Technical GM TH400 issues
Discussion in 'The Hokey Ass Message Board' started by 1pickup, Apr 9, 2025.
  1. Kevin Ardinger
    Kevin Ardinger
    If it is cavitating because of that filter, not being a screen type filter, it will cause all of your problems. So it can be fixed in the vehicle. I wouldn’t pull the trans out until I put a Allison type filter, make sure there’s two of the right size O-rings on the pipe. Those cloth type filters do not work! And make sure the vent tube is clear.
    427 sleeper and gimpyshotrods like this.
  2. gimpyshotrods
    gimpyshotrods
    You don't have to pay you, and you don't have to mark up parts for yourself.
    Get a few books, read through them, Grab a camera and get to it.
  3. squirrel
    I screwed up the first one I did for a friend when I was 16, but after that they mostly all worked....
  4. mohr hp
    mohr hp
    from Georgia
    Here in Georgia, I just picked up my 400 that a great local shop rebuilt for me. Alto clutches, it already had a Transgo kit, 34 element sprag and nothing else too exotic for $1,200. $2,200 seems crazy for a regular 400.
  5. squirrel
    If I had to charge $200 an hour, it doesn't look quite so crazy.
  6. gimpyshotrods
    gimpyshotrods
    I have to charge >$200/hr., but I can rebuild one, in 4-hours, at a comfortable pace.
  7. BJR
    BJR
    I paid about $800 with a new torque converter to rebuild my 400.
    Sharpone, SS327 and gimpyshotrods like this.
  8. @1pickup, don't be afraid to tackle the rebuild yourself. Get one of the books that Gimpy pictured (I personally like the Cliff Ruggles one) and look it over. I think you will find it pretty straight forward. If you just do a "refresh" build with just seals, gaskets, and clutches it is even easier, less costly, and requires fewer DIY tools.
    Sharpone and gimpyshotrods like this.
  9. I'm not sure if this makes a difference or if someone has already mentioned it. There are two different filters for a T400. An early one and a late one. I would be sure I had the right one for the year of the trans. Gene.
  10. jaracer
    jaracer
    If it went into gear once without slippage, it probably isn't a pump problem. Either the pump is being starved for fluid, or you have a m***ive internal leak. You could put a pressure gage on the test port, but your description already points to a pressure problem. Sounds like it either has to come out and be repaired or replaced.
    rattlecanrods likes this.
  11. I am thinking something similar. In park, convertor hasn't filled up yet after leak down. Trans will engage a bit until convertor fills up but now there isn't enough fluid left in pump and cavitation occurs.
  12. '49 Ford Coupe
    '49 Ford Coupe
    Just as an additional tip, when/if you pull the pan, get 4 of those large donut magnets at Home Depot and epoxy them in the corners of the pan. That will grab most of any metallic debris before it gets to the filter.
  13. gimpyshotrods
    gimpyshotrods
    '49 Ford Coupe likes this.
  14. BJR
    BJR
    With a 30 year old automatic transmission you are just wasting time and money trying to fix it. Seals dry out and crack, clutches fall apart and loose the lining. Old fluid turns to mud. Just bite the bullet and rebuild it. I was there and am glad I went to the trouble to pull it and rebuild it.
  15. 1pickup
    1pickup
    Not sure what happened, but there is a ton of **** in the pan now. There was nothing there when I changed the filter, and it's got about 10 miles on it since then. I see the fluid has some metallic look to it, and the sludge looks like mud. It's coming out for a rebuild.
  16. 1971BB427
    1971BB427
    from Oregon
    But it does require some specialty tools that might make the cost of doing one rebuild not all that affordable. And without the proper clamp tool to hang the trans tailshaft down it's a little more difficult to do it on a bench or the floor.
  17. squirrel
    I use a short piece of pipe and some baling wire to hold the gear ***embly when installing it, I put the case on a milk crate.
    The clutch spring compressor and bushing drivers are the only special tools I have, and they pay for themselves real quick.
  18. garyf
    garyf
    I have made a spring compressor for the clutch drum spring with threaded rod, s**** steel and mig welder. A 25 gallon metal barrel with the round opening flattened on one side, will grab most transmission cases where the back of the pan bolts up. Makes a perfect height transmission stand to load all your rebuilt innards into trans case with tail shaft down..The thin metal tool snap on provided on their toolboxes to remove the drawers,worked perfectly with Vaseline to aid installing servo and drum lip seals. Threaded rod with a driver to make a slide hammer to remove the front pump. Cut the heads off the correct size and thread bolts, to align the front pump back into case on re***embly.If you take the front pump apart to clean or inspect gears,instead of buying a realignment band,with the pump halves loose carefully install pump upside down in empty trans case, tighten pump bolts,the halves are now aligned, remove and reinstall.
    427 sleeper and squirrel like this.
  19. gimpyshotrods
    gimpyshotrods
  20. gimpyshotrods
    gimpyshotrods
  21. squirrel
    I got one of these a long time ago, seems to do the job...but they are discontinued, and used ones cost money. Neat to see all the cheap new ones available these days.
    gimpyshotrods likes this.
  22. gimpyshotrods
    gimpyshotrods
    The bench clamp is cheap enough that I bought a second one, to cut up and widen to hold a TH425.
    That has the lugs in the case, but they are out of range of a regular clamp.
  23. gimpyshotrods
    gimpyshotrods
    squirrel likes this.
