Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. F-head
    F-head
  2. vtwhead
    vtwhead
    got lucky today! found a '66 283 bored 30 over with power pac heads. Been in a dry garage for over ten years. story goes that the PO had it rebuilt and then was in an accident, so he pulled the engine to use another day which never happened.
  3. Robdski
    Robdski
    I was able to get some epoxy primer on some front end parts today.
  4. pila38
    pila38
    Finally made this happen:
    Tim, 4 pedals, Sharpone and 14 others like this.
  5. choptop40
    choptop40
    50 DeSoto gauges all worked out .. Disassemble, strip dash . prime and paint.. PXL_20250407_172548190.jpg
    jazz1, Sharpone, mad mikey and 11 others like this.
  6. nochop
    nochop
    from norcal
    jazz1, chevy57dude, Sharpone and 16 others like this.
  7. 50chevytx
    50chevytx
  8. Adriatic Machine
    Adriatic Machine
    Now that’s a cool setup!
    Sharpone, mad mikey and porkshop like this.
  9. High test 63
    High test 63
    I shoulda flogged on that ol' girl when i had the chance last year! I hope she's run'n sweet Mike!
  10. 50chevytx
    50chevytx
    Just hope it runs, not idling to good so far.
  11. saltflats
    saltflats
    from Missouri
    Well got this plasma cutter up and running. Have a few wire to hook up so it can go to work on a CNC cutting table.
  12. deathrowdave
    deathrowdave
    from NKy
    IMG_2610.jpeg Tough job in the shop . It warmed up so I made a mistake and rolled up sleeves . You all know the little extra tab sticking out on a hose clamp . Well I found it . Blood thinners make life a mess at times . Looks way worse than it is . My fault for bypassing the PPE .
  13. saltflats
    saltflats
    from Missouri
  14. deathrowdave
    deathrowdave
    from NKy
    Looking good , Anthony . You will love the Tripower carbs
  15. deathrowdave
    deathrowdave
    from NKy
    It looks way worse than it is . It was bleeding pretty good . Just a reminder to all , try not to bypass the PPE , it usually has bad results for being stupid for just a few minutes.
  16. Sharpone
    Sharpone
    On the bright side the car ain’t done until you give it a little blood, just a little though. PPE is good I have do something dumb about every 20 years for a reminder. LOL
    Dan
    Bill's Auto Works likes this.
  17. Your episode hits home here, too. Hotrods are carnivores, I'm convinced. Maybe omnivores, too, when you count the "lettuce" they chew from our wallets.
  18. nochop
    nochop
    from norcal
    This needs a “that f-ing*****s”*****on
  19. 50chevytx
    50chevytx
  20. saltflats
    saltflats
    from Missouri
    Digging in the old DXF files we have the rendition of my art work for my shop sign.
  21. Sharpone
    Sharpone
    Installed points distributor, new adjustable double roller cloyes timing set, Holley Street Dominator intake with Carter AFB (with @carbking s help) set timing to 32, 33 degrees at 3500 rpm. Should sound better when exhaust isn’t directed at the floor.
    Excuse my poor video and hillbilly wiring for the Dirt Cheap Dart 318 I have about $870 in engine transmission and accessories
    April 9, 2025
    Dan
  22. atch
    atch
    Clarence was backfiring through the exhaust at highway rpm's. Ran great at lower rpm's. I surmised a vacuum leak was preventing the vacuum advance from working. Plugged the vacuum port going to the brake booster and it ran great in the shop at all rpm's.
    Installed hose clamps on all rubber-to-steel connections in the booster line. Runs great now. I think I'll drive it to lunch with the guys tomorrow. That's about 45 miles each way.
    We'll see how it performs.
    Pix unnecessary. Anyone who doesn't know what a hose clamp looks like isn't on this board anyway.
  23. brading
    brading
    Nothing wrong with the Hillbilly wiring to check something out we have all done it, its not like its the finished article.
    osage orange and Sharpone like this.
  24. jeepster
    jeepster
    from wisconsin
    porkshop, saltflats, Robdski and 2 others like this.
  25. atch
    atch
    Got my restored license plate instilled. Thanks @oldpl8s.
    Before pic (note; this was after extensive CLR and vinegar baths):
    When received from oldpl8ts
    As now installed:
    charleyw, enloe, Marty S and 14 others like this.
  26. Robdski
    Robdski
    Perfect color!
    Super straight body work with an awesome gloss.
    Great work on the plates too.
  27. atch
    atch
    Thanks man. I can't take much credit for those things. I'm no body/paint man and hate doing it. A VERY talented man did over 600 man hours on the body including paint. Tom is one of those guys for which it's either perfect or not good enough. Paint color is Washington Blue; same code as Ford used in the 30's.
    oldpl8s on here restored the plate. What little I'm capable of doesn't show up at first glance (underneath and hidden).
    I drove it to lunch today about 40 miles each way. First time it's been driven this year. It sure felt good.
