The "this is just wrong" thread
Discussion in 'Off Topic Hot Rods & Customs' started by DDDenny, May 30, 2024.
  1. jimmy six
    jimmy six
    porkshop and 65pacecar like this.
  2. jimmy six
    jimmy six
    porkshop likes this.
  3. Bleach
    Bleach
    Vette with flat head?!?
  4. chevy57dude
    chevy57dude
    Well, the 1978 Corvette had either 185 or 220 horsepower from the factory. So probably a downgrade there!
    Extra points for leaving it rusty!
    porkshop and Bleach like this.
  5. Paulz
    Paulz
    I'd have put a 300 six in the thing.
    jimmy six, porkshop, Bleach and 3 others like this.
  6. GMC or Stovebolt?
    jimmy six, porkshop and SS327 like this.
  7. EDMAR'S GARAGE
    EDMAR'S GARAGE
    from Crete, IL
    ...looks like the results of a drunken one night stand between the Batmobile and Monkeemobile.
  8. EDMAR'S GARAGE
    EDMAR'S GARAGE
    from Crete, IL
  9. EDMAR'S GARAGE
    EDMAR'S GARAGE
    from Crete, IL
    porkshop, Bleach, southerncad and 3 others like this.
  10. Bleach
    Bleach
  11. Bleach
    Bleach
  12. jimmy six
    jimmy six
    For a lot of years they were POS’s so seeing them like this will never bring a tear to my eye!
    porkshop and Deuces like this.
  13. LOST ANGEL
    LOST ANGEL
  14. LOST ANGEL
    LOST ANGEL
  15. chevy57dude
    chevy57dude
    ^ Maybe I'm whacky, but there is potential here.
    SS327 likes this.
  16. rustydusty
    rustydusty
    I kinda like it, but would have to lose the “hood ornament”…
  17. Deuces
    Deuces
  18. Surely you can’t be serious?
    Deuces and SS327 like this.
  19. SS327
    SS327
    He is serious. And don’t call him Shirley.
    Deuces, ottersea and Bleach like this.
  20. Deuces
    Deuces
    Yeah, what he^^^^^sez!...o_O;)
  21. Aaaahhhh , what is it ??
  22. A flathead Lincoln V8 hooked up to the crankshaft of the stripped flathead Ford V8 which will still turn the original gearbox in the truck.
    porkshop, SS327 and LOST ANGEL like this.
  23. Bleach
    Bleach
    It’s a Cadillac flathead with a Hydramatic transmission.
    Just because you can doesn't mean you should.
  24. SS327
    SS327
    But it is a cool Rube Goldberg way to adapt a transmission to a different engine.
    chryslerfan55, porkshop and Bleach like this.
  25. DDDenny
  26. Paulz
    Paulz
    I'd like to see the rest of that. Looks like a home made log jammer truck. Those guys got real creative with junk they had laying around to get the job done.
    chryslerfan55 and Bleach like this.
  27. j hansen
    j hansen
  28. gene-koning
    gene-koning
    What do you do when you lift things that are too heavy at the rear? Add a counterbalance to the front. He probably doubled the weight the boom could pick up.
  29. Must have been a beach to try and steer at slow speeds. Don't see any heavy lift cables or winch rig on it. How long before the flathead crank bearings run dry on the stripped ford engine. Looks like the Caddy and hydro had been set up as a sled power unit for some reason and was later put on the front of the truck as a quick and dirty re-power stunt. Way back in the 1960's I saw several Caddy and hydro sled power units built up to run a drive shaft over to water wells in the Indio Ca. date farms. The power sled was drug around from well to well and the fly in the air drive shaft were attached between the hydro and the 90deg well pump head. Hydros made for an easy setup, just pull the throttle and set the rpm. Let it go.
    Okie Pete, chryslerfan55 and porkshop like this.
  30. LOST ANGEL
    LOST ANGEL
