Technical 1932 Ford Grille Bars - Where to buy?
Discussion in 'The Hokey Ass Message Board' started by dlw1932, Apr 16, 2025.
  1. dlw1932
    dlw1932
    from Nebraska
    Just picked up this original 32 grille insert that’s missing 16 bars. Tried All Ford Parts and they are out of stock. Has anyone purchased the plain steel 32 grille bars recently from any of the vendors? Thanks!
  2. John Tumolo
    John Tumolo
    Maybe try NW Cl***ic Parts in Silver Creek WA. Helped me parch my 35 Ford grill. JOHN
    dlw1932 likes this.
  3. continentaljohn
    continentaljohn
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] I got some from Bob Drake but when I went to order more they were sold out. So I made my own and my tech.
    I had to make a few grill bars and this is how I made mine.
    Started out with 22 gauge or .030 and found its easier to bend on my brake in a bigger panel rather then strips .540 wide. The brake I have wants to slip out when you fold or brake the strips so ended up made some s****. So the brake will only bend it to about 60 degrees and so need to fold it over and tried a few thing. The first was the bead roller and it worked great but the grill bars got distorted and twisted. I have another brake but its buried away. So I found the vice with a drywall joint knife folded it nicely. I will make a brake press jig to do the full length in the next day or two as I am missing 30 grill bars..
    Now cutting it I ended up flipping it upside down and slid it into shear against the blade and did a great job. The look just like the real deal
  4. dlw1932
    dlw1932
    from Nebraska
    I’d be interested in purchasing 20 or 25 of them if you decide to make some extras!
    continentaljohn and 51 mercules like this.
  5. Fortunateson
    Fortunateson
    I’m looking as well...
    continentaljohn and dlw1932 like this.
  6. alchemy
    alchemy
  7. dlw1932
    dlw1932
    from Nebraska
    Talked to Josh at NW Cl***ic. I’m going to send him some original bars to use for reverse engineering them. He makes very nice products!
    deuceman32 and 51 mercules like this.
  8. woodiewagon46
    woodiewagon46
    from New York
    As continental john shows, any good sheetmetal shop can fabricate them for you.
    continentaljohn likes this.
  9. Brian pittenturf
    Brian pittenturf
    Where are you located please are you still searching?
  10. Brian pittenturf
    Brian pittenturf
    I have some grill bars please send me a email message sw3322889@gmail.com
  11. continentaljohn
    continentaljohn
    Yes they are fairly easy to make if you have a jump shear. I think the biggest issue was trying to get a set up to be consistent.
    We are pretty busy at work right now but if I do get a chance I’ll make a few hundred. I have to see if I have the correct material and or order a sheet.
  12. dlw1932
    dlw1932
    from Nebraska
    I sent some original bars to Josh at NW for him to work with. Got the stainless trim removed and grille ready to blast. Removed the bent bars that will be straightened, blasted, and reinstalled. Planning on doing epoxy primer and painting with original French grey with flattener.
  13. dlw1932
    dlw1932
    from Nebraska
    Just finished up the grille. It’s ready for primer and French grey paint. Josh from NW Cl***ic made me some new bars and they are just like NOS!
    IMG_9330.jpeg IMG_9398.jpeg IMG_9399.jpeg IMG_9400.jpeg IMG_9401.jpeg IMG_9402.jpeg IMG_9403.jpeg IMG_9405.jpeg
  14. Fortunateson
    Fortunateson
    Are you selling any?
    dlw1932 and rod1 like this.
  15. brady1929
    brady1929
    How much were they each, please?
    dlw1932 likes this.
  16. dlw1932
    dlw1932
    from Nebraska
    I paid for the bars and some tooling cost so I don’t have a piece price to share. I’m not selling the ones showed in the photos above. If anyone is interested in purchase I can put you in touch with Josh.
    19Eddy30 and Big Al like this.
  17. Super cool. Keep the info coming.
    19Eddy30 and dlw1932 like this.
