Projects uncle Charlie's hot rod model A projects
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Feb 19, 2025.
  1. tb33anda3rd
    tb33anda3rd
    bchctybob, TFoch, winduptoy and 6 others like this.
  2. ct1932ford
    ct1932ford
    bchctybob, TFoch, winduptoy and 5 others like this.
  3. tb33anda3rd
    tb33anda3rd
    the new gl*** came in for the windshield. Charlie had the frame all cleaned up and I put it all together. image0-4.jpeg image1-2.jpeg
    bchctybob, Deutscher, TFoch and 10 others like this.
  4. The37Kid
    The37Kid
    Another great project to follow!
  5. tb33anda3rd
    tb33anda3rd
    Bob, Charlie would love a visit and you can see it in person
    bchctybob, Stogy and winduptoy like this.
  6. tb33anda3rd
    tb33anda3rd
    this is the roof I cut off a '65 suburban parts truck. I am thinking it is the perfect material to make the back of the cab. image0-4.jpeg image1-2.jpeg
  7. tb33anda3rd
    tb33anda3rd
    I cut the panel in half to eliminate the step and squared it up. I ran a bead along the long edge. image0-4 copy.jpeg
    bchctybob, Deutscher, TFoch and 7 others like this.
  8. tb33anda3rd
    tb33anda3rd
    I trimmed it at the lower edge of the bead. this section will be the upper part of the back of the cab and the bead section will over lap the lower panel. image1-2 copy.jpeg
    bchctybob, Deutscher, TFoch and 9 others like this.
  9. tb33anda3rd
    tb33anda3rd
    image2-2.jpeg I then planned out the location of the rear window. the bead will line up with the small lower bead of the side of the cab and I measured up off of that to place the rear window. the window is centered in the cab and centered up and down with the side windows. I then cut out the hole to weld the rear window frame in. image2-2.jpeg
    bchctybob, Deutscher, Stogy and 9 others like this.
  10. tb33anda3rd
    tb33anda3rd
  11. tb33anda3rd
    tb33anda3rd
  12. Okie Pete
    Okie Pete
    WOW awesome work
    winduptoy and tb33anda3rd like this.
  13. tb33anda3rd
    tb33anda3rd
    thank you.
    Okie Pete and winduptoy like this.
  14. tb33anda3rd
    tb33anda3rd
    went to Charles to test fit and trim. I measured wrong and the bottom section came up short. I will have to weld a piece on.:confused: image0.jpeg
    dwollam, bchctybob, Deutscher and 4 others like this.
  15. tb33anda3rd
    tb33anda3rd
    I aligned the bead of the top section with the cab corners and marked them to be trimmed. once trim we screwed them in place temporary. image1.jpeg image2.jpeg
    dwollam, bchctybob, Deutscher and 8 others like this.
  16. tb33anda3rd
    tb33anda3rd
    nothing is in final, all the tin will get fitted and trimmed once all the parts are made. it will come back apart but this mockup is starting to look like a truck. image3.jpeg
    Outback, dwollam, bchctybob and 12 others like this.
  17. winduptoy
    winduptoy
    I am loving everything about this project....carry on!
    Outback, bchctybob and tb33anda3rd like this.
  18. tb33anda3rd
    tb33anda3rd
    thanks
    winduptoy likes this.
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Outback, dwollam, bchctybob and 3 others like this.
  20. tb33anda3rd
    tb33anda3rd
    he was eyeballing the alignment;)
    he likes the color of the back of the cab.
    Outback, bchctybob, winduptoy and 3 others like this.
  21. MPmachine
    MPmachine
    I like that!
    tb33anda3rd and winduptoy like this.
  22. TigerFan
    TigerFan
    from Athens, GA
    I love this thread. Keep it going!
  23. tb33anda3rd
    tb33anda3rd
    thanks, we like the way it is coming out.
    Thanks, Charlie is happy to hear that people from all over are watching his project.
    dwollam, winduptoy and Speccie like this.
  24. ct1932ford
    ct1932ford
    How are we going to get a Big Block in this thing?:eek:
    Dino 64, winduptoy and tb33anda3rd like this.
  25. tb33anda3rd
    tb33anda3rd
    spent the day with Charlie, he has been busy since I last was there. He made and installed all four shock mounts. image17.jpeg image16.jpeg image14.jpeg
  26. tb33anda3rd
    tb33anda3rd
    we also finished up, the grill shell. it was missing the front receiver for the hood hinge. we riveted that, and the crank hole cover in. I also banged a couple dents out of it and put the Ford badge on. we also replaced the hood hinge tube. image2.jpeg
    dwollam, bchctybob, cactus1 and 3 others like this.
  27. tb33anda3rd
    tb33anda3rd
    we also came up with a solution for the door latches. they would not latch without turning the handle, no matter how hard it was slammed so we added a wedge to the front of the catch we had used. it is a mismatch of parts but we made it work and the doors close effortlessly. image15.jpeg
    dwollam, bchctybob, cactus1 and 2 others like this.
  28. tb33anda3rd
    tb33anda3rd
    with the doors opening and closing and aligned we welded both cab corners in image13.jpeg
  29. tb33anda3rd
    tb33anda3rd
    once the cab corners were in I centered the upper half of the back of the cab, trimmed it to follow the cab corners and used the grinder to fit it. image12.jpeg
  30. tb33anda3rd
    tb33anda3rd
