Technical Need some advice '40 Ford
Discussion in 'Traditional Hot Rods' started by Corvairdave, Apr 12, 2025.
  1. Corvairdave
    Corvairdave
    Good morning. I'm hoping for some help diagnosing a poor running '40 Ford. It's my Dads' car and we are currently trying to sell it. It is an early 50s custom with a 303 Olds Rocket and 3 Stromberg 97s on a progressive linkage. It runs a 6 volt system and has a Pertronix. The engine is completely rebuilt with less than 1000 miles on it. It is missing quite badly. Idles ok, but as it revs it hits about 3000 RPM (no tach, so guessing) and then feels like it hits a rev limiter. Here's what we've tried. Fresh gas. (Old stuff was ok, we think, just covering the bases) Set fuel pressure to 2-1/2lbs, new coil, checked spark at each plug, (looked pretty yellow orange weak) Had 5.8 volts on the hot side of the coil. Pertronix is new. Don't have alot of experience with 6 volt systems. I know a 12 volt systems sits at 13.2 or so fully charged and above 14 when charging. Are 6 volt numbers meant to be half of those figures? Also, is the spark from a 6 volt somehow weaker than a 12 volt system? Any help would be great. TIA Cheers, Dave
    Moondog13 likes this.
  2. Doublepumper
    Doublepumper
    from OR-WA, USA
    I'd first make sure all the ground connections are there and are clean...very important on a six volt system.
    Ducbsa likes this.
  3. Budget36
    Budget36
    I’d like to see a pic of the car!
  4. lothiandon1940
    lothiandon1940
    ...Likewise..:D
    Moondog13 and Budget36 like this.
  5. guthriesmith
    guthriesmith
    Yep, we need pics. Sounds like a great car! :cool:
    lothiandon1940 and Budget36 like this.
  6. tubman
    tubman
    I strongly agree with checking grounds and all connections.
    Pertronix setups for 6 volt systems have a reputation of being "iffy". Having less than 6 volts doesn't help either. Either get more than 6 volts to the Pertronix or put points and condenser back in. I strongly suggest the latter.
  7. Corvairdave
    Corvairdave
  8. Corvairdave
    Corvairdave
  9. Budget36
    Budget36
  10. tubman
    tubman
    WOW! That is very nice. I notice the "bumps" in the valve covers; that means a high-lift cam with either adjustable pushrods or rocker arms.
    If that were mine, I'd find a Mallory "flattop" for it and really have the "look".
  11. Corvairdave
    Corvairdave
    Thank you. He put many hours into it. If a Mallory flat top would make it run properly, I'd be all over it ;-)
    Kiwi 4d and lothiandon1940 like this.
  12. guthriesmith
    guthriesmith
    Wow! That is one cool car! Hope you get it all sorted out.
    Tow Truck Tom and lothiandon1940 like this.
  13. Very nice car!...I agree with all of the above recommendations (especially reverting back to the points/condenser). And, because nobody else asked...what are you asking for the car?
  14. lothiandon1940
    lothiandon1940
    Sweet '40. Hope you get things sorted. Likely something simple. Good luck.
    Tow Truck Tom likes this.
  15. tubman
    tubman
    Here's another approach; a stock Olds distributor with a Mallory dual point conversion. Since the second set of points takes up the space where the condenser usually lives, you need a snazzy "trash can" conenser on the outside of the distributor, which has always been a "high-performance" cue.:cool:
  16. I agree with tubman, use a stock distributor. Pertronix are "no good", especially in a hot 40 engine room. Also the best bet on groundin straps. 1. engine to frame 2. body to frame 3. Engine to body 3 grounds is the best way to go. Also an 8 volt battery will help alot I used one on my Cord which has a 322 in flathead and it really helped it start right up.
    I really like your Custom Coupe,it's a beautiful Custom, I love nosed and decked' JW
    lothiandon1940 likes this.
  17. tubman
    tubman
    I think I'd recommend an 800 CCA Optima before using an 8 volt battery and all that it entails. The main problem is that you have to figure out some way to get the charging system to put out over 8.5 volts to keep the battery up. It can be done, but...
  18. Russco
    Russco
    from Central IL
    Man that’s a nice ‘40! I would put a timing light on it and see if the ignition is advancing when the RPM comes up like it should, but if it’s breaking up under no load RPMs sounds like the ignition is breaking down.
    Jermo, Tim and lothiandon1940 like this.
  19. alchemy
    alchemy
    I thought Perjunkix couldn’t be used with a generator?
    RICH B likes this.
  20. tubman
    tubman
    Probably "shouldn't", not "couldn't".:rolleyes:
  21. nochop
    nochop
    from norcal
    That’s a slick 40
  22. guthriesmith
    guthriesmith
    I’m agreeing with everyone about it likely being the Pertronix. But, it could also be those front two air cleaners on upside down? :p
  23. tubman
    tubman
    I think Jeff may be on to something. Try taking them off completely and see if it makes a difference. Those things are very restrictive.
    Kiwi 4d likes this.
  24. guthriesmith
    guthriesmith
    Yea, there is that too. I know those are very restrictive.
  25. warbird1
    warbird1
    6v. Pertronix don't have the best reputation. I'd go back to points and a "good" condenser.
    12v. Pertronix are a different matter, I've been running one on the Cad in my '40 for 5 years now with no issues.
  26. tim troutman
    tim troutman
    start the car in the dark with the hood up rev it up see if you see any arcs with it running
    bobss396 likes this.
  27. Corvairdave
    Corvairdave
    We are asking $42,000 Canadian, once we get it running properly of course ;-)
  28. so has it ever ran good? is this a new problem? You said it is a new/rebuilt motor with less than 1000 miles, just wondering if the carbs are set up right as far as jetting.
    Tim and guthriesmith like this.
  29. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup, Ditch the Pertronix and remove those decorative v8 wraps over the air filters. I can't imagine those are letting enough air in
  30. Yes the regulator will have to be adjusted to 8 1/2 volts to make it work.
