Technical 1955 Chevy truck, problem removing rear springs.
Discussion in 'The Hokey Ass Message Board' started by IDTag, Apr 12, 2025.
  1. IDTag
    IDTag
    1955 second series 3100 truck. Looked at the manual and seemed straight forward but getting the front pin out seems like a lot more of a project than they show. Pushing them inward I run into the frame, outward and you run into the bed step. Do you have to pull the step or am I completely missing something stupid simple?
  2. tb33anda3rd
    tb33anda3rd
    taking the whole bed off makes the job easier and you can really clean things up.
    klleetrucking likes this.
  3. 55 gasser pickup
    55 gasser pickup
    from utah
    I have seen an article, (Cl***ic trucks i think).That says remove the step. I want to know for sure as i have one too and need to do rear suspension work. Also i have seen a hole drilled in the step Big enough for a socket to get in there.
  4. BJR
    BJR
    Removing a pickup bed is not hard to do. Only a few bolts, and a couple of friends to lift it off. Makes the rest of the work much easier, and you can clean up the frame and paint it.
  5. squirrel
    never was an issue on my 59 Fleetsides....
  6. patsurf
    patsurf
    that is almost mean!
    IDTag and SS327 like this.
  7. Motorwrxs
    Motorwrxs
    It’s been a minute since I replaced the springs in my 57 GMC step side, but I did not remove the bed to put in my new Posie rear springs.
  8. swade41
    swade41
    from Buffalo,NY
    I jacked up the front of the bed to get past the step, pain in the ***
  9. IDTag
    IDTag
    Looked a little more, maybe 8 bolts holding the bed on. I have a lift so would be pretty easy to get it off the frame. Just don't see any way to get those front pins out without lifting the bed or removing the step.
    Did get Posies springs for front and rear, also have a drop axle on the way from Sids. Truck has some pretty large tires on it right now, have some lower profile ones on the way so will see how it looks then.
    Fronts were easy, took maybe an hour and a half. Sunny day so couple beers and not in a hurry, was a long week.
  10. swade41
    swade41
    from Buffalo,NY
    I used Posies springs front and rear on mine as well
