Hot Rods No diesel oil
Discussion in 'The Hokey Ass Message Board' started by proartguy, Apr 8, 2025.
  1. proartguy
    proartguy
    from Sparks, NV
  2. Oh boy, is it that time again?
  3. tubman
    tubman
    I've always wondered why some people insist on using a product recommended for uses it was not designed for.
    Perhaps the panache of diesels, you know, those broad-shouldered semi-trucks pulling incredible loads through the Rockies, driven by brawny, ruggedly handsome teamsters?:D
  4. HOTRODNORSKIE
    HOTRODNORSKIE
    You can find oil for cl***ic cars all over the place now a days so why use diesel oil in your vintage motor.
  5. FrozenMerc
    FrozenMerc
    If your flathead developed a rod knock in it's first 50 miles after a rebuild, that probably has nothing to do with the oil, and is much, much, much more likely due to incorrect machining, contamination, defective parts, or something else a human did wrong. In other words, prove it - show me root cause.
    Yes, Diesel Oil has about twice the amount of detergent additives as gasoline engine oil, and generally speaking the same levels of wear preventatives like ZDDP and phosphorus. It has also been proven that those extra detergents do negatively effect how the wear preventatives work and interact, specifically causing an increase in cam wear, especially in flat tappet applications.
    But, our love of over carbureted antique engines with large duration bump sticks and inefficient combustion chambers (flathead guys - stand up) causes our engines to produce much more soot and sludge than a modern direct injection gasoline engine. For this reason I would argue that running diesel engine oil in our antiquated junk is not nearly as detrimental as it would be in your wife's 2024 2.0L something or the other.
    At the end of the day, just use the right oil.
  6. Jack E/NJ
    Jack E/NJ
    from NJ
  7. 1971BB427
    1971BB427
    from Oregon
    Diesel oil was what guys ran to when a lot of newer oil became lacking in zinc. But diesels also got catalytic converters so they eliminated the zinc from diesel oil also. Why people don't just buy oils designed for older engines instead is beyond me. Oil is cheap, and rebuilds aren't. Plus they take time I don't want to spend doing them.
  8. squirrel
    Where did he say it was a fresh rebuilt engine?
  9. Bleach
    Bleach
    I haven’t seen any oil designed for older engines in my area. There’s a few choices for higher mileage engines but nothing else.
    bob b. likes this.
  10. proartguy
    proartguy
    from Sparks, NV
    Some clarification - when I bought the car the previous owner said he probably drove it about 5,000 miles over several years. When he purchased the engine he took the pan and intake off and said he said it looked like it had been rebuilt. I drove it a couple of hundred miles and changed from the 50wt that was in it to 15/40 Rotella. After 50 miles it had a knock. Looking over the engine after it was apart everything was great except one rod. The previous owner was quite surprised at what happened and offered to help me out.
    A friend sent me a link later to a article about why diesel is not a good idea so I have continued to look for information and found the video to quite informative. This is only my experience, and I suggest watching the video I included in the first post for the scientific explanation.
    Full floating rod bearings. Delaminated on the crank side and worn on the rod side. Measurements are the bearing 2307805849371302119.jpeg
    Ziggster likes this.
  11. squirrel
    I wonder if the 50wt that was in it previously contributed to the rod bearing demise? it's hard to get that stuff moving when it's cold....
  12. The 50wt kept it quiet?
    Fixing to dig into one that’s had 15/40 diesel oil since we built it. Not for repairs, changing up some things for its new home. I’ll check cam lobes.
    Probably 35- 40k miles on the build.
  13. '29 Gizmo
    '29 Gizmo
    from UK
    You didn't say if you were running any kind of filter. Detergent oils need a filter to remove soot. Non detergent oils led it settle as sludge in your pan
  14. oldsmobum
    oldsmobum
    from SoCal
    That video spent most the time explaining different kinds of fuel injection, and then goes on to explain how you shouldn’t run diesel oil in a direct injection engine, which almost no one does, because near zero have flat tappet camshafts.
    Clickbait ******** trying to contradict what we have all seen work just fine in older carbureted engines with our own two eyes.
    Diesel oil did not destroy your engine in 50 miles. In many cases you could make it those 50 miles with no oil at all; another thing I have seen with my own two eyes.
  15. proartguy
    proartguy
    from Sparks, NV
    gimpyshotrods and squirrel like this.
  16. oldsmobum
    oldsmobum
    from SoCal
    I literally LOL’ed at comp cams claim they could reliably measure camshaft wear to the Millionth of an inch, and guess what? The best they could say is that is cost .000002” of wear. So they will invest in multi-multi million dollar equipment that is supposedly a hundred times more accurate than they need, pay to properly maintain it in a clean room, but they wont warranty a $20 lifter that is lazy out of the box? There are no variables listed about room temperature, humidity, time in the fixture, etc. all which affect the parts dimensionally well before you get anywhere near millionths of an inch.
    The suggestion that the oil will blow out a piston in a street driven flat tappet engine is straight up trolling.
    Is diesel oil better than regular conventional oil? Maybe, maybe not. But it is not going to blow up your pistons, FFS.
  17. Jack E/NJ
    Jack E/NJ
    from NJ
    > >Clickbait ********> >Diesel oil did not destroy your engine in 50 miles.> >
    Agreed. Oil nerd talks funny. Much more likely a coincidence than the cause.
  18. jimmy six
    jimmy six
    The big brown truck…Lucas Hot Rod!
    mkubacak and gimpyshotrods like this.
  19. Bleach
    Bleach
    I’ve heard of Lucas oil being advertised in a lot of old car blogs. I like to buy consumables like oil off a shelf but I guess that’s another thing I’ll have to have delivered.
  20. lostn51
    lostn51
    from Tennessee
    I run 30w non detergent in my flatheads and Castro 20-50 in all my hot rods never had an issue.
  21. tubman
    tubman
    I would be interested in your reasons for making this choice.
    Sharpone and gimpyshotrods like this.
  22. I use oil.
    I don’t recommend not using it.
  23. lostn51
    lostn51
    from Tennessee
    I got the 30w non detergent speech from my grand daddy and my dad saying if you don’t know what was in it use this and you will not have any problems, and the 20-50 Castrol is what my buddy and I have been using in all of our motors since high school. So I guess it’s just habit but never once have I ever had any issues because of the oil.
  24. I was taught non detergent for engines without oil filters
    Could flip a coin for the byp*** ones.
    but keeping oil in it and changing regularly has to happen either way
  25. mad mikey
    mad mikey
    I have oiled up my bodybuilder girl friend with diesel oil, she never spun a bearing or failed a lifter. Case closed.:D
  26. gimpyshotrods
    gimpyshotrods
    Maybe even overdue.
  27. Matt Dudley
    Matt Dudley
    from New York
    There is a product in a yellow bottle available at auto parts stores that is basically an additive that makes regular oil of your choice viscosity into cl***ic car oil by adding back the additives that have been subtracted for new cars. Gives an extra 1,200 ppm of zinc and some other stuff…. I forget the name or brand but it works good.
    26 T Ford RPU likes this.
  28. :D Should I explain again, that the most popular midrange diesel engine in the country still uses a flat tappet camshaft and modern diesel engine oils still have to support this camshaft and lifter design?
  29. gimpyshotrods
    gimpyshotrods
    Sure, but nobody will listen, or retain.
  30. oldsmobum
    oldsmobum
    from SoCal
    I put rotella in my O/T (but still almost as old as the average HAMBer) pickup because I had it; another O/T truck is diesel. I don’t always use it, because I don’t really care as long as it has oil.
    I drove it 750+ miles yesterday. No flattened cam, no blown out pistons… Even despite the piss that they sell as gasoline out in the middle of the desert.
    A lot of the car content on YouTube is made for people who aren’t really that into cars… It goes along with all of the stuff we read on the internet about how this/that will never work (like reusing pistons, lifters, etc) despite it being done frequently before the internet.
    Just imagine how boring this hobby would be if random people on the internet who don’t actually build cars were setting the “standards” for people the who did in the 1950’s like is done today.
    bschwoeble and caprockfabshop like this.
