Hot Rods Elliptical Tubing for Frame Rails
Discussion in 'The Hokey Ass Message Board' started by Russco, Apr 10, 2025.
  1. Russco
    Russco
    from Central IL
    Im just getting started on this new project And would like to start by getting the chassis started. I’m having difficulty sourcing the elliptical tubing I need to re create this hot rod. I didn’t think it would be this much of an issue sourcing it but it’s proving to be very difficult to find. So far I’ve actually only found one place that said they could produce it but it costs 3K for them to tool up for a run plus the cost of the product. I’m not totally against doing this but they also said they are 8-10 weeks out as well. So a few thoughts I have are, if I have some made would there be enough demand to have some extra made that I could sell to help offset the costs? Then I would need to spec out the tubing itself. Off the top of my head I figured it would be made from 3” DOM and probably .095 wall would be sufficient in strength? I believe this would end up with tubing that would roughly be about 2” by 4” give or take? Maybe some of the chassis builder guys could chime in on this? In doing the research for this project It’s said that this tubing was used for PBY wing struts. I haven’t been able to find any specs on what that tubing actually was sized at but I would expect it was 4130. The car I’m building is only going to be for display purposes but I would want it to be of sufficient strength that it could be driven.
    My next thought would be maybe I could take 3” tubing and run it through a set of dies and try to make it myself? I don’t know how hard this would actually be but I would expect it would take a good bit of thought to do it well. Anyways? Here are a few pictures of the chassis showing the elliptical tubing I would like to hear some opinions on what approximate size you think this actually is and what wall thickness it would take to be sufficient for this type of project. Maybe some other ideas on how to accomplish this or maybe locate some I haven’t thought of yet. I’ve been searching aircraft suppliers like McMaster ETC…. And googling tubing and steel suppliers. So far with no luck other than the steel mill in Louisiana I mentioned. I’ve found some exhaust tubing that is oval shaped that’s 304 Stainless I think, but it’s only .065 and not really the shape I’m needing anyway. Anyway, here are a few pictures that show the tubing I’m needing to duplicate I’d like to here some opinions on what sizes and wall thickness you think this would be and/or need to be to be structurally sound to use for a chassis like this. I would also like to hear what anybody thinks the estimated wheel base is on this car. I’m assuming around 104-110 maybe? Thanks in advance. IMG_4667.jpeg IMG_4602.jpeg IMG_4596.jpeg
    dana barlow, Tim, Just Gary and 2 others like this.
  2. warbird1 likes this.
  3. Russco
    Russco
    from Central IL
    Pretty sure I’ve checked all those already, AED and aircraft spruce for sure and Wicks aircraft I remember talking to. the streamline or aero tubing is more of a teardrop shaped profile, non symmetrical and the largest they have spec’ed is about 1/2 the size I need. But I’ll double check thanks for replying.
  4. Ziggster
    Ziggster
    Have you looked into architectural suppliers? I see all kinds of strange shapes in buildings, but would most likely be aluminum or SS, and thin walled, but you never know.
    While doing the layout for my speedster, I was surprised at the length of my wheelbase. I would say that a “normal” vehicle wheelbase would be between 100” and 110”. The wheelbase on my 80 Series Land Cruiser is 112”.
    Had the C channels for my speedster made. 1 5/8” x 3 1/2” x 1/8” thk IIRC. Used mild steel and they are “flimsy” IMHO even with my crossmembers attached (although they are just bolted at the moment). Trying to stiffen up the chassis is going to be a challenge, but if you’re just looking for a static display, a “thin” walled section might suffice depending on the material, but I would try to keep it no less than 0.100”.
  5. Oneball
    Oneball
  6. 69fury
    69fury
    alanp561 likes this.
  7. Russco
    Russco
    from Central IL
    Yeah, I’ve talked to them, he was very helpful and said they would do it, they are the ones that are $3000.00 tool up fee and are about 10 weeks out. I may have to go with that, but I’m hoping to find some that’s cheaper than 175.00 per foot. If There would be enough demand for it I could have them run off maybe 5 sets or something and sell 4 sets to help offset the cost of the tooling fee.
    Oneball likes this.
  8. Tim
    Tim
    from KCMO
    I wonder if @cornfieldcustoms would have some ideas. Between his shop work and working with salt cars he may have a source or process?
  9. alchemy
    alchemy
    Cheaper to weld up some long dies to press some round tube between? Would be even cheaper if you could do it in 4 foot chunks and weld them together. Or do you need a full length stick to pass tech? ;)
    Russco likes this.
  10. AccurateMike
    AccurateMike
    Flatten round in a roller ? I worked at a shop that had a roller that could have done frame rail sized stuff. We sent bigger stuff out all of the time. Mostly box, round, I-beam and angles into curves and circles. I'm pretty sure a machine that can roll I-Beams could do it, with the right set-up. Mike
    GlassThamesDoug likes this.
  11. saltflats
    saltflats
    from Missouri
  12. Rusty O'Toole
    Rusty O'Toole
  13. Russco
    Russco
    from Central IL
  14. Russco
    Russco
    from Central IL
    I just joined up to a PBY internet group hoping to at least get the specs/info on the tubing. I have a guys number way out in Oregon that says he has 2 struts but they are both pretty damaged and I probably wouldn’t be able to use them.. Thanks for the suggestion
  15. 57Fury440
    57Fury440
    I hope you find some. That frame looks really nice. I'm with you, I would want it to be able to be driven and even maybe good enough to drag race.
  16. Texas John
    Texas John
    What about sailboat masts?
  17. Russco
    Russco
    from Central IL
    I work for a fence company, we use some pretty heavy rollers on our cantilever gates, I could try to turn them down in a lathe to get the profile but it will take a hell of a fixture and a lot of force to draw it through I’d bet IMG_4678.jpeg
  18. Russco
    Russco
    from Central IL
    I’d like it to be strong enough to drive and be functional, but I don’t have any plans at this time to get the Ardun running. It hasn’t ran for 62 years. So at this point I’d be tickled just to have the car look accurate enough to put on display and show it. I’d be scared to death to drop a valve or something and hurt it bad, it’s supposed to have some pretty exotic parts in it for the time.
  19. Mike Lawless
    Mike Lawless
    A few years ago, I think the Chassis Shop had elliptical 4130 tube. The kind of stuff they use on TopFuel rear wing struts. Be worth a look
    Russco likes this.
  20. AccurateMike
    AccurateMike
    I was thinking of a place more like this https://www.cmrp.com/ or this https://www.nisteel.com/steel-fabrication . One of these should be able to do it
    A 3 1/2 round would be just about 2x4 if you flattened to 2 and ended up with ~ 1/2 round (1" rad) ends. It'll put a bend in it, a run through upside down should straighten it. Just a hunch, Mike
    saltflats likes this.
  21. Russco
    Russco
    from Central IL
    Man, both those places sound promising and are within a few hours of me too. I just imagined the machine that forms it uses a series of round dies on rollers that it feeds through like a big bead roller progressively getting smaller I donno?
    That big roller is crazy!
    . I appreciate your help, there’s gotta be someone that does this.. I have a machinist buddy that thinks we could just make dies and use a press and just do like a foot at a time. like Alchemy said
  22. continentaljohn
    continentaljohn
    Mike I was going to suggest talking to Bob Boyce of Boyce engineering. He was instrumental in the tubing industry and with Indy car ,nascar and all sorts of racing .
    Unfortunately looks like Bob sold the company but believe I may have his cell phone number.
    What’s good is Bob innovations and machines we sold to
    AEDMetals.com
    And looks like they are still making aero tubing
    tractorguy likes this.
  23. porkshop
    porkshop
    from Clovis Ca
  24. porkshop
    porkshop
    from Clovis Ca
  25. porkshop
    porkshop
    from Clovis Ca
  26. Rickybop
    Rickybop
    I don't know about the tubing.
    But that's one amazing hot rod.
    porkshop likes this.
  27. Russco
    Russco
    from Central IL
    Thanks John! Hope you’re doing well, I will check that out I think I may have checked with them but maybe I’m asking for the wrong tubing or something? I was gonna call you and see if you have some of the parts I’m needing. Mel and I are planning g on going to Torque Fest. You should go over for the day.
  28. Russco
    Russco
    from Central IL
    I’m working on those suggestions thanks . The guy at LJTUBE was very helpful and gave me a list of places to check with, but they have a minimum run of 30,000 feet to tool up. Which is the problem I’m finding at many of the placesI call that can produce it. I appreciate all the suggestions I’ll check out every one Thanks again!
  29. Rickybop
    Rickybop
    I wonder if round tubing could be pressed into an oval shape with a hydraulic press.
  30. Bandit Billy
    Bandit Billy
