History FOUND- Nick Arias Jr.'s '37 Chevy Coupe
Discussion in 'The Hokey Ass Message Board' started by Justin Arias, Jun 28, 2023.
  1. dirt car
    dirt car
    from nebraska
    Thanks, I'll need to ck. my achieves as I do have some info when the Iowa individual, I spoke of years ago happened to be visiting the Ch***is Engineering facility during my visit, if in fact the same guy. Thanks, Ron
    chryslerfan55 and porkshop like this.
  2. gas pumper
    gas pumper
    Ha! I thought these looked familiar..... If we can successfully run Loring LTA in July we will bring these rods and pistons to Bonneville in our '46 GMC XO/PP ..... and when you finish the Coupe, It can probably be run at a safe speed at LTA, the mile and a half timed run on a 2 1/2 mile runway has "common sense" safety rules based on the anticipated trap speed. Frank
  3. tractorguy
    tractorguy
    Would love to see any info you can find on the guy and whatever Iowa connections there are.
    porkshop and chryslerfan55 like this.
  4. alchemy
    alchemy
    Would you guys be talking about 12 Port Charlie from Nevada, Iowa? He was well known in the 70’s to 80’s for working on sixes. When I met him he had a long beard. Was in a wheelchair.
    porkshop, chryslerfan55 and Thor1 like this.
  5. uncleandy 65
    uncleandy 65
    Why does it have a 38 grill shell on it?
  6. jimmy six
    jimmy six
    Charlie Baker was one of the first members of Inliners International. I stopped by his shop in Nevada Iowa on a vacation once. He was casting and repoing a lot of parts at that time. I believe he was casting the Wayne F. Horning head for the GMC’s. I believe Don Ferguson has those patterns now. Charlie gave me a set of the Horning blue prints with all the dimensions figure and I gave the set to Don a few years ago. Not too much call for all of this now days and costs to reproduce is very high.
  7. benchseat4speed
    benchseat4speed
    from Golden, CO
    Justin,
    When did John L. Crockett p*** away? Amazing you were able to get ahold of his old s****book and that jacket! Any other stuff from his estate related to your car?
    Where is the head leaking from, is it repairable?
    This thread is outstanding, man. Keep up the great work, appreciate all the updates.
  8. Justin Arias
    Justin Arias
    Still trying to figure all that out. The body has the darker original yellow color underneath it, but the grille shell and front fenders do not. Still a mystery.
  9. Justin Arias
    Justin Arias
    Thank you sir. John p***ed away on Christmas day, 2013. He moved to Sacramento in the 2000s sometime, and I have no idea what happened to any of the remaining cars and engines he owned at the time. Apparently he was a pretty big inline 6 collector and ended up making some wild engines with custom OHC conversions etc. Just recently, a friend of mine from WA purchased a 228 (I think) GMC with a homemade OHC conversion out of a stock head from a racer here in SoCal just a few months ago. It's crazy how stuff is still popping up after all these years.
  10. flyn schlosser
    flyn schlosser
    from Elko,NV
    This is just awesome history I can't wait to see.more.updates
    Justin Arias and porkshop like this.
  11. Justin Arias
    Justin Arias
    The LaSalle is finally done getting machined, hot tanked (dishwasher) and prepped for final ***embly. I got this case from local hot rodder Augie Esposito that was already modified for closed drive Ford, so the remaining work consisted of minor, but tedious, upgrades that'll help this thing live longer but more importantly, seal better. The shifter shaft hole was counter bored deeper for a press in lip seal and chamfered the rear cluster shaft bores for o-rings, and the rest of the work went into the internals, gears, and a bunch of custom parts that no one makes any more. For as simple as these transmissions are, this one was a task!
    Next step is to have Ken McAlister spline the main shaft for me and it's ready to go together.
  12. Justin Arias
    Justin Arias
    Some solid progress being made. I'm having the clutch rebuilt and installing a steel insert into the flywheel like your typical aluminum type today. This one was just bare aluminum with some sort of face coating direct to the clutch and it did not like it, so it's getting a little facelift to allow me to drive it without worry. Ken McAlister has cut the Ford splines into the LaSalle main shaft for my Lincoln Zephyr u-joint, and I've been busy machining the rear mount for Cad bearing and other little miscellaneous things. I'm also very excited to finally run my sweet GM-LaSalle adapter by Cooks Machine in LA. My grandpa used to frequent Cooks, so it's cool to continue using period correct parts from the same area. New (old) center caps were added to the stock front wheels with a little adjusting of the retaining clips and they now just need to be wrapped in the correct Firestones to get the look. I've also begun the process of rebuilding the Strombergs, first of five. Tuning these will be a chore, I'm sure.
    Slowly but surely...
  13. Justin Arias
    Justin Arias
    Got the LaSalle ***embled last night with my girlfriend and everything went pretty well! There's a lot of custom work in this thing and it's nice to see them all working together as a whole. On to the next!
  14. stuart in mn
    stuart in mn
    ^ That's pretty enough to put on display in the living room. :)
  15. patsurf
    patsurf
  16. Baumi
    Baumi
    Wow, that came out nicely! You are doing a great job!
  17. Justin Arias
    Justin Arias
    I like that!!
    ct1932ford and porkshop like this.
  18. Justin Arias
    Justin Arias
    Thank you very much. This car is deserving of giving my best effort. Just can't make anything look too new, which is sometimes hard for me. o_O
  19. Silva
    Silva
    Thank you for your effort to chronicle the history and preservation process. This is such a remarkable story.
    chryslerfan55, porkshop and RatPwrd like this.
  20. ct1932ford
    ct1932ford
    So this Rusetta timing tag is on the Auburn dash in a 32 Five Window I bought some years back. The coupe was owned by Dwayne Rogers who supposedly was a friend of Kenny Bigelow. I'm trying to find out if Bigelow owned this coupe or Rogers just snagged the tag. Its dated the year before Bigelow died.
    Looking for history on this coupe. IMG_3685.jpeg IMG_8353.jpeg IMG_8351.jpeg IMG_8352.jpeg
  21. ct1932ford
    ct1932ford
    Talked with Dwayne Rogers yesterday. He did not remember where he got that tag. He knew who Ken Bigelow was but did not him personally. So no story here.
  22. Justin Arias
    Justin Arias
    An amazing discovery to the project- a short video clip of the coupe at Bonneville in 1954! My dad texted me the link to this video on Friday and it absolutely blew my mind. Never would I have expected for there to be film of this car out there, and in color no less! The ***le says 1953 but this clip is from 1954, running in B Coupe with an injected Wayne Chevy on 50%.
    Also shown at 4:24 is the yellow "Maedel Specialties" '29 roadster of Danny O'Brien that was powered by an injected 12 port GMC on Nitro, built by my grandfather. This car became the beautiful, Iris Blue Yeakel Bros. roadster the next year with its famous Von Dutch artwork on the grill, accidentally painted upside down. I have quite a few pictures of both the coupe and roadster together, so it's really neat to see them both in the same video.
    On the way to Bonneville in '54, owner Danny suffered a bad towing accident which resulted in a broken ankle and a banged-up truck and racecar. They managed to get the roadster there and repaired enough to set a 2nd cl*** speed of 167.28 mph, but unfortunately burned the pistons out of it and got their money stolen somewhere along the way to add insult to injury. They were presented the "Hard Luck" award by Wally Parks, and it was even featured in Hot Rod mag in the fall of 1954. Danny unfortunately p***ed away in June and I was never able to meet him, however I have recently been in touch with his son and will be attending his service next month. Dan Jr. has been sharing some amazing photos of the roadster with me which I will post below.
    Coupe shown at 4:00, roadster at 4:24.
    Few photos of the Maedel Specialties '29 roadster.
    Making some repairs in Wendover. This is by far my favorite photo of the coupe that I have. It represents everything these guys were all about back then.
    GMC "By Nick".
    Grandpa, third from left, smiling at camera.
    Repairing the roadster & trailer in Wendover. Danny O'Brien is behind the car with crutches after injuring his ankle in the towing accident.
    "Hard Luck" award presented by Wally Parks.
    As seen the next year in 1955.
    "Best Appearing Crew" award, 1955. Grandpa Nick on far left, Bill Likes, Danny O'Brien, Don Rackemann, Jo Rackemann, Rich Rackemann, Nick Matranga, Lou Baney and Ted Evosavich.
  23. jimmy six
    jimmy six
    Neat photos. I spent quite a bit of time talking to Don Rackemann the last few years of his life about his escapades in Bonneville, Lakes, and drag racing. He had a lot of stories to tell. I was smart enough to know not to get involved with any of his “investment's” . The transmission in my 56 for was one he left at Art Carrs for rebuilding and never came back for. I don’t think missed it! I remember the hours I spent with your grandpa either ordering pistons or just stopping by to yak. He was always one to help out the single owner/driver guys….
  24. benchseat4speed
    benchseat4speed
    from Golden, CO
    Outstanding update! Outstanding photos and film too!! I hope Ben Kahan makes another video on this car, progress update or something for his channel. I've watched the first one a few times.
    porkshop likes this.
