Featured Projects uncle Charlie's hot rod model A projects
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Feb 19, 2025.
  1. Looks good!:cool:
    tb33anda3rd likes this.
  2. helped Charlie today, keep working from the front to the back. we got the garnish molding cut down for the windshield and moved the stud, for the adjuster bar ,that props the windshield open. image0.jpeg image1.jpeg
    41 GMC K-18, Deutscher, TFoch and 2 others like this.
  3. image2.jpeg image3.jpeg image4.jpeg we also cut and welded both doors and fit and tested the windshield again
    Deutscher, charleyw, cactus1 and 7 others like this.
  4. patsurf
    patsurf
  5. :)
  6. Looks good for a couple of slackers!:p
  7. Stopped by this week to see no one at work! “Slackers “ IMG_7837.jpeg IMG_7836.jpeg IMG_7838.jpeg
  8. Looking good!
  9. I took the doors and pieces back to my shop and finally got a chance to work on them.
    I trimmed the back door skin from the 4dr to shape and used the opposite jamb section from the other door to creat a jamb section of the back corner of the cab. image19.jpeg image18.jpeg
  10. I trimmed the jamb to match the front door shape, then welded it to the "back" door.
    31Apickup, Dino 64, dwollam and 5 others like this.
  11. I then cut a piece of sheet metal to the arch of the door to create a return for the back of the cab to attach to. image12.jpeg
    31Apickup, Dino 64, dwollam and 6 others like this.
  12. I cut off the the part of the "door" above the bead and made a new section, putting a raised area in it to mimic a 29 model A pickup. folded the sides and welded it in. image9.jpeg
  13. I then did the same for the other side, welded up the old door handle holes and cleaned it all up with a little 80 grit.
    31Apickup, ERguitar, Dino 64 and 10 others like this.
  14. I chopped the back window only an inch and a half, so it is the same height as the side windows. image0.jpeg
  15. That’s it?:p
  16. Charlie was worried if we went any more he would have a hard time seeing out of it.
  17. No, I meant that’s all you did!:p
    milwscruffy and patsurf like this.
  18. slacker is as slacker does
    dwollam and ct1932ford like this.
  19. stopped by Charlie's to drop off the parts for test fit. put one door on and clamped the quarter to the post. I need to do a little trimming before I weld it in but it looks like it will work. image0-4.jpeg
    31Apickup, Dino 64, dwollam and 2 others like this.
  20. two visitors today, Charlie dropped off the hood for me to louver and Mark came by and laid them out. image0-4.jpeg image1-2.jpeg image2-2.jpeg two rows per side. ten on the inside row and 8 on the outer side.
    akoutlaw, ct1932ford and cactus1 like this.
  21. once Mark-ed out, I cut thin slices with the grinder and a thin cut off wheel. the hand made tool slipped into the groove on the face side of the hood and the chisel tool punched the louver from the back side. image3-2.jpeg image4-3.jpeg image5.jpeg
    dwollam, 31Apickup, Dino 64 and 2 others like this.
  22. With a little hammer and dolly work and cleaned up with a file the hood is done.
  23. We make a good team.:cool: Hope Charlie likes it.
  24. he is going to love it.
    ct1932ford likes this.
  25. I like the Jeep tires. HRP
    tb33anda3rd and ct1932ford like this.
  26. patsurf
    patsurf
    yes yes and yes--and perfect!
    ct1932ford and tb33anda3rd like this.
  27. Dino 64
    Dino 64
    from Virginia
    Love those louvers !! :)
  28. we also trimmed up the cab corners for fit and made some measurements for the back of the cab. image0.jpeg
