Technical Rear shocks
Discussion in 'Traditional Hot Rods' started by Eastwood34, Apr 12, 2025.
  1. Eastwood34
    Eastwood34
    I just picked up a 34 Ford Coupe fibergl*** with a 9" rear-end looking for suggestions on some rear shocks
    dana barlow likes this.
  2. wuga
    wuga
    You probably have less then 800 lbs of sprung weight, so you don't need a very aggressive shock. After you have your rear suspension, then figure out where your upper and lower shock mounts are going. Typically the mounts are 12"-13" apart at rest. Most hot rod shocks use a 1/2" bolt eye. Hot rod shocks from Speedway or Socal work great. The shocks should be at an outward angle at the bottom of about 10 to 15 degrees making sure they don't hit anything in their travel or don't bind.
    Warren
  3. panhead_pete
    panhead_pete
    Will depend on the suspension setup. Buggy spring, coil overs? ??
    05snopro440 likes this.
  4. pprather
    pprather
    Are there no shocks currently?
    OR, is there an issue with the installed shocks?
    The starting point is not clear, as the rod was recently acquired.
  5. manyolcars
    manyolcars
    I talked to a guy today who said 80 pound coilovers were just right for this car. 120 was too much thot.jpg
  6. Bandit Billy
    Bandit Billy
    I have installed a lot of shocks on a lot of cars and my "go to" on cl***ic stuff is Bilstein. I have them on my 34 ford roadster and my 41 ford PU. They ride nice, work as designed and come in chrome! Bonus! :cool:
    Just Gary likes this.
  7. Eastwood34
    Eastwood34
    Buggy springs
  8. Eastwood34
    Eastwood34
    Issue with the existing ones
  9. Eastwood34
    Eastwood34
    Do you have a model # I can look up. I like Bilstein, I have them on a Mustang
    Bandit Billy likes this.
  10. Bandit Billy
    Bandit Billy
    Speccie and Just Gary like this.
  11. Happydaze
    Happydaze
    Speedway list chromed Bilstein shocks in 3 lengths. Fabulous shocks.
    Chris
  12. pprather
    pprather
    The Bilsteins on the rear of my buggy sprung highboy are '84-'87 Corvette rears.
    I believe the # is 24-192297
    86-4600 series.
    They have 35k miles and are quite nice. A vast improvement over the P&J shocks that were exhausted at 30k miles.
    Tim likes this.
  13. Eastwood34
    Eastwood34
    Thanks I'll look them up.
  14. panhead_pete
    panhead_pete
    As its a buggy spring what are the symptoms you are trying to fix? Please post pics of your current setup.
  15. Eastwood34
    Eastwood34
    Just trying to upgrade form Pete and Jake's shocks
  16. pprather
    pprather
    Let us know how you resolved your rear shock problem.
    What the status of the front shocks?
  17. Happydaze
    Happydaze
    Parallel leaf springs, not (transverse) 'buggy' spring. Should be relatively easy to find quality replacement. Suggest you avoid gas filled shocks.
    Chris
    05snopro440, Tim and panhead_pete like this.
  18. Eastwood34
    Eastwood34
    Thank you all for your input, I went with Bilstein. Now waiting for them to show up.
    Bandit Billy, Tim and panhead_pete like this.
  19. Bandit Billy
    Bandit Billy
    I drove my roadster last night to meet up with friends that flew into town unexpectedly. The car rides so nice and corners well for what it is, I thought of your post while driving. You cannot go wrong with Bilstein. You can get cheap and tolerable. You can get a deal on mediocre. Or you can just pony up, pay the price and get the best...which I see you did.
    Make sure you post your review after install.
    Just Gary and pprather like this.
  20. Eastwood34
    Eastwood34
    Sorry for the delay on this had some other things to take of before I could take her for a ride. Bilstein shocks were definitely the way to go.
  21. RodStRace
    RodStRace
    Thank you for a resolution! Glad you are happy with the result.
  22. pprather
    pprather
    What part number for those rear shocks?
    Algoma56 likes this.
  23. Eastwood34
    Eastwood34
    Bilstein F4-BOA-0000788 rear and BSN-24-185035 front
    pprather and RodStRace like this.
