Projects 54 Chevy 210 custom "THE ORPHAN"
Discussion in 'Traditional Customs' started by The Chevy Pope, Feb 26, 2024.
  1. Walk-around talking some ideas
  2. First thing today after sticking a few more body mount bolts in is I traded the old 235/70s that came with the car for a pair of roughly equal condition 215/70s. Not actually going to run them but I always prefer to have a project car on the size tire I'm going to run. Driver front wheel will get painted blue and get used in the car while the p***enger front will get painted red and used on the 53 IMG_20250409_153632_HDR.jpg
    Okie Pete and Tim like this.
  3. And moved on to some of the bodywork. Got the smashed part of the quarter mostly knocked out. Actually think I'll be able to get the tail light fixed reasonably easy enough not to justify cutting out and replacing metal. Am thinking I'll get a lower rocker patch. Also got most of the dent out of the roof IMG_20250409_161049_HDR.jpg IMG_20250409_161056_HDR.jpg IMG_20250409_160922_HDR.jpg
    tb33anda3rd, Okie Pete and Tim like this.
  4. Interesting way of lowering but I kinda dig it. Seems like it'd mess with upper arm angle less IMG_20250409_153640_HDR.jpg
  5. Stuck the steering box in it. Still need washers and the u bolts where it goes to the dash IMG_20250410_165455_HDR.jpg
    Tim likes this.
  6. fastcar1953
    fastcar1953
    You will have it running in no time. Body doesn't look to bad now.
    The Chevy Pope likes this.
  7. Naw. Once the hammers started swinging progress started happening. Side note a nickname that has followed me to every job I've been at despite the job having no knowledge of my previous job is Thor because of how I am with a hammer lol.
    Anyway going to stock up on hardware and rubber so I can securely mount to the frame. Yesterday I saw what you were talking about on the body mounts. Going to make them myself with generic bolts instead of buying a kit. Seems just as easy and a lot cheaper. And going to work on getting at least the front brakes functional on it. I know you said they were probably the wrong rotors but when I had the wheels off yesterday they seemed to fit really well. And under the surface rust looked like replacement rotors. And the bearings were adjusted right and smooth. Going to test fit a caliper and go from there. Basically the vibe I got of my boss is if it rolls, stops, and steers he probably wouldn't care if I pulled it in the shop to do stuff like paint the roof and dash and drop the engine in. So that's kinda my immediate goal lol
    Lone Star Mopar and fastcar1953 like this.
  8. Something else I'm thinking is on the firewall instead of welding up all the holes I'll get some sheet metal and skin the hole thing in sections.....at least the flat parts. Make for a cleaner look with a lot less work. Not to mention an extra bit of insulation/sound deadening. About the only holes I'll need that aren't already being used are for the heater hoses and for the main harness to come through. And I can cut for the heater hoses later on after paint
    fastcar1953 likes this.
  9. And because it's easier to get my phone to upload a video instead of take pics I took a video of how close I have this thing to fitting a tail light
    Tim likes this.
  10. Decided to make a checklist of modifications I'm doing for sure the first time around on this car lol
    -nosed and decked
    -louvered and peaked hood
    -shaved side trim
    -shaved gas door
    -frenched antenna
    -55 Chevy rear bumper
    -50 Oldsmobile door handles
    -obviously lowered lol
    -lakes pipes
    -grill but undecided on exactly what I'm doing....want 54 Pontiac but haven't secured one yet
    -58-60 t bird center console
    -partially shaved lower dash
    -**** rear deck
    -license plate frenched into decklid
  11. So I think after I get the body securely bolted to the frame Im going to hyper focus on bodywork and paint on the roof and dash. If I knock that out I can work on getting gl*** in it. With gl*** in it I'll have a bit more flexibility on how I store it. As to where it's currently sitting I can run extension cords to it to run grinders and compressors. So it's doable where it is.
  12. Tinkered a bit more today. Also worked the quarter a bit more
  13. fastcar1953
    fastcar1953
    Making it look easy.
    Did that fall off a lift or what? :p:p
  14. Way I'm doing actually makes it easy. Do about 20 minutes of work over a period of two hours lol. Though that driver door has inexplicably fought me more than any other door I installed lol. Next time I wrench on it I'm going to set out to get the best gap possible on that door so I can focus on roof paint prep lol. And honestly it was in good shape considering what happened to it. Like all the body mount holes still lined up nicely
  15. fastcar1953
    fastcar1953
    Weird the way the driver door fits. I guess when it went between the lift arms and got the b pillar it pulled it back at the top. When it hit the gutter I'm guessing that didn't help.
    Might check for square.
  16. I think I just need to rotate the whole door slightly clockwise. That side is on an awkward spot you really can't tell in the video. Meanwhile p***enger side is easy to work around. Also I looked it over pretty good. I didn't see any evidence of stress cracks that'd pop up in enamel paint if the roof or pillars had flexed or warped. And like I said it fit nicely on the frame. Iirc you told me you gave me the best pair of doors. Judging by the primer and splashes of blue on the doors I'm guessing the p***enger is original. Would I be correct that the driver side isn't? This era car wasn't known for spectacular panel fitment. In fact when I bought my 53 I ***umed it was a 210 someone stuck bel air stuff on based off how the trim aligned and the fact the bel air emblems weren't exactly straight. Nope. Just 1953 gm fit and finish standards and it was an actual bel air lol. And honestly I'd rather **** with fitting a non original door than deal with rust. And that door is nice. What really surprised me is how quiet the hinges are on this car. If you notice no noise when I open the doors in the videos. Meanwhile you look at a door on my 53 and the "SCREEEEEE!" that anyone that's been near a 50s Chevy has heard happens audible three blocks away lol
  17. fastcar1953
    fastcar1953
    Both doors came off the 54 I have. I kept mine off your car. I already shaved the handles.
  18. So that may have been the fluke of the draw then. We'll just blame 1954 gm tolerances lol. In any event it's all reasonably solvable. I'll hop back on it in the next couple days
  19. Example of what I was talking about on the factory tolerances. My 53 has never been wrecked and this door has never been so much as loosened. But as you can see there's a slightly wider gap at the top IMG_20250416_075821_HDR.jpg IMG_20250416_075830_HDR.jpg
  20. So I'm back debating shaving the door handles again lol. I should mention if I do I section in a similar patch on the driver side instead of welding in round plug patches. I feel like it'd be a better finished product
  21. So yeah I've decided to go ahead and just shave the handles. And since I haven't come up with a solution for door poppers with the current latches I'll likely go ahead and swap to bearclaws. After my 53 I'm honestly tired of 49-54 Chevy door latches lol. I'll eventually modify the 53 to use the said olds door handles
  22. And by a fluke of finding a 54 the same color scheme and stance I'm planning only more stock along with another member helping with some quick and dirty Photoshop I think we have the best visual yet lol. Obviously mine will have less trim and end up with both scallops and metal flake Untitled_Artwork (4).jpeg
  23. So another solution to the filler neck with the gas door shaved. Ignore the wheel tubs because those WON'T happen in this car lol. But I'm thinking the mustang tank is the trick. One it's a lot cheaper. I'm already Frenching the license plate into the trunk. Think Ill hinge the plate in the recess and have the filler come in through an alcove behind it. Screenshot_20250418-164108~2.png
  24. Weekend weather put a damper on progress. But hoping for a window in the rain to get the paint/shave panel cut out for the p***enger door. If window is long enough I might get both cut out lol
  25. @fastcar1953 wow I guess I got lucky on the quarter damage. Just saw this on a FB page on a four door for sale. Don't think I'd even try to hammer that out. Cut and replace lol FB_IMG_1745550560452.jpg
  26. Still gotta price sheet metal that large. May end up harvesting from a hood lol
  27. And weekend wasn't a total waste. Made the first door handle patch/shaving plate. Used a spare driveshaft and a small ratchet strap to put the curve in it that I matched against the conveniently located 53. Thinking even though this area is solid on the driver door I may have it the same way as I'm thinking it'd be easier and cleaner than cutting and fitting and welding two small circles. Not to mention I could adjust the door gap at the same time IMG_20250427_123045_HDR.jpg IMG_20250427_123104_HDR.jpg
    Lone Star Mopar likes this.
  28. Motivation on this project is steadily increasing even if actual progress isn't significantly lol
  29. Tim
    Tim
    from KCMO
    I’d love to try to pull that fender straight. Make the car anchored and strap a winch to a near by tree lol
