Hot Rods Custom intake manifold fabrication
Discussion in 'The Hokey Ass Message Board' started by 6inarow, Apr 5, 2025.
  1. 6inarow
    6inarow
    Does anyone make custom intakes? Specifically looking for someone to make a side draft intake for a Chevy 6. Any recommendations?
    tractorguy and Sharpone like this.
  2. gimpyshotrods
    gimpyshotrods
    Which Chevy 6, and which carburetors?
  3. Mike VV
    Mike VV
    from SoCal
    A few do, but not sure you would be interested in paying their price of entry !
    As YOU...should dive into the internet to do your own home work, they come right up, when Google is asked the question !
    Or, maybe "specify" that maybe someone within the HAMB group might be willing to help. MAYBE a slightly more friendly cost.
    Mike
    gimpyshotrods and Sharpone like this.
  4. manyolcars
    manyolcars
    I bought a 3/8"strip of stainless, used a hole saw and welded stainless J-bends. made my own manifold for my avatar
  5. brading
    brading
    Sharpone likes this.
  6. '52 F-3
    '52 F-3
    from Central PA
    Most small welding/fabricating businesses can make anything you can describe. Some will give you a (don't really wanna do price) but some will ***ist with a respectable hourly rate.
    If you can cut modify/build to the point that the welder only has to weld, it'll cost alot less $$.
  7. Not a side draft but interesting
    lake_harley, dana barlow and Sharpone like this.
  8. Early vets had em. Not cheap but probably cheaper than paying to have something built.
    Nickson made em as well
    dana barlow, Sharpone and Just Gary like this.
  9. brading
    brading
  10. Joe H
    Joe H
    Not a side draft, but heres one I am using on a 250. Nothing but hand tools, electric drill, jig saw, and mig welder. assembling intake.jpeg IMG_0957.jpeg IMG_0962.jpeg IMG_0981.jpeg IMG_1030.jpeg
    dwollam, Robdski, 39custom and 20 others like this.
  11. seb fontana and Sharpone like this.
  12. The 235/261 COE and step van intake could easily be converted to side draft
    If ya dont mind welding cast iron
    Had an updraft carb
  13. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Not the best pic but here is my Mercruiser 2 bbl manifold converted to side draft Carters.
    Time and materials type job. Message me if interested.
  14. Mr48chev
    https://www.hellsgatehotrods.com/ makes and sells intake or intake-exhaust flanges for straight six Chevys and makes carb flanges to help with intake fab. They will also sell you the tubing/bends to make intake or exhaust too. Screenshot (856).png
    GuyW, 40two and caprockfabshop like this.
  15. Stooge
    Stooge
    Are you opposed to just guessing your way through it? :rolleyes:
    A couple more inline cylinders than a 6, but same idea. I still need to do some finish welding and get it all polished up before it gets cerakoted along with the header but ive been dragging my feet and wanted to make sure i didnt need to add any provisions for fuel or gas pedal before it gets coated.i think the intake stuff starts around page 10 of the thread in my signature
    IMG_4638.png IMG_4640.png IMG_4641.png IMG_4642.png IMG_4643.png IMG_4644.png IMG_4645.png IMG_4646.png
    That's where i got the intake and exhaust flanges from for the straight 8 stuff. i also bought some carburetor flanges but i ended up using some that i made.
    Robdski, GuyW, Deutscher and 13 others like this.
  16. willys36
    willys36
    Posted elsewhere but here it is again. Equal length 180deg 4bbl intake I cast for the 230/260 series Chevy 6.
    P8150025.JPG P8150026.JPG manifold 12.jpg manifold 1 - Copy.JPG manifold 3 - Copy.jpg manifold 4 - Copy.JPG manifold 6 - Copy.JPG manifold 7 - Copy.JPG manifold 9.JPG manifold 8.JPG Intake Manifold.jpg manifold 10.jpg manifold 11.jpg pontiac_3..JPG
    GuyW, RatPwrd, Deutscher and 12 others like this.
  17. 6inarow
    6inarow
    Weber side drafts. I cant find anything on google.
  18. 6inarow
    6inarow
    235/261 with Weber side drafts.
  19. gimpyshotrods
    gimpyshotrods
    Two twos? Three twos? Three singles?
  20. 1952henry
    1952henry
    outstanding work!
    Stooge likes this.
  21. gimpyshotrods
    gimpyshotrods
    Cosmo49 and 6inarow like this.
  22. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Or, get any old aluminum manifold, plate off the inlet(s), fab up a couple of flanges, weld them on and Bob's your Uncle!
    This isn't rocket surgery :eek:
  23. Damon777
    Damon777
    You guys have inspired me to build the intake for my '50. One question. Did any of you guys account for the engine angle. I know the carb is level on the stock intake, and they do it with the runners. That was my hangup, but I think I could deal with that building an intake like Stooge's.
    I already have all of the stuff from Hell's Gate, it's a matter of getting over my own trepidation.
    Stooge likes this.
  24. RMR&C
    RMR&C
    from NW Montana
    The intake(clifford) on my 300 six is flat. I made a thin wedge spacer to level up the carb. You could weld on the carb bases on at any angle you want. That's how I'd do it
    GuyW likes this.
  25. Joe H
    Joe H
    When I made my intake, I used the exhaust manifold as a guide to set the level of the intake. I did set the carbs at the same hight knowing I was going to use one large air filter, but there is very little difference in them.
  26. brading
    brading
    Please post pictures and a write up of your progress.
  27. Stooge
    Stooge
    I didnt add any angle to my intake for the carburetors. From the Edmunds Customs intake i used as a concept, and the Howards 6 carb intakes i have seen for straight 8's, neither had risers on the rear carbs. I have a couple of factory dual carb intakes for the smaller straight 8's with the carburetors still on them, and the rear most carburetor is slightly higher than the front, but i believe it is a fairly minimal difference. Let me know if i can help with anything. the homemade one wasnt as easy as it looks, and between that and the exhaust header, i do have many many hours in to it, but it is doable
  28. Jmountainjr
    Jmountainjr
    You didn't mention if you had a material that you preferred. If you are ok with mild steel, between thick flanges and bent tubes available it's not super hard and does not require complicated welding methods. Stainless is a significantly more complicated welding process as the tube should have purge gas inside while welding. You can build all of that, but will also need to be a proficient TIG stainless welder. Go with mild steel and try it yourself, or with some help from a buddy.
  29. Damon777
    Damon777
    I am probably going to end up with a build thread soon. Re-wiring the car and doing a bunch of other stuff on the cheap.
    I have one of those dual carb intake/exhaust manifold setups. Snagged it last year at a swap meet. I believe that there is some angle on the pot metal riser for the rear carb. I can't use it on my car without modifying the motor mount as the exhaust manifold wants to occupy that space.
    brading likes this.
  30. Hotwyr
    Hotwyr
    I'm not 100% sure, but I think Cliffoed used to make one. I seem to remember seeing it in an older catalog. Good luck in finding one though. Have you seen the one that D-Russ built for the HAMB special land speed truck for a GMC?
    1Nimrod likes this.
