Hot Rods Blowing this thing apart
Discussion in 'The Hokey Ass Message Board' started by nochop, Feb 28, 2022.
  1. nochop
    nochop
    from norcal
  2. Tim
    Tim
    from KCMO
    That looks fantastic! The view looking in threw the drivers window is going to be killer!
    05snopro440 and nochop like this.
  3. nochop
    nochop
    from norcal
    Now I get to lay on my back…..
    catdad49 likes this.
  4. In_The_Pink
    In_The_Pink
    Out of curiosity, how 'readable' are the gauges to the extreme right on the dash? I realize the cabin/interior width isn't huge, and a vacuum gauge my not need constant monitoring while driving, but is a Detroit Lean required to view the gauges on the p***enger's side while driving?
  5. nochop
    nochop
    from norcal
    No, the cab is small you can monitor everything. As a side note, I copied the gauge layout my dad did to this dash in the late 50’s. That’s how long this car has been in the family
    hfh, Stogy, Robdski and 6 others like this.
  6. nochop
    nochop
    from norcal
  7. Tim
    Tim
    from KCMO
    Looks tidy! I like the olds detail on the grill insert. Out of curiosity what’s the sleeved wires near the oil pan? And can I see how your running that brake line along the drivers side frame rail?
    thanks man, cars getting so close!
  8. nochop
    nochop
    from norcal
    Alternator lead to starter sleeved in asphalt loom then sleeved in a heat shield
    Tim likes this.
  9. nochop
    nochop
    from norcal
    catdad49, CDLooper, hfh and 3 others like this.
  10. RodStRace
    RodStRace
    They are all grining! Were they hot boxing in the van?
    CDLooper and nochop like this.
  11. nochop
    nochop
    from norcal
    Todays weed? We would all be in a fetal position whimpering
    catdad49, Tim, RodStRace and 3 others like this.
  12. nochop
    nochop
    from norcal
    More smalls, this time radiator hold down bolts IMG_7644.jpeg IMG_7645.jpeg IMG_7646.jpeg IMG_7648.jpeg IMG_7647.jpeg
  13. nochop
    nochop
    from norcal
    Idiot lights, just because I can be one IMG_7657.jpeg IMG_7660.jpeg IMG_7655.jpeg
    catdad49, guthriesmith, hfh and 5 others like this.
  14. Tim
    Tim
    from KCMO
    Looking good.
    did you make the radiators hold down hardware? Curious how stiff the spring is.
  15. nochop
    nochop
    from norcal
    catdad49, Just Gary and Tim like this.
  16. RodStRace
    RodStRace
    Cool! I could use one of those!
  17. Tim
    Tim
    from KCMO
    Perfect! Thank you. I might have snagged on and it’s sitting on the shelf but little stuff like that hit the “out of stock” status in 2020 and a lot of it never came back. Finding more common sources for the little stuff has become my main route now
    nochop likes this.
  18. nochop
    nochop
    from norcal
    It did require cutting a coil or 2 off the spring and grinding a little ring down on the bolt. Oh yeah they are metric but accept a sae wrench. After putting the nylock on and tightening the tension seems acceptable
    catdad49 and Tim like this.
  19. nochop
    nochop
    from norcal
    Doors and fenders IMG_7723.jpeg IMG_7722.jpeg IMG_7721.jpeg IMG_7734.jpeg IMG_7724.jpeg
  20. Tim
    Tim
    from KCMO
  21. HEMI32
    HEMI32
    Yep . . . @nochop is correct . . . the quarters are tight in a Deuce 5wd Coupe . . . the driver can easily monitor all the gauges.
    In '57 or '58, my father did a very similar gauge layout in our coupe:
    circa 1973
    dash is pretty much the same today
    catdad49, Just Gary, CDLooper and 2 others like this.
  22. nochop
    nochop
    from norcal
    Nothing like having our dads coupe
  23. nochop
    nochop
    from norcal
    Set the drivers door latch and moved on to running boards IMG_7739.jpeg IMG_7741.jpeg IMG_7749.jpeg IMG_7747.jpeg IMG_7743.jpeg
    catdad49, Just Gary, SS327 and 14 others like this.
  24. Tim
    Tim
    from KCMO
    Man it’s getting so close! You’ve really done a great job with this! Tearing apart a driving car and changing it all isn’t a feat for the easily spooked!
    427 sleeper and nochop like this.
  25. I like the readers at the ready in the alternate position!...I'm with you, I have a pair within arms reach of wherever I am. Your deuce is going to be a knock out!
  26. Dick Stevens
    Dick Stevens
  27. nochop
    nochop
    from norcal
    All four on the floor IMG_7784.jpeg IMG_7781.jpeg IMG_7785.jpeg IMG_7782.jpeg
    catdad49, Just Gary, SS327 and 6 others like this.
  28. Tim
    Tim
    from KCMO
  29. Tim
    Tim
    from KCMO
    catdad49 and nochop like this.
  30. nochop
    nochop
    from norcal
    Holy Cr*p Tim that’s awesome
