Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Yep
    Nothing special. Off the shelf cast.
    Bout as performance as I build for myself.
  2. patsurf
    patsurf
    hillbillys use composition gaskets...safer!
    porkshop, Sharpone and anthony myrick like this.
  3. Those new fangled contraptions?
    Old engines use real gaskets
    porkshop, alanp561, Sharpone and 2 others like this.
  4. swade41
    swade41
    from Buffalo,NY
    New wheels for the 41, oh yeah it's going to be a good year for this one
  5. Bullington
    Bullington
    Getting the 392 Hemi ran in so it can go into the sedan!
    pila38, Okie Pete, Paul and 16 others like this.
  6. saltflats
    saltflats
    from Missouri
    Being I got the plasma cutter up and running we have the CNC cutting table working again. So we cut out some brackets for alternator mount and throttle cable brackets cut out.
    got the oil pick up height figured out. About to tig it with some bronze.
    Finished up porting these performance exhaust manifolds to match the later port size.:)
    If I use these valve covers one will need clearanced on the inside to clear the head casting.
    Adjusted the progressive linkage to clear the dizzy. (Not pictured)
    Gotta figure out how I’ll finish the carbs. Thinking about dipping em in the aircraft “anadozing” stuff.
    Gotta blast the timing cover and pan.
    Decide on a color. Red or black.
    Car had a red flatty when I bought it.
    pila38, Okie Pete, porkshop and 13 others like this.
  8. alanp561
    alanp561
    More progress! After sawing 1/4 inch off of the header bolts and shimming the front motor mounts 3/8", I finally got these headers in place. Some bolts went in easy; some went in 1/6th of a turn at a time. No room for sockets. Now, on to the pipes.
    Driver's side, we got clearance.
    P***enger's side.
    pila38, Okie Pete, porkshop and 17 others like this.
  9. enloe
    enloe
    from east , tn.
  10. atch
    atch
    Alan,
    At least you got yours in with 1/6 turn at a time. I usually wind up having to do 1/12 turn at a time.
  11. Robdski
    Robdski
    I took the time to remove all the rough surfaces with files, a DA, sandpaper.
    I used epoxy primer to fill the remaining low areas and block sanded, then spot primed any bare spots.
    Painted with urethane and mid temp activator. The temps in the garage made for a successful day! IMG_3595.jpeg IMG_3597.jpeg IMG_3599.jpeg IMG_3596.jpeg
  12. swade41
    swade41
    from Buffalo,NY
    I got my other fender painted
    And in between the steps in that I started removing the bolts and linkage to pull the carbs to rejet and pull the top of the tunnel ram off to make a new gasket for that
  13. nochop
    nochop
    from norcal
    Made up some radiator hold downs IMG_7644.jpeg IMG_7645.jpeg IMG_7649.jpeg IMG_7646.jpeg IMG_7647.jpeg
  14. Robdski
    Robdski
    A simple like isn’t good enough.
    Thanks to All of you folks who share the detail photos of the things you are building.
    Some things, like a radiator hold down, or spark plug wire routing, or any aspect of fabrication really, may seem simple, but, are an education for guys like me who learn so much from the things you post.
  15. milwscruffy
    milwscruffy
    Got the new firewall treatment about done on the 29 Dodge I'm working on for a friend. IMG_3274.JPG
    Phillips, Okie Pete, das858 and 22 others like this.
  16. mad mikey
    mad mikey
    That is very NICE. Well done.
  17. milwscruffy
    milwscruffy
    Thanks !
    porkshop, mad mikey and Sharpone like this.
  18. Stock Racer
    Stock Racer
    A 327 for my 62 Biscayne...
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Your pointer is too short. :)
  20. IMG_9280.jpeg IMG_9279.jpeg Little Truckdoctor and I built a bracket for the electric fan on Papaw. I just couldn’t bring myself to use the push through the fins plastic ties that came with the fan. The pictures are from the still mocking it up phase, if you pay close attention, the fan motor is contacting the water pump pulley. IMG_9279.jpeg
  21. 57 Fargo
    57 Fargo
    Andy, Are you sure that’ll hold the fan? Looks a little light.:)
  22. Sandcrab
    Sandcrab
    I set the body on again so I could route the parking brake cables and decide on the placement of a lever since I ended up with a straight pull handle.
    Then I fabricated a floor for the spare tire cavity that was lost to the tank. I made it removable so I will have access to the fuel sender and plumbing. When I thought I was only going to build smalls like my avatar I picked up a 24" brake, so for this piece I had to split it and **** weld the halves to get straight sharp bends. And then the tire cover as the gas door. I'll vent with a rollover to the fender well.
    Resized_20250419_172223_1745116625153.jpeg Resized_20250419_172437_1745116631863.jpeg
    Okie Pete, porkshop, Robdski and 9 others like this.
  23. Stock Racer
    Stock Racer
    Makes it easier to adjust the pointer which is easier than loosening the wheel to adjust.
  24. Lane, when I was involved in restoration of antique International Harvester tractors, Dad and I toured Kinze Manufacturing in Eastern Iowa. They build tillage, planting, and grain handling equipment. The man who started it as a welding shop in 1965 is Jon Kinzenbaw. His motto is “When in Doubt, Build it Stout”. I really like it, so I adopted it. That, and I was able to get the steel at work! :D
    Okie Pete, Marty S, porkshop and 9 others like this.
  25. Better to overbuild than to underbuild, s**** the first, and maybe second and third versions trying to sneak up on it.
    Okie Pete, das858, porkshop and 4 others like this.
  26. tomcat11
    tomcat11
    Killer wheels. Are they Real Rodders Sprint spindle mount, but with lug bolts? What are those bolts?
    Sharpone likes this.
  27. swade41
    swade41
    from Buffalo,NY
    They are American Rebel brand that are called Sunburst, the lug nuts are a bit strange
    Okie Pete, porkshop, loudbang and 2 others like this.
  28. tomcat11
    tomcat11
    Really nice wheels. The lug nuts are a bit strange but do make for a super clean look. Well done!
    porkshop, swade41 and Sharpone like this.
  29. deathrowdave
    deathrowdave
    from NKy
    porkshop and Sharpone like this.
  30. nochop
    nochop
    from norcal
    Bolting radiator to frame while providing a little movement to hopefully prevent cracking at the radiator lower bracket. Pretty much how ford intended IMG_7647.jpeg
