff
Discussion in 'The Hokey Ass Message Board' started by '52 F-3, Apr 5, 2025.
  1. '52 F-3
    '52 F-3
    from Central PA
    Just picked up this setup. It looks like a lot of it was once chrome plated at one time.
    Anyone recognize? Supposed to fit 42 -48 Ford spindles, will be testing this evening.
    Just Gary likes this.
  2. Hollywood-East
    Hollywood-East
    Look like Hurst GoKart calipers..
    seb fontana and '52 F-3 like this.
  3. '52 F-3
    '52 F-3
    from Central PA
    better pic of calipers...
  4. squirrel
    slightly different design from this one, but it does look similar
    and generally they put their name on their stuff.
    '52 F-3 likes this.
  5. 1971BB427
    1971BB427
    from Oregon
    The rotors look a little heavier than what I see on go karts, but calipers sure look like Hurst Aireheart stuff. Probably car rotors by Hurst also. Nostalgia buffs love the old Hurst stuff.
    '52 F-3 likes this.
  6. Dave G in Gansevoort
    from Upstate NY
    It appears your shop superintendent doesn’t approve of the setup. Send it to me, I’ll be sure that it doesn’t upset him anymore…
    Hey I had to try
    '52 F-3 likes this.
  7. Fordors
    Fordors
    '52 F-3 and squirrel like this.
  8. '52 F-3
    '52 F-3
    from Central PA
    casting looks likes the AIRHEART, cleaning up tonight...
    Screenshot_20250405_141834_Samsung Internet.jpg Screenshot_20250405_141913_Samsung Internet (1).jpg
    swade41, Just Gary and squirrel like this.
  9. '52 F-3
    '52 F-3
    from Central PA
    So, I'm thinking this isn't a m***-produced unit. Calipers have a little W inside what looks like the state California cast mark. The caliper mounting brackets, dust caps, rotor mounting hubs all have tool marks. Also looks like everything was Chrome plated, painted black and silver. Decided to let calipers soak a day before trying to push the pistons out.
  10. patsurf
    patsurf
    is the w for 'winters' foundry?
    '52 F-3 likes this.
  11. jamesgr81
    jamesgr81
    The W is probably Weiand Foundry.
    51 mercules, Just Gary and '52 F-3 like this.
  12. '52 F-3
    '52 F-3
    from Central PA
  13. patsurf
    patsurf
    yes--great call
  14. '52 F-3
    '52 F-3
    from Central PA
    I've got a mess going on here, black paint under thick grey paint... Chrome plated aluminum Hubs and Stainless Spokes are going to look great, but Rims aren't looking so good.
  15. gary macdonald
    gary macdonald
    I had these on an old altered . Problem , like many early calipers , the seal is on the piston . Whick means the sealing surface is on the caliper aluminum surface . Easy back in the dat , the bare calipers were $20 . Now you’re going to resleeve the calipers if pitted . I haven’t checked if they’re repops being made . Any shop that does the vette calipers should be able to do these .
    '52 F-3 likes this.
  16. Hollywood-East
    Hollywood-East
    I was sniffing around on kart/Hurst, These guy's came up, Do all kinds of vintage stuff.. I'd bet they can hook you up.. Screenshot_20250406_161929_Google.jpg
    '52 F-3 and Just Gary like this.
  17. '52 F-3
    '52 F-3
    from Central PA
    Would you believe each caliper has 34 pieces? All the pistons were stuck really tight, later realized it was due to pucks mushrooming. Maybe from a lot of heat?
  18. '52 F-3
    '52 F-3
    from Central PA
    Still cleaning laced (wire)wheels, I'm pretty sure they were made by "Hallcraft" but can't find a exact example. Got new O-rings/seals from a local hydraulic shop, they have an old school parts desk with tons of knowledge. They have build a few perfect "kits" for me over the years.
    swade41 and Fordors like this.
  19. '52 F-3
    '52 F-3
    from Central PA
    These wheels are being a pain to clean up. I now also think wheel hub is solid stainless steel.
    swade41 likes this.
  20. alchemy
    alchemy
    Are you going to take the wheels apart and rechrome the rim?
    '52 F-3 likes this.
  21. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Try CLR in a tray and let the wheel/rim sit in it. Rinse and repeat. I’ve seen orange cleaner /mixed with Awsome from Dollar Tree. Worked well on the chrome stuff from my 57. Not perfect but cleaned it up 300 percent
    silent rick and '52 F-3 like this.
  22. DDDenny
    '52 F-3 likes this.
  23. '52 F-3
    '52 F-3
    from Central PA
    Thanks for ideas, I did use some old brake fluid which worked pretty well.
    Plan is to just cleanup and either paint rim white or just clear coat once all cleaned/polished up.
  24. '52 F-3
    '52 F-3
    from Central PA
    Cleaned up pretty well, I plan to paint the rim and polish the stainless hubs and spokes. BUT, what color?
    I might just clear coat, but am considering white or red, or red,white &blue .
    vtx1800 and Tim_with_a_T like this.
  25. Fordors
    Fordors
    I vote for the clear coat.
    '52 F-3 likes this.
  26. '52 F-3
    '52 F-3
    from Central PA
    Ended up clear coating, ready to install on some 42-48 square spindles.
    Fingers crossed for true and close to balanced.
  27. Dave G in Gansevoort
    from Upstate NY
    Those came out looking pretty darn good.
