Technical EDELBROCK CARB mounted backwards
Discussion in 'Traditional Hot Rods' started by badsix, Apr 12, 2025.
  1. badsix
    badsix
    i'm doing a draw through turbo on a 302 gmc six, the configuration more less makes me mount the 600 Edelbrock carb back wards. has anyone done this?? i had a guy tell me that the secondary's will open erratically because of the counter weight on them is working backwards. give me your ideas... thanks Jay D.
  2. RMR&C
    RMR&C
    from NW Montana
    dunno about backwards, but I have one mounted sideways on a 300 six. Seems to work fine. even on corners...
    lothiandon1940 and Just Gary like this.
  3. squirrel
    the counter weight really doesn't care about which way the carb is facing, does it?
  4. tubman
    tubman
    I like small base Rochester 2G carburetors on street driven flatheads, and have done several. They are much easier to to hook up when mounted backwards. Doing so has never caused any problems.
  5. Montana1
    Montana1
    I saw one on a flathead with a 144 blower in a '40 that was mounted backwards... because he said it was easier to hook up the throttle. He said it worked great!
    lothiandon1940 and mad mikey like this.
  6. Bandit Billy
    Bandit Billy
    Only below the equator. :cool:
  7. marfen
    marfen
    from sask
    Max wedge cross ram Carters were mounted sideways. Same carb as edelbrock. Didn't slow them down.
  8. I've floored my 650 Edelbrock in reverse and it acted just like it did doing the same in drive lol
    49ratfink, 2devilles, swade41 and 4 others like this.
  9. Mike VV
    Mike VV
    from SoCal
    What he said !!
    The only possible problem is uncovering the jets on hard acceleration.
    You CAN do like the Holley jet "extenders", form a bent tube to face the deeper area of gas, so the jets stay covered in gas under acceleration.
    Don't ask others that are only...guessing ! Give it a try.
    Mike
  10. deathrowdave
    deathrowdave
    from NKy
    Trying it is free , maybe a little time . My vote is it will be good to go .
  11. big john d
    big john d
    from ma
    2x4 fe fords holly's were mounted backwards from the factory
  12. chicken
    chicken
    from Kansas
    It'll work fine backward.
  13. carbking
    carbking
    I don't know about these carbs, but if it were a genuine Carter, I would suggest an A/F gauge to see what the A/F was doing under hard, extended acceleration. There might be an issue with the floats dropping as they should, allowing the fuel bowl levels to drop to an unacceptable level.
    Testing is going to be the answer.
    Jon
  14. Chucky
    Chucky
    Mounted backwards and at a severe angle on my ‘66 Correct Craft. Runs great.
  15. Montana1
    Montana1
    Edelbrocks mounted forwards are known to slosh fuel on hard left turns and choke out the motor, especially if the floats are a little high. (don't ask me how I know) :rolleyes:
    Depending on which way they're mounted, I wonder how that works on a sideways mounted carb?
  16. badsix
    badsix
    THANKS everyone, i'm going to try it this is what its on 31 chevy pickup 270 GMC.
    Jay D.
    pprather, Montana1 and swade41 like this.
  17. 29Sleeper
    29Sleeper
    from SoCal
    Mount them however you need too. Sometimes there isn't enough room for "normal" mounting. dominator 8v.jpg
    Just Gary and mad mikey like this.
  18. mad mikey
    mad mikey
    I do not think the carb knows the difference, only how it flows through the intake.
  19. There were two kinds of "marine" conversions on the iron manifolds. First was the Wedge adapter plate between carb and manifold and the second was aftermarket "marine" intake manifolds that actually were wedged to flatten out the carb mount. More modern conversions are just angle mounted carbs. Raise the float level and slosh. Dad sold boats for near 40 years of his life. Saw a lot of marine conversions. Good, Bad and the UGLY.
    I'm currently running a Motorcraft 2100 2bbl crosswise on an Offenhauser 360 4bbl manifold 300 Ford 6 . Every time I make a hard right hand turn at speed, it starves for fuel for a second, dies then comes back just after the turn. Learned to live with it.
    41 GMC K-18 likes this.
  20. 41 GMC K-18
    41 GMC K-18
    Well known speed boat brand from Fresno California.
  21. 4barrel Harold
    4barrel Harold
    Engine vacuum opens the rear ****erfly plate. The secondary plate is very adjustable on a Carter four barrel and it has a splash plate.
